Soooo I know this thread is inside of a few years old but I just haven't finished bc I i dont manage my money well enough to buy the tools i need. So, I bought tools instead of parts this time.
I bought a tube bender off eBay
tube notcher from eastwood
motion pro carb sync
timing light from eBay
hobart welder
Now, for parts on this project, I have an earlier GSXR front end maybe off of a 600, and i have a rear GSXR wheel.
I RECENTLY picked up the front end of a vfr700 interceptor, I have the front end, the swing arm and wheel, and the mono shock.
Ive decided to go mono shock on this project, here are some specs for the vfr bc im going to need some advice or direction on the best way to mount my mono shock.
On this bike the shock is set up horizontally coming through the front of the swing arm, can i mount a shock that functions in a horizontal position in a diagonal position for my application? or do I need to get a shock that functions in the same position as I will be seeking to mount it?
Another thing I like about this swap is the ground clearance from the wheel and fork length sizes. The forks are nice and long and keep the front up nice and high, has a 16" front tire but the rear wheel is a similar to stock 18" wheel. Here are specs on the vfr
Engine:
699cc, 70 x 45.4 bore x stroke, compression ratio 10.5:1
carburetion four Keihin CV 34/31 mm
Chassis:
wheelbase 1480 mm
rake/trail 27.8 degrees/4.3 inches (108 mm)
front suspension 37mm Showa fork, 5.5 in travel, adjustments for
air pressure and TRAC anti dive
rear suspension Pro-Link, Showa damper, 4.1 in travel, preload adjustment
tires 110/90V16 front, 130/80V18 rear
weight 501 lb wet, 470 lb dry tank
Performance:
(claimed)
horsepower 92 claimed, torque not listed
(observed)
fuel consumption 40 to 45 mpg American
average 200 yard top gear acceleration from 50 mph results in
73.4 mph terminal speed
best 1/4 mile 12.08 sec at 110.3 mph
projected best 1/4 mile 11.7 at 114.8.
The vfr rear axle is the same size as our cb 550s, So the rear wheel actually fit nicely...ill include some pictures so you can see the gaps i need to fill using some custom spacers or finding spacer, It sort of looks like the sprockets line up and the wheel is on dead center.
