Author Topic: Palepainter's 750f project.. Al Fine'  (Read 63091 times)
Offline calj737
  • I refuse...
Re: Palepainter's 750f project..electrical psychosis.....
« Reply #425 on: March 12, 2017, 07:49:40 PM »
The GR/Y wire carries power to the tail light when the switch is activated. The tail light is grounded separately. Unless yours is wired differently? You should have a solid BLACK wire at the switch (power) that is transferred to GR/Y. You can check that with a meter at the switch to make sure thats happening. You can also confirm the GR/Y is connecting to the proper wire color at your tail light (aftermarket, right?).
Some aftermarket tail lights want both the TAIL and BRAKE circuits powered to illuminate the BRAKE bulb. Not common, but I've seen it with modular LEDs and its a PITA.
Offline palepainter
    • Mike Learn custom paint and airbrush.
« Reply #426 on: March 12, 2017, 08:03:02 PM »
Ya Cal.  I have spliced the G/y wire starting on the one side of the front pressure switch.  That then runs back and spits off into the one leg of the mechanical switch on rear brake.  The black one goes to power as well, but on a separate leg.  This is a LED with common ground and two hots in.  It appears that the light functions by adding more LED when brake circuit is engaged.  Pretty simple brake down.
I do have to remind you that my schematic is far from stock.  I have one leg on breaker running lights.  The LED turn signals have very low draw.  Same as the rear light.  I have ignition on another leg on its own breaker as well.  I have an AUX circuit left over for who knows what at this point.
Nothing on any of the switches is a power to ground....It is all power through switch.  So I feel like something is not right.  When both of the switches are engaged, it will,  The power on  both sides of the switches has to come from the same circuit, correct?
Offline palepainter
« Reply #427 on: March 12, 2017, 08:17:24 PM »
Ok...Sitting here with a clear head.. I see what I need to do.  :)
Offline innovativems
    • Innovative MotoSports
« Reply #428 on: March 13, 2017, 06:29:05 AM »
woo hoo!  glad you're almost done!
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Offline palepainter
« Reply #429 on: March 13, 2017, 11:15:32 AM »
Very close.  I just fixed the brake light system.  I am too embarrassed to mention what I did wrong and threw up an issue.
Offline irish44395
« Reply #430 on: March 13, 2017, 03:49:36 PM »
Thats me on a daily bases
Pete
Offline palepainter
« Reply #431 on: March 13, 2017, 05:57:33 PM »
I thought I had electrical psychosis on this Honda...then this shows up today.  82 Suzuki GS1100....more electrical than NASA space shuttle.  Ran...Until my neighbor thought he would build a café racer.   :)  200 and its mine.  Came with title.
Offline budman
  • 1914X
    • LeCompte Electric Bass
« Reply #432 on: March 13, 2017, 06:35:36 PM »
The two brake light switches are similar to parallel output on a dual coil humbucker.  Shouldn't hurt anything.
I found this photo of the original motorcycle with the fairing that I thought yours resembled.  I had never seen the original bike, only the Jeff Decker sculpture.
Bud
1973 CB750K3 Chopper
2021 Indian Scout
Offline palepainter
« Reply #433 on: March 13, 2017, 07:11:32 PM »
HEHEHEHE.  Yes, exactly.  Humbucker is it.  I had it right when I wired it...but forgot to check the adjustment on the mechanical switch.... It played with my head, because I went right for the worst case scenario.  :)  It is all wired, I just need to verify that I have the Alt/Reg/Rect hooked up properly.
  I had not seen that photo before.  Just the sculpt as well.
Offline palepainter
« Reply #434 on: March 14, 2017, 07:07:26 PM »
Ok. I think I'm ready to fire it up once new throttle and clutch cable are here.  I filled it with oils and all the new gaskets and seals are holding up to the 4.25 qts i threw in her today.  I disconnected coil and cycled oil for a while.  Oil pressure up.  Tomorrow I will put new plugs and get some gas for it.  Clutch cable and last few pieces here by Friday.
I was surprised how easy it was to find a an oil filter locally.
Took a good look at one of my next projects today.
« Last Edit: March 14, 2017, 08:46:05 PM by palepainter »
« Reply #435 on: March 15, 2017, 07:42:21 AM »
Fire that bad boy up!
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Offline palepainter
« Reply #436 on: March 15, 2017, 06:23:25 PM »
Hey Shawn.  I have it all ready to go.  But I am going to patiently wait until Friday.   It is my birthday and I am taking the day off work load to enjoy a cruise through the countryside with my trusty tools.
