Author Topic: 1975 Honda CB750F Cover Bolt Torques  (Read 1042 times)
Offline RodSOHC750
  • Restoring Vintage Honda Motorcycles
« on: November 11, 2016, 06:52:17 PM »
I am curious to what is the correct tightening torque for the engine covers using 6mm bolts (valve cover, alternator housing, drive sprocket cover, clutch cover, valve cover top cover).  I am using gaskets w/0 sealant and socket head bolts with flat washers.  I'm screwing into aluminum, of course. I was tightening to 8 ft-lbs torque until I had one strip out on me.  Then I began torquing to 5 ft-lbs.  Now I'm worried this may not be enough to prevent oil leakage.  Anyone have good practical experience on the correct tightening for these bolts?  Thanks.
1979 Honda CB750L Limited Edition
1975 Honda CB750F Super Sport
1972 Honda CL450
1970 Honda CT70
Re: 1975 Honda CB750F Cover Bolt Torques
« Reply #1 on: November 11, 2016, 07:13:57 PM »
I think its 5-8 ft lbs.. If you were only at 8 I think it was previously overstressed..
