Author Topic: Palepainter's 750f project.. Al Fine'  (Read 63634 times)
Offline budman
  • 1914X
    • LeCompte Electric Bass
Re: My first CB 750f project has started
« Reply #100 on: December 14, 2016, 10:12:55 AM »
Diagram sent.
Bud
1973 CB750K3 Chopper
2021 Indian Scout
Offline palepainter
    • Mike Learn custom paint and airbrush.
« Reply #101 on: December 14, 2016, 10:42:52 AM »
Diagram sent.
Got it Bud.  Thanks a ton.  I going to give it a good look over this weekend.
Mike
Offline palepainter
« Reply #102 on: December 16, 2016, 05:07:43 PM »
Well, the welder went down again.  So in order to keep moving, the sand blasting has commenced.  There is a bunch of it.   I managed to get the rear caliper torn down.  Will need new seals and one piston.
« Last Edit: December 16, 2016, 05:50:27 PM by palepainter »
Offline palepainter
« Reply #103 on: December 16, 2016, 05:27:17 PM »
Rear caliper torn down and am cleaning up the castings.  Call me OCD.
« Reply #104 on: December 16, 2016, 05:39:10 PM »
Well, the welder went down again.  So I order to keep moving, the sand blasting has commenced.  There is a bunch of it.   I managed to get the rear caliper torn down.  Will need new seals and one piston.
SiriusConInc.com has a kit with both pistons and seals at a reasonable price
Offline palepainter
« Reply #105 on: December 16, 2016, 08:50:06 PM »
use this:
Thanks Calj, I seen that on chop cult.  I looks like a good place to start.
Offline palepainter
« Reply #106 on: December 17, 2016, 07:35:01 AM »
Thanks for that link Jerry!!!
Offline palepainter
« Reply #107 on: December 17, 2016, 03:14:05 PM »
The only way I have ever finished projects was to keep at it amidst stumbling blocks.  So since the welder is down, I went ahead with painting blasted parts.  Etch prime, base and clear.
« Reply #108 on: December 18, 2016, 10:22:37 AM »
 Hope you got  soft jaws on order...
Offline palepainter
« Reply #109 on: December 18, 2016, 02:47:22 PM »
Today I met up with a local CB collector/builder.  Purchased a few items from him including neck bearing kit, oil pressure gauge, and updated fuse block.  This guy has it all, tons of stuff.  Man.....  I am sure he will be taking my money.  I found a set of wheels from 77 SS for my bike.  After pricing a bunch of different options for making the spoked wheels look decent, I pulled the trigger on these mag wheels.  I will be able to take them down and powercoat or paint them.  I will put the money saved somewhere more important.  I really like the look of the wheels on this bike.
Offline palepainter
« Reply #110 on: December 18, 2016, 02:50:46 PM »
Has anyone used this oil temp/ dipstick on their bike Supersport.  I was wondering if it fit under stock side cover?
Thanks.
« Reply #111 on: December 18, 2016, 04:25:31 PM »
Hold onto that rear SS hub.  Many people with spoked drum rears wanting to upgrade to a disc, and they can easily relace a wheel.
Offline budman
  • 1914X
« Reply #112 on: December 21, 2016, 09:47:28 AM »
What are the ping pong balls for?
Bud
2021 Indian Scout
Offline palepainter
« Reply #113 on: December 21, 2016, 10:30:10 AM »
Bud, they are to put into intake boots when I soda blast the motor.
Offline budman
  • 1914X
« Reply #114 on: December 21, 2016, 11:52:49 AM »
Clever.
Bud
2021 Indian Scout
Offline palepainter
« Reply #115 on: December 21, 2016, 12:30:16 PM »
Ping pong balls at work.
« Last Edit: December 21, 2016, 12:41:32 PM by palepainter »
Offline palepainter
« Reply #116 on: December 23, 2016, 10:26:03 AM »
I cut and drilled the gussets today.  The welder is back.  Taking some time between Christmas and New Years to finalize frame and get to blaster.
Offline palepainter
« Reply #117 on: December 23, 2016, 04:21:14 PM »
Can anyone confirm the year of this front caliper sitting in the beer tray?  75K?   The one that came with bike is shot.  I fired up my PM caliper to push out pistons.  Worked pretty slick.
« Last Edit: December 23, 2016, 04:43:53 PM by palepainter »
« Reply #118 on: December 23, 2016, 05:53:54 PM »
 Caliper is 73-76 if it came on that bracket..
 Your gussets look like they may be quite thick... If they are more than 1/16 ” thick, they are just extra weight...plus there is a tendency for vibrations to concentrate near the bracket if you use overly thick material.      Plus its harder to bell the holes..
Offline palepainter
« Reply #119 on: December 23, 2016, 07:06:23 PM »
Yup.  Those came on that bracket.   Thanks, now I know what rebuild kit to get.   .110 is the plate thickness.
Offline Godffery
  • Godffery's Garage
« Reply #120 on: December 24, 2016, 11:46:42 AM »
 Looking pretty interesting Man,
I could help with those Brake components if you'd like:
http://www.vinmoto.org/gallery/v/VinMoto-Garage/album03/Godfferys-Garage-123/Parts+and+service/
Offline palepainter
« Reply #121 on: December 24, 2016, 04:29:09 PM »
Thank you for the link.  I will keep your services in mind.   This afternoon  I made the spacer between the tank and tail section.  .080 aluminum with flanged holes.  My wife calls it the nut cooler panel.
« Last Edit: December 24, 2016, 05:10:08 PM by palepainter »
Offline Godffery
  • Godffery's Garage
« Reply #122 on: December 24, 2016, 07:08:15 PM »
Ha, we all need a Nut Cooler from time to time!   =)
Offline palepainter
« Reply #123 on: December 27, 2016, 05:45:16 PM »
Tonight I made a bracket for the tail light and mocked it up and shimmed the tail section to its finalized position.
« Last Edit: December 27, 2016, 06:29:50 PM by palepainter »
Offline palepainter
« Reply #124 on: December 29, 2016, 10:51:30 AM »
I got the frame ready for blaster and started to tear down the forks for rebuilding.  I am running into a problem.  I got the cap off the top, removed the springs.  But can not get the bottom bolt to come out.  It just spins.  Am I missing something here or am I literally screwed.  :)
