Author Topic: 750 k3 Left hand switch wiring  (Read 643 times)
Offline Sigop
« on: November 10, 2016, 05:13:12 PM »
Small wire pulled out of switch which controls turn signals.  I have no pictures yet and have not opened switch yet, but is it possible that some wires go through handle bar and turn signals only come out of end of switch? Size of wire seems too small to have all the wires that I see on replacement switches on ebay. I also cannot find a pic or drawing of inside of switch. I'd like to try to patch wire and keep original "gray" switch rather than replace with a mismatched shiny black repro switch.
Any shared knowledge appreciated. Thanks.
CB750 K3  Original Owner and Operator
DH
Re: 750 k3 Left hand switch wiring
« Reply #1 on: November 11, 2016, 04:24:38 AM »
http://manuals.sohc4.net/cb750k/technical_reference/WD750K3_K7.jpg
as far as I remember, all 11 wires go thru bars to inside of headlite housing, (on a stock bike) where they all connect to like colored wires in the main harness etc.
« Last Edit: November 11, 2016, 04:38:40 AM by DH »
Offline Sigop
« Reply #2 on: November 11, 2016, 05:59:18 AM »
Thanks, DH.  I'll see what damage I can do.
Offline Phuz-E
« Reply #3 on: November 11, 2016, 07:12:48 AM »
I am in the process of wiring exactly this. Yes all 11 wires run through the bars. What color is the wire you pulled loose?
Offline Phuz-E
« Reply #4 on: November 11, 2016, 07:30:19 AM »
Lt green- Horn. O/w-left marker LtBlue/W-right marker, O-left turn, LtBlue-right turn, grey-blinker wire, Dark blue-headlight (high) white-headlight (low) green-ground......Unsure of others as my controls are after market. You may have a Brown/W and a Brown/Blue- turn buzzer
Offline Sigop
« Reply #5 on: November 11, 2016, 06:00:39 PM »
Away from the bike until Monday but will get some pics when I get back to it. The small wire/black cable that pulled out had a small pin at the end, a spring around it, surrounded by 2 small metal inward facing brass clamps or contacts, if that makes sense. Still have not opened the switch but I'm wondering if that pin broke off and was maybe a contact pin of some kind. I have not pulled any of the wires yet.
Sorry to only have partial info still.
Offline whitjonw
  • Motorcycle Maniac
« Reply #6 on: November 13, 2016, 02:35:16 PM »
That sounds like the starter motor safety switch wire.
1973 Honda CB500 K2
1974 Honda CL200 Scrambler
1974 Honda CB750 K4
1976 Honda CB750 K6
This is our life, this is our song.....
