Highly unadvisable to bead blast an assembled motor. The media will find its way into oil galleys and bearing surfaces. This will drastically shorten the lifespan of your motor. Some have sofa blasted their motors, but that does necessitate flushing the entire motor well as soda/oil cause congealing of the oil.
Best to simply use wire brushes and elbow grease and solvents to strip the motor. I like stainless steel brushes to cut through the oxidation. It also doesn't scratch so heavily against raw aluminum. You can follow that up with ScotchBrite pads for a more brushed finish.
