Author Topic: Daytona Brand Fork Brace  (Read 2223 times)
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« on: November 27, 2016, 02:38:52 PM »
     Don't know if the image will appear or not, but I have a fork brace, that I bought a few years back and did not even think about what it might fit  ::) And when I got it, I realized that I didn't have anything that would be needing a 60mm fork brace.  Gonna check that part out, as soon as I post this. It has been "Garage Art" all this time. SMH, My Brain must have still been asleep that day, that I bought this. SMH.
« Last Edit: November 27, 2016, 02:49:01 PM by bill440cars »
Member # 1969
Re: Daytona Brand Fork Brace
« Reply #1 on: November 27, 2016, 03:23:13 PM »
Measure center to center..
Offline bill440cars
« Reply #2 on: November 27, 2016, 03:41:40 PM »
        Frank, Looks like 7 1/8", I didn't have any way to measure metric of that length. What do you think?
Member # 1969
Offline MoMo
  • Ride like you're invisible
« Reply #3 on: November 27, 2016, 05:42:20 PM »
Bill, inches x 25.4 to get metric   or  one inch equal 25.4mm
« Reply #4 on: November 27, 2016, 06:49:58 PM »
Just punch in 7 1/8 inches to mm on google..
Offline bill440cars
« Reply #5 on: November 28, 2016, 09:50:52 AM »
       equals 180.975 mm. Thanks, Frank. So, now I am wondering what bike(s) it would work on?
Member # 1969
« Reply #6 on: November 28, 2016, 11:13:33 AM »
It's hard to tell from that photo how it mounts.  Does it have pinch bolts?
Offline bill440cars
« Reply #7 on: November 28, 2016, 04:24:07 PM »
       If you will look closely, at the left side of the brace, I think you will see where The end piece separates. There are 2 bolts that, once removed, a piece comes off of each side of the brace, leaving a half circle on end, so you tilt it, put it between the fork legs and bolt on the 2 half circle pieces (making sure the brace is level and where you want it and tighten the bolt)s.   :)
Member # 1969
« Reply #8 on: November 28, 2016, 05:02:00 PM »
So it measures 60 mm in the holes..measure beside the slit, to the far side on other side of the slit..might have closed up a mm or two..
 The other one is likely 180mm .easy to be out a mm with the tape.
Offline bill440cars
« Reply #9 on: November 28, 2016, 06:44:28 PM »
           I'll give it a look tomorrow, Frank. Kinda wasted presently, late going to sleep last night and got up to early, as I hate laying in bed, while the day moves on. Just me, always been that way. But, I did measure with a caliper (which I think is fairly accurate. I'll post up tomorrow, when I get it checked.  Thanks you, for your input here and everyone else as well. ;)
Member # 1969
Offline bill440cars
« Reply #10 on: November 29, 2016, 11:25:58 AM »
           Measured 60.64mm, when I measured there.
          So Frank, any clue as to what this would work on?
         Or Does anyone else have any input on what this might fit?
         Or does it go back to being "Garage Art", on the wall? It looks nice enough, just would look better on a bike, than on a wall.
Member # 1969
Offline MoMo
« Reply #11 on: November 29, 2016, 03:58:12 PM »
Did a quick search and found KTM has a model with 60mm fork tubes..I have a set of Husqvarna forks that are 45 and they seem large, can't imagine 60mm....Larry
Offline bill440cars
« Reply #12 on: November 29, 2016, 04:15:47 PM »
           But This goes on the upper portion of the fork legs though. I think I might have mislead you all, in the beginning, but this does go on the legs. And I don't know if there is a chart anywhere, with that info on it. I do know that the '80' DOHC750 Four is out, as is the '80 CB650, because, even if they had the right size fork legs, they aren't perfectly round on the outside. There is a ridge on the front and back of each leg, that goes from top to bottom.
Member # 1969
« Reply #13 on: November 29, 2016, 04:17:40 PM »
I got it Bill... ;D  60mm fork legs, now they would be huge.... ;D
Offline bill440cars
« Reply #14 on: November 29, 2016, 04:22:29 PM »
            LOL, Didn't want to mislead anyone, ya know? Yeah, I hear you, for sure.  ;)
Member # 1969
