Author Topic: Hindle 4-2-1 Stainless exhaust - first impressions!  (Read 11078 times)
Offline markreimer
Re: Hindle 4-2-1 Stainless exhaust - first impressions!
« Reply #25 on: November 25, 2016, 02:54:15 PM »
Hey so have I! ......only I was 2 at that time.
Offline USMC5811
« Reply #26 on: November 25, 2016, 03:05:55 PM »
I was well into my teens and listening to REAL punk
LOL
Offline calj737
  • I refuse...
« Reply #27 on: November 25, 2016, 03:20:38 PM »
So do you think that crusty part inside should be knocked down a bit..
 All the way may weaken it too much.
Not necessary at all.
I can see the benefit from a pure performance point of view, lessening restriction of exhaust flow, but I don't think I'd notice or appreciate such marginal gains enough to warrant potentially weakening the pipe. Correct me if I'm wrong but I can't image that would make much difference? If I wanted to go faster I don't think I'd grind the welds down...I'd do an 836 conversion  8)
There won't be any issues with performance. It's purely a quality control thing. And aesthetic.
Offline Lostboy Steve
« Reply #28 on: November 25, 2016, 04:44:18 PM »
Ever see the guys racing lowered civics? The literally flatten the two lowest tubes from "asphalt grinding" until they have holes, then they replace them and start the process over again. How in the hell can you have consistent 1/4 times when your exhaust keeps changing? Dunno. Probably doesn't matter much. There's this video... on the other hand a small 4 probably takes notice of exhaust way more than a sbc.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
« Reply #29 on: November 25, 2016, 05:47:06 PM »
Here is what i keep thinking.. Most headers are far bigger than port exit..
 Now until the pipe gets smaller than that..is it really restrictive..?
It certainly did not slow his bike down..
Offline markreimer
« Reply #30 on: November 25, 2016, 07:40:16 PM »
Good question... I suppose if it's compatible size but not smooth (from welds) it could cause disturbance and restrict it slightly but I dunno if it'd be appreciable.
I also have an xr650l and one of the most common 'mods' I hear people do off the bat is to grind the welds down inside the header right at the exhaust port. People claim you can gain a HP from that but I dunno if anyone has proven that.
Offline calj737
  • I refuse...
« Reply #31 on: November 26, 2016, 03:38:47 AM »
The weld ripples on the interior won't hurt a thing from a performance perspective. There's insufficient exhaust gas flow and volume to be effected by the few, short humps.
The biggest reason to use a purge while welding stainless tubing (or titanium ((required)) is to insure that the weld stays against the tubing. Without the back purge, the oxygen present "sucks" the weld to the inside and "sugars". This can create porosity and small pinholes. Using the purge creates an oxygen-proof weld and eliminates any contaminants and prevents the weld from forcing its way inside and drooping.
Didn't mean to kick a hornet's nest by asking my original question  :-[
Offline pipeguy
« Reply #32 on: November 27, 2016, 05:51:26 AM »
gonna keep an eye on this one.
1970 CB750 K0
1980 CBX
2001 Electra Glide
2013 CRF450R
2013 KX450F
1977 KH 400 triple (gone)
1973 CB750 K3 (waiting it's turn)
2000 KLR 650(gone)
2001 BMW 1200RS(gone)
2004 Busa limited(sadly gone)
2003 ZZR250 ninja(gone)
1996 VFR750(gone)
1974 RD350(really sadly gone)
Offline markreimer
« Reply #33 on: January 14, 2017, 04:59:29 PM »
Finally got around to installing this today.
I converted to 40mm studs. 45 would have made life easier though. Before I had the stock bolts and spigots.
Installation was a bit tricky as the bends in the system drew the whole exhaust up a bit and into the oil pan. It's currently touching the pan, which I'm concerned may lead to damage over time. I'm going to email ripple rock to see what they think. Everything else is bang on. With the whole system hooked up with the springs the muffler mount is exactly in line with the passenger peg bracket.
It's my fault, but I didn't realize this eliminated the ability to run passenger pegs. Oops. Good thing my wife got her own Sohc4 last year!
I have no experience with exhausts held by springs. Should they be 100% air tight?  When I fired it up I could see wisps of smoke coming out where the headers hook up. I used new copper exhaust gaskets so I don't think it's a gasket leak, but maybe where the headers slide onto the spigots? It looked to clear up after a few minutes I think.
Here's where it hits the pan
Sorry no video. I have one but it was running rough. Realized #2 wasn't firing after seeing the other three headers start to turn bronze from the heat (normal for stainless). Turned out to be a wet plug. Fired right up nicely after and I forgot to shoot a video. It sounds fat and sporty, loud but not absurdly so.
Offline calj737
  • I refuse...
« Reply #34 on: January 14, 2017, 05:40:01 PM »
Couple things for you to bear in mind:
Wipe the entire system down with Acetone before you run it much more. Any grease or oil left o the surface from handling and installation will turn a darker brown and not be easily removed.
You're 100% certain you got the old copper gaskets out of each cylinder? Sometimes, they're mashed in there pretty good and make fitment challenging the next go around.
To help alleviate the oil pan conflict, see if you can adjust the rear muffler hangar to be a bit longer. Doing so will pivot the pipes downward and away from the engine.
