Author Topic: K8 Highway Racer - Finished  (Read 28465 times)
Online seanbarney41
Re: CB750 K8 Highway Racer - Updates
« Reply #100 on: December 22, 2017, 03:27:20 AM »
subscribed, I got a set of Marzochi's that need rebuilding also...kinda pissed that the fellow who sold 'em to me told me that rebuild kits were generally available from vintage Ducati sites.
Offline JoeCooley
  • Long time lurker, but now I'm a
« Reply #101 on: December 22, 2017, 09:49:02 PM »
Here's the link to the seller. Message him, he may have kits still. I paid $100 each. https://m.ebay.com/seller?sid=marzocchimark&nav=ORDER_DETAILS
Joe in San Diego - Quick Cyles
78 CB750K 836cc Highway Racer - http://forums.sohc4.net/index.php/topic,162264.0.html
Rickman CR750 Restoration (SOLD)
Offline JoeCooley
« Reply #102 on: December 23, 2017, 10:07:29 PM »
My shock rebuild parts came in today. So I've been busy with that today. Everything's been cleaned, blasted, and primed. A couple coats of paint and I should be able to throw these Marzocchis back together. I have to remember to take pics as I go. I'll attach a couple for now.
« Last Edit: December 23, 2017, 10:53:48 PM by JoeCooley »
Offline JoeCooley
« Reply #103 on: December 24, 2017, 09:46:12 PM »
Ok so one shock done one to go!
Here's a couple pics! The disassembled pic has the parts laid in the proper order of assembly. It looks complicated, but these shocks are really pretty simple. Refer to the manual on the site I posted earlier in this thread. I'm using 10wt fork oil in mine but the internet claims you can go as high as 30wt depending on your dampening needs.
The paint turned out pretty good for rattle can. Hopefully my stickers will arrive soon from Europe.
« Last Edit: December 24, 2017, 09:53:31 PM by JoeCooley »
Online seanbarney41
« Reply #104 on: December 25, 2017, 06:01:47 AM »
Those look great on your bike!...hope they perform as good
Offline JoeCooley
« Reply #105 on: December 25, 2017, 11:23:53 AM »
Thanks Sean. It took a while, but they are both finally rebuilt. Well, this was more of a restoration. Haha.
Let me know if you have any questions when you go to rebuild yours.
« Reply #106 on: December 26, 2017, 09:32:57 AM »
How do you determine the weight of shock oil you need? A thicker weight is going to be slower to work its way through the shock and result in firmer ride.  I understand you want it to be compliant and maintain contact as well as not giving you a firm ride transferring those bumps into your body but absorbing those.  A motocross or adventure bike would use a very low weight shock oil.
David
Offline JoeCooley
« Reply #107 on: December 26, 2017, 02:03:32 PM »
For me it will be trial and error. According to my (limited) internet researce on these shocks, ~5wt was used from factory. Most guys complain about them being too soft and switch to 10wt. 10wt also happens to be the same oil I run in my triumph's forks. I need to reseal one of those again. So it made sense to buy a quart of it to use on both bikes.
There isn't much literature on these old Marzocchis and the factory manual is quite vague. In theory, the better designed dampers will require thinner oil than an old shock from the stone age...
Offline JoeCooley
« Reply #108 on: December 27, 2017, 09:11:30 PM »
Well my stickers came in from France. The shocks look much nicer now. Finally finished with that part of the build.
Offline JoeCooley
« Reply #109 on: December 30, 2017, 09:27:00 PM »
Tarozzi rear-sets DONE! The brake side was a pita! 😲
If this doesn't work out I'm just going to get a cable setup.
Next up: Clutch replacement and modification as per Mr. Hondaman.
Happy Year everyone!
-Joe
Online seanbarney41
« Reply #110 on: December 30, 2017, 10:26:16 PM »
you got that set up really weird...does it work good?  Here is mine, works good...
DSCN0944 by Sean Barney, on Flickr
« Last Edit: December 30, 2017, 10:30:41 PM by seanbarney41 »
Offline JoeCooley
« Reply #111 on: December 30, 2017, 10:43:58 PM »
Yes it works well. It took a lot of trial and error to make it all fit and work correctly. I have a K8 so the bolt on kits don't work. Also, I can't  go above like you did because the rod will hit the swing-arm nut. Luckily Cognito Moto sells brackets and other bits to make it happen. I may shorten the lever a bit to make packaging easier and clean it up a bit.
