Author Topic: 627B carburetors?  (Read 1049 times)
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
627B carburetors?
« on: November 07, 2016, 01:40:15 PM »
Cleaned the crud off my spare carby's - found that I had one rack of 022A where I thought I had two!
So whats the straight skinny on 627B carburetors?  Visually, there are miniscule differences between the 022A and 069A carbs.
Update; found 105 mains and 40 slows in the bowls.
What can I use between them to make one nice rack?
« Last Edit: November 07, 2016, 02:02:26 PM by BomberMann650 »
  • Holy Cow! I'm a
Re: 627B carburetors?
« Reply #1 on: November 07, 2016, 02:50:57 PM »
Well I'll be - 627b's fit the intake runners on my spare cb550F motor
Offline Scott S
« Reply #2 on: November 07, 2016, 03:36:42 PM »
 All the 500/550 carbs used the same bodies from '71-76 and, therefore, the same manifolds. The '77-78 models were different (and even slightly different from each other in jetting) and used different manifolds.
 All the other 500/550 carbs had slight differences in jetting, mixture screw settings, etc. I think that if you used the stock settings for any particular set of carbs they'll pretty much run on any 500/550 (yes....even the carbs that came on the F models with ever so slightly leaner jetting for the 4-1 exhaust. There really wasn't THAT much difference between them).
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
  • Holy Cow! I'm a
« Reply #3 on: November 07, 2016, 04:39:11 PM »
Thanks Scott!
Say, do ya think the 105 mains will work with pods?  Lol
