Author Topic: reg/rec  (Read 1039 times)
Offline faeth007
reg/rec
« on: November 05, 2016, 02:42:17 PM »
Hi all its been awhile. Not long ago I purchased a YHC-103  electronic regulator/rectifier however the wire colors differ
from my bike three white which i'm sire go to the yellow but the red,black brown and yellow confuse me if anybody has used
this reg/rec I'd appreciate any insight as to how to wire it up. It came from China with no instructions.
Thanks
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: reg/rec
« Reply #1 on: November 05, 2016, 03:08:42 PM »
Why roll the dice on that part?
Oregon Motorcycle Parts has replacements that are warrantied and come with great instructions!
Offline Bodi
Re: reg/rec
« Reply #2 on: November 06, 2016, 07:44:06 AM »
Not super helpful to say throw it out and get something else.
I would guess the red goes to battery: that's pretty much standard everywhere. It will then need ground, switched +12V power in, and field coil power out wires (and you have four mystery wires! coincidence?).
See if black and red have diode continuity to the white wires - consistent readings to all white wires, low resistance with meter leads one way and high the other way (or around 0.5 one way and ERROR the other way if you have a diode test meter). If they do, very good bet that these are ground (black) and battery (red). Honda uses black as the switched power wire, but other brands often use black for ground.
The other two wires are a bit harder to figure. My guess is brown for switched power and yellow for field coil but no certainty and offhand I don't know of a test. If one has diode-like continuity and the other doesn't ... I think probably the one that does will be the switched power input.
At least try it... if you burn it out then BM650's suggestion sounds OK.
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=5slf7outu8qnochm97c7u8ku92&/topic,60973.0.html
Re: reg/rec
« Reply #3 on: November 06, 2016, 11:34:10 AM »
try to Google the numbers... or Photo Google the Photo.. often some diragrams pop up...i have faund a lot in there..even some relevalt for the repareir
i hate all this v-w.... vords