Today I bled out the front brakes and changed plugs.  Got gas in a can.  Ready to go.  Just waiting on clutch cable which should be here tomorrow.
« Last Edit: March 15, 2017, 06:25:25 PM by palepainter »
Offline palepainter
« Reply #437 on: March 16, 2017, 06:01:39 PM »
Damn clutch cable has not shown up yet.   Grrrrrrrr.  I hate to throw on the old cable just to get my kicks.   It is fractured and frayed.
Installed new throttle assembly and adjusted cables.
Fabricated license plate bracket and lighting for it.
« Last Edit: March 16, 2017, 06:18:58 PM by palepainter »
« Reply #438 on: March 16, 2017, 06:08:05 PM »
The streamlined Knuck is the one ridden by Joe Petrali..set a record back in 36 or 37.
« Reply #439 on: March 16, 2017, 08:54:47 PM »
FYI - Drag Specialties now makes a license plate frame with an LCD integrated into the frame rail to illuminate the plate.
Offline palepainter
« Reply #440 on: March 16, 2017, 08:57:22 PM »
  Ya...  Cha Ching.  :)  This one cost me 2bucks.
Offline palepainter
« Reply #441 on: March 17, 2017, 12:37:07 PM »
Finished up the seating area today.  Found a clutch cable locally.   Put everything together added gas then hit the start button and VROoom.
Offline Godffery
  • Godffery's Garage
« Reply #442 on: March 17, 2017, 03:07:05 PM »
 Now, I would suspect a BOTM nomination coming soon.?!    :D
« Reply #443 on: March 17, 2017, 06:33:25 PM »
Mike, so, is the paintjob offer on the table to sort the Suzuki GS wiring for you?
Do you think a paint job in trade for someone to have done your electrical for you still a fair deal to you?
Seems to me it is far more work to do all the hard work in the prep for paint so it comes out nice and stays nice.
Years ago, I have seen too many body repairs (done at good body shops that were not cheap) show up like a sore thumb where you can point to exactly where they used filler as the clear coat in that area would lose much if not all of the gloss where you could chalk an outline of the areas filled.
It would start being seen after a year to 18 months and easily seen from 15-20 ft away by 2 years.
I never understood how you could have a place do a body repair where some filler was required and they could do the job in less than a week.  The filler would still be hardening a week or more, even if it was in a warm shop or put in a booth with slightly elevated temps, (drying lamps not running full duty cycle like they would use to cure paint jobs so they could get the vehicle out of the booth for another paintjob...I am thinking 120F-140F bake... to get the plastic filler to fully harden and outgas any chemicals...close to all that it ever would. Or, if it is strictly a function of time for the cure.) To my knowledge they do not typically do, as they do not have the space in booths for that to be done and it is expensive to use the booth that way.  Granted this was stuff I was seeing done around 2000 and before.  Have materials advanced where that is no longer an issue? Is that a failure in not using a sealer that should have been done or was it just a failing of paint or body filler materials?
Even a coat of wax did not eliminate it from being visible as I am not sure if it was a combination of shrinking or outgassing when going through heating and cooling cycles or what caused it.
Sorry to go so far off the deep end...
Great job on the bike!  The clutch cable you ordered ever arrive?
April is going to be a tough month to compete with this likely on the blocks...or is it May that would be voted on in April?
David
« Last Edit: March 17, 2017, 10:55:42 PM by RAF122S »
« Reply #444 on: March 17, 2017, 06:35:48 PM »
David
We are currently voting for April BOTM.  Nominations will be open on April 1 for May BOTM.
« Reply #445 on: March 17, 2017, 07:26:38 PM »
I knew someone would jump in to correct my errors...  What better than one of the guys who helps run the BOTM and gives us all those cross-posts in various forum areas to remind us to "get out and Vote" before the clock runs out.  Thanks CB750 Cafe Racer Fan!  8)
Peace out...
Boy my last post sure is long looking at it on the screen now... I only see a little window of text on my tablet. Yes, I know who Captain Obvious is... ::)
If you guys like I could send that SoyBoySigh or SighBoySoy or whatever his ID is to step in and show you a really really long inane posting.
Offline palepainter
« Reply #446 on: March 17, 2017, 10:01:10 PM »
Shawn, so, is the paintjob offer on the table to sort the Suzuki GS wiring for you?