Offline JoeCooley
« Reply #112 on: December 31, 2017, 12:07:53 PM »
New clutch time! I've had these parts for like a year.... Finally get to it...
« Last Edit: December 31, 2017, 12:09:34 PM by JoeCooley »
Offline JoeCooley
« Reply #113 on: January 03, 2018, 08:01:02 PM »
Some new parts showed up...
Offline BPellerine
Re: K8 Highway Racer - Nobody cares? 🤔
« Reply #114 on: January 04, 2018, 10:10:16 AM »
some good parts,I have one of those cams,havent tried it yet,but it kissed the pistons in a stock engine,maybe contact cyclex about milling the pistons down?
1978 CB 750K ard and webers
another anfob
Offline JoeCooley
« Reply #115 on: January 04, 2018, 10:23:32 AM »
Do you know any of the specs for the cam? I can't find anything on Google.
The valve reliefs are huge on these pistons. I doubt I will have any contact.
Yes, I should contact them. Maybe they will know how much I should take off it I want to lower the scr.
Offline BPellerine
« Reply #116 on: January 04, 2018, 06:07:00 PM »
some guy on here contacted crane cams and got the specs for one of there other cams maybe they can supply you with info,I was not thinking you would have contact with those pistons,just knew it had a little too much lift for stock pistons,hope you can get the cr down.
another anfob
Offline JoeCooley
Re: K8 Highway Racer - Updates!
« Reply #117 on: January 12, 2018, 07:39:18 PM »
I contacted Crane's tech line. They said they will research it for me and email if they found anything... A week later and no word... So yeah.
On a positive note, I'm almost done with the rewire and new bar controls. I fired it up on starting fluid! So I know the coils are working and most of the bike is wired correctly. I went to a K1 harness and minimalist early style bar controls. Everything works except the signals. I think it's a simple fix but who knows. I have to probe the switch and check for power and see if it is even functioning. It's a cheap repop.
Also, some of new go fast parts showed up. So far I have the pistons, crane cam, CX Super rods, RC red retainers, and some stock rocker parts. Thinking about sending my gears off to be undercut.
Offline calj737
  • I refuse...
« Reply #118 on: January 13, 2018, 04:05:10 AM »
Check if your harness has the signal power being supplied from the TURN SIGNAL RELAY. On many models (I don't know the K8 well) power comes to the LH pod on GREY.
Offline JoeCooley
« Reply #119 on: January 16, 2018, 01:06:59 PM »
I found the problem! It was just a missing spring on the little contact in the switch which I forgot to put in on reassembly. Stupid mistake that cost me an hour of diag to find. Oh well, it's good now. Haha
So Phase ll is nearing an end. The bike is looking much better now and everything seems to work electrically. I can't wait to ride this thing and see how she handles. 👍😎
« Last Edit: January 16, 2018, 04:38:42 PM by JoeCooley »
Offline SKTP
« Reply #120 on: January 16, 2018, 01:20:57 PM »
Looking good! What Wiseco pistons did you go with (assuming you have a 1978K head)? I am thinking of getting Wiseco 863cc pistons and and trying to figure out if the 78K uses the F style of the 69-76K style...I think F, but I need to do more research
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
« Reply #121 on: January 16, 2018, 02:13:32 PM »
Looks fantastic!
Offline JoeCooley
« Reply #122 on: January 16, 2018, 04:48:53 PM »
Thank you. My current build is a bit of a mutt. CruzinImage flat top 65mm pistons, 72k cylinders, 72k cam, 75 F1 Head, Kimble white springs. I had 3 angle valve job done and springs & seals replaced.
The 78k Head is supposed to be similar to the F1 head. The F2 got the change in combustion chambers. I have my old 78K head laying around and it looks pretty much like the F1.
Looks fantastic!
Thank you Stev-o! It means a lot coming from you. Your bikes are all very nice. This bike isn't perfect in any way. It does however remind me of a track worn 70s racer with modern updates... That's kinda the look I'm going for....
Cheers Guys!
« Reply #123 on: January 16, 2018, 08:04:20 PM »
Looks good, Joe.  Ride it like you stole it!
Offline JoeCooley
« Reply #124 on: January 16, 2018, 09:22:32 PM »
Thanks Don! Oh, I plan to ride $hit out it!!!
Seat pan is started. Just taped it up with packing tape and masking tape. I might lay the first layer of glass tonight. Kinda tired tho and I have to be up at 0500...
« Last Edit: January 16, 2018, 09:29:10 PM by JoeCooley »