It certainly is a pretty looking system  :)
Offline markreimer
« Reply #35 on: January 14, 2017, 05:53:58 PM »
100% sure! You can see in my first photo I have the original spigots with their corresponding gaskets under them. Unless there were two gaskets in there, I got em.
I emailed ripple rock to ask what kind of clearance to expect as their website photos show what looks to be nearly an inch of room. It might be my fault, but I doubt it really. I think the bends are just a hair tight.
Offline markreimer
« Reply #36 on: January 14, 2017, 05:54:20 PM »
Also great tip re acetone!
« Reply #37 on: January 14, 2017, 10:03:17 PM »
I have no contact on my 550.
Offline markreimer
« Reply #38 on: January 15, 2017, 12:41:29 PM »
When did you buy your exhaust? I heard back from Ripple Rock, apparently the photos on their site are of an older design. The system has since been redesigned to allow for oil changes without removing the pipes, and also hugs the bike much tighter. They just installed the same one on a 750 in their shop, and I'm waiting to hear back if the collector piece touches their oil pan or if there is supposed to be 'daylight' between the exhaust and the bike.
As for the smoke around the spigots, I think that may have just been some oil and wd40 I used to help the pieces slide together burning off. The real test will come after I go for a ride. I should be able to tell if there are any leaks from the sound and backfiring during engine braking. That'll have to wait for spring though.
Offline markreimer
« Reply #39 on: January 15, 2017, 12:49:31 PM »
A bit of searching the forum and I found photos of your Hindle 550 system. It's a totally different design, pretty cool looking. But The issue I have I don't think would be possible on yours since the two pairs of headers collect around the oil pan. Mine has a 'Y' piece directly under the pan, and has a slight upward angle, which is where my contact happens.
Offline calj737
  • I refuse...
« Reply #40 on: January 15, 2017, 01:13:14 PM »
Post a picture of where your system attaches to the frame beyond the collector.
« Reply #41 on: January 15, 2017, 03:23:28 PM »
I just wonder if the adaptors might be "adjusted" by slightly loosening the lower nuts and tightening the uppers. It would take so little to get clearance at the bottom.
Offline markreimer
« Reply #42 on: January 15, 2017, 08:20:12 PM »
Hmm good idea. I'll give it a try! I've got a few sets of exhaust gaskets too so I could try tightening them after the exhaust is in place.
Ripple rock sent me photos of their 750 with the same system on it. Its sits very close to the oil pan but doesn't actually touch it, so it looks like mine has just been bent a touch more. It's designed to sit as close to the bike as possible, so I can see how if the first or second header bends were just a hair too much it would result in the horizontal section contacting the engine at some point. I don't think this is a major issue worth looking into an exchange, just trying to alleviate some stress in the system.
Here is the attachment for the muffler. It's the only attachment point other than the spigots.
Offline Desert-SOHC
  • It's old
« Reply #43 on: January 15, 2017, 09:14:55 PM »
I've worn plaid all my life and am no where close to a hipster...... :o......more like biker-redneck! ;)
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
Offline calj737
  • I refuse...
« Reply #44 on: January 16, 2017, 02:06:55 AM »
If you temporarily remove the hangar bolt you pictured, can you push the muffler down and create enough space? You should only need to move that bolt hole lower by a 1/4". That should create an 1" of space underneath.
Offline Garage_guy_chris
« Reply #45 on: January 17, 2017, 01:07:58 AM »
Here is a photo of the original system. I believe both versions are still available. Mine was a fairly early system hence the early design (no gap between 2 and 3).  Overall I have been very happy with the system Its holding up good and sounds fantastic, Only complaint is its going to be problematic to add an oil cooler adapter that i am needing for my big bore, but i happen to know Kemp has a cooler adapter in the works that will work with this early design.
I also have this vid for a little idea on sound, this is a 16" long muffler
-=Video No longer Available=-
« Last Edit: April 11, 2018, 09:17:33 PM by Garage_guy_chris »
Offline markreimer
« Reply #46 on: January 17, 2017, 09:04:43 AM »
Oh god that is a good looking bike drooooool
« Reply #47 on: January 17, 2017, 11:58:39 AM »
Pretty bike, Garage guy.
Offline Rocky2010
  • Live in Strayla
« Reply #48 on: January 17, 2017, 06:23:05 PM »
Nice looking exhaust system also like it in stainless 8)
2010 Harley Fatboy Lo
1972 Honda CB750/4 Under Restoration
1971 Honda CB500/4 Original Condition
1972 Honda CB350/4 Original Condition
1972 Honda XL250 Motorsport Under Restoration
1967 Honda C90 Original Condition
1968 Honda S90
1962 Triumph Speed Twin
1952 Triumph Speed Twin
1970 Bultaco Sherpa T
1971 Bultaco Alpina
1958 Moto Guzzi Zigolo
1970 Moto Guzzi Ambassador Original Cond
1973 Yamaha RD250
1948 Velocette x 2
1942 WLA Harley Davidson
2006 Kawasaki ZX12R (Sold)
1980 Corvette
« Reply #49 on: January 17, 2017, 06:45:06 PM »
+1 on the above.. Unless the pipes press fit on the head , it should easily move at least 3/4 of an inch at that point.
