Author Topic: breather tube  (Read 1714 times)
Offline carl550k
  • 76 550k, 99 honda shadow aero
breather tube
« on: June 01, 2005, 08:26:42 AM »
 if i disconect the breather tube running from the top of the engine to the airbox would it make a difference how the engine runs? will it effect the idle? any ideas? the bike is a 76 cb55k
« Last Edit: June 01, 2005, 08:28:52 AM by carl550k »
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
Re: breather tube
« Reply #1 on: June 01, 2005, 08:31:52 AM »
The breather tube is where the moisture exits the engine when up to temperature (see other posts). It also vents any excess crankcase pressure to the outside world.
It's connected to the airbox cos the government said we must recycle oil and gasses.  Removing the tube won't affect performance, but you may get the odd speck of oil on the engine (depends on the state of your rings and bores).
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
Offline carl550k
Re: breather tube
« Reply #2 on: June 01, 2005, 08:52:33 AM »
thanks steve, but it should not efect the performance of the engine? the bike is a 1976 so it doesn't really need the emissions to pass spec in new york state,at least they never check.
Offline Einyodeler
  • Midnight bugs taste best!!!
Re: breather tube
« Reply #3 on: June 01, 2005, 09:04:47 AM »
You can route the hose down to where the carb overflow hoses are or get a crankcase vent filter to connect to end of the tube.The only way it would make a performance difference is if the tube was clogged due to dirt as the pressure from the motor would have to find another way to exit ie. seals or gaskets.
1972 CB500 - 1973 CB500 - 1974 CB550K - 1975 CB550F - 1975 CB750F - 1976 CJ360 - 1983 CR480 - 1970 BSA A65T Thunderbolt
Download Motorcycle Shop Manuals here: http://forums.sohc4.net/index.php?topic=17788.0
Bobby
Re: breather tube
« Reply #4 on: June 01, 2005, 12:45:08 PM »
For both aesthetics and cleanliness, I mount a small filter.  K&N and other filter makers produce them.  I actually bought a bunch from a guy who always has them on eBay (not K&N's) for low money.  Here is a link -
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=4553387524&category=35595