David
Time is generally your friend when it comes to painting.  That only changes when you are dealing with windows between base coat and top coats.  But there are ways around that as well.  For example, if your base calls for clear to be applied within an 8 hour window, but you need to do striping or taped graphic that requires more time, all you have to do is use an intermediate clear or clear base coat to open up that window again.  A case in which too much time can slow things down is if you wait too long to buff.  A clear has an optimized point in time in which it sands and buffs the best.  That will vary with the type and brand of clear.  I typically do not like to rush stuff in regards to the cure, but will use UV lamps to accelerate when appropriate.
Sealer is a safety barrier when working over older paints.  If you have stripped the sheetmetal and are working up from there, generally, you do not need sealer if using a urethane or epoxy primer.
Clutch cable didn't make it here....there was a snafu on order.  I found one locally.
In retrospect, the wiring job was easy once I trashed the idea of maintaining the factory harness.  Then it was pretty straight forward other than the new regulator pin coordination on the connection.  But, I would have much more enjoyed painting a bike for someone, than wiring.   :)  It was good to dabble into the unknown a bit.
« Last Edit: March 17, 2017, 10:06:05 PM by palepainter »
« Reply #447 on: March 17, 2017, 10:51:57 PM »
Mike, I figured that was the case... Just like the way we have to approach a job of eating an elephant, only way it can be done is one step at a time.
Same way you prep a part...you break it into steps or bite size pieces.
Totally understand you on the enjoyment of one task over another...  In woodworking most almost universally hate sanding,  I love sanding...feeling it and seeing it come together...it is like getting a long curl when using a hand plane from a plane blade you've honed to a sharp edge and you are able to get the feel and smell and visual of that plane skimming off the high spots or leveling a board or trimming a joint with the plane...etc.
So, when it comes to polishing, while the sanding is tedious and it making your fingers hurt after a while, all of that work starts to quickly show when you start buffing the parts with the polishing compound and the gleam of the polished aluminum develops.
Stuff with intricate curves can be really tough though and you hate those just like everyone else. It really is the difference between having some of the tools that a professional would use that makes that task easier.
Oddly enough electrical many have a mental block that it is some giant hurdle they are not capable of solving.
Some of the electrical stuff with cars today is well beyond the ability of home mechanics because of the computerization of many modern cars. But, there are tons of cars that develop electrical problems and those shops doing electrical work earn $$$ because so many mechanics can't solve electrical problems because they are racing to crank out tons of work to perform and bring home their normal salary. Electrical problems usually are not something that is rapidly solved and is a single point of failure. The typical book rate and manufacturer's approach is to shotgun the problem into submission replacing lots of components until you don't see the problem or it fixes it. So, often wiring issues that go intermittent cost tons of money because if they are trying to solve it replacing lots of components and it is at the owner's expense. When the manufacturer is paying the bill they can afford to have the failed components or those replaced be sent to a recycler who can thoroughly test the component to cull through the expensive ones to see if they really were the problem with test equipment not available to every dealer.  Those remanufacturers would either verify it passes tests or it needs repaired and then they either replace the failed components or they scrap the part.
I've been down those same rabbit trails everyone has and understand some of those traps we fall into.
Bartering for work can be a very nice thing to have with people who know what they are doing and you can mutually benefit.
Having Calj virtually step beside you, and others on the forum doing this as well, and walk you through the confusing parts and helping direct you with wiring, Motogadget, or other troubleshooting and diagnostic work.
Finding a community of owners like this whom are helpful instills that sense of community and "brotherhood" if  you will, or family and friendship. We are lucky to have this forum and those mods and owners who have fostered and developed the resource we enjoy today. Kudos to Glenn and all the mods and all the contributors.
Thank you and all the others who have threads as I know it is not the most time efficient and to write it up as well as to capture the pictures and add them.  It really can slow things down and that dialogue of the thread isn't without a cost to that thread owner.  I have done threads on one of my other hobbies and it is rewarding by the ideas and things your learn while you do it. It can be a bit of work to stop everything to catch a few pictures. On some things like laying up fiberglass composites you are racing time for the epoxy to kick off so it really takes another set of hands helping with photos and even during layups that is so helpful.
David
« Last Edit: March 17, 2017, 10:59:38 PM by RAF122S »
Offline budman
  • 1914X
« Reply #448 on: March 18, 2017, 08:16:02 AM »
Awesome job.  You beat me.  I'm still waiting on a few parts before I can test ride.
Let's see some pics with the fairing.
Bud
2021 Indian Scout
Offline palepainter
« Reply #449 on: March 18, 2017, 08:41:19 AM »
Changing out the original headlight plug today.  It is giving me a bit of grief...on...off...on...  Then I will throw it on.
