Author Topic: Servicing a keyswitch (tumblers, etc)  (Read 2066 times)
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« on: November 04, 2016, 07:16:05 AM »
Is it possible to service the lock/tumblers on our keyswitches? My key is getting difficult to insert. Once it is in there it is fine to turn.
Or should I just order a new switch set?
--Evan
1975 CB750K "Rhonda"
Offline lrutt
Re: Servicing a keyswitch (tumblers, etc)
« Reply #1 on: November 04, 2016, 07:45:21 AM »
I usually give mine a quick shot of WD40 and it works fine. Doesn't take much at all to smooth things up.
« Reply #2 on: November 04, 2016, 07:58:17 AM »
^^ Yeah, soak it with oil and it should help.
Offline evanphi
  • Apparently I'm an
« Reply #3 on: November 04, 2016, 10:12:33 AM »
Riding is almost done for the winter, so I'll take it apart and give it a good spray.
--Evan
Offline lrutt
« Reply #4 on: November 04, 2016, 10:46:10 AM »
No need to take apart. just flip the little flapper open and give it a quick shot. Not a lot, just enough to make it work smoother.
Offline evanphi
  • Apparently I'm an
« Reply #5 on: November 04, 2016, 11:31:25 AM »
Well the flapper is stuck open. I'll take it apart as much as I can to clean it.
--Evan
Offline Gene
  • Chat enuf you too can be a
« Reply #6 on: November 04, 2016, 03:21:35 PM »
I would suggest graphite as opposed to WD-40 for a lubricant. WD-40 can attract grime, those pins and springs in the tumbler are fickle.  I only suggest this because that's what they used at a locksmith company I worked for - worked wonders.
*1973 CB750K3 (Bow)
Offline grcamna2
« Reply #7 on: November 04, 2016, 03:30:35 PM »
I do take switches apart(the lower part)to clean and put some fresh dialectric grease film on the contacts,it gives it a lot better contact for your electrical system.I spray a little Tri-Flow into the lock section of the switch when i have it apart and let that soak in a good bit and dry before I reassemble the lower contacts.
Offline Kevin D
  • SE Michigan
« Reply #8 on: November 04, 2016, 04:20:16 PM »
My tumbler wore out, you could see the first pin in the key slot was sideways. I managed to work it back into place but got an aftermarket switch which has been good for 15? years. I was worried that I was going to get home one day and my keys would be somewhere out on the road. The pins were always well lubed, but I think they are soft metal, brass maybe??
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline grcamna2
« Reply #9 on: November 04, 2016, 04:51:17 PM »
I think the heavy bunch of keys is what wears them fast,I like an individual key on a nice fob.
Offline jack58
« Reply #10 on: November 04, 2016, 06:01:07 PM »
Houdini lock lubricant in a spray can works very well I use it all the time
Offline evanphi
  • Apparently I'm an
« Reply #11 on: November 04, 2016, 06:04:41 PM »
I used some Rust Check. Good penetrating lubricant. Freed everything up. I let it soak overnight, blow it out, and pop some graphite in there, too.
My first pin can also get knocked sideways. It seems like it springs up too high sometimes, then can be knocked over.
--Evan
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #12 on: November 05, 2016, 01:33:13 AM »
+1 for graphite
Offline Kevin D
  • SE Michigan
« Reply #13 on: November 05, 2016, 04:38:06 AM »
heavy bunch of keys
+1
Don't have that but I do have a rub mark on the frame from the keys swinging in the wind. I took a hacksaw and cut the ears off of the house key, but I think the keyring is the culprit windcatcher. I have the original key for the fork lock, but I'm not cutting that. The switch is in a tough spot tucked under the tank lending itself to off angle entries. On some of the older Hondas the switch is on the side cover and I have seen a few keys busted off in them. Is the top triple where they are nowadays? Think I have seen some high end bikes with the proximity key.
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
Offline evanphi
  • Apparently I'm an
« Reply #14 on: November 05, 2016, 06:00:38 AM »
heavy bunch of keys
+1
I just have my two Honda keys on a ring with a small paracord fob. They clip off my 'biner full of other keys.
--Evan
Offline evanphi
  • Apparently I'm an
« Reply #15 on: June 11, 2017, 04:40:45 PM »
I know I'm resurrecting my own dead thread here... But Rhonda's ignition switch has taken a turn for the worse.
The first pin has popped out completely, and web I CAN get it back in place it is often sideways and it makes it difficult to insert the key.
If I leave the pin OUT I can turn the ignition on most of the time... But then I have to take the key back out and put it in my pocket. Then put it back in to shut the bike off. Luckily it can't be turned with a screw driver... 😆
Now I'm REALLY interested in rebuilding this ignition switch. Or getting a new/NOS one. Prefer not emgo for obvious reasons.
--Evan
Offline evinrude7
  • not a kung-fu
  • something to hüsker
cb750 k6 - ugly
Offline grcamna2
