Author Topic: Bummer  (Read 3501 times)
Offline josherr
Bummer
« on: December 04, 2016, 10:25:45 AM »
Offline Old Scrambler
Re: Bummer
« Reply #1 on: December 04, 2016, 02:45:04 PM »
Painful...............but not a killer ;)  Be sure to solve the oil-supply problem before replacing the parts :)
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Re: Bummer
« Reply #2 on: December 04, 2016, 04:25:50 PM »
Cripes! Never seen that before.
Re: Bummer
« Reply #3 on: December 04, 2016, 04:44:02 PM »
Not so bad... Usually can be fixed for around a hundred bux..
 Better now than in the middle of a long ride..far from home..
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
Re: Bummer
« Reply #4 on: December 04, 2016, 05:04:22 PM »
It'll still run like that
Re: Bummer
« Reply #5 on: December 04, 2016, 05:32:06 PM »
Yeah i did 60 mph over a high mountain pass , for over an hour, with one worse than that..
At least it was worse than that when we tore it down the next day.. And it had gotten louder thru the 4 hr ride that day..
« Last Edit: December 04, 2016, 09:15:50 PM by 754 »
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
Re: Bummer
« Reply #6 on: December 04, 2016, 05:48:36 PM »
     There might have been worse things that could have happened, but I'd rather not encounter any of that or the other things it could be.  ;)
Member # 1969
Offline Desert-SOHC
  • It's old
Re: Bummer
« Reply #7 on: December 04, 2016, 06:33:30 PM »
I drove one 60 miles that way, I was in the middle of nowhere.
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
Offline markreimer
Re: Bummer
« Reply #8 on: December 09, 2016, 08:43:12 PM »
Holy smokes is it cracked in half???
Re: Bummer
« Reply #9 on: December 09, 2016, 09:07:07 PM »
  They are wrong. It won't run like that. And if it would you would be putting more debris in the rest of the motor. it most likely bent at least two valves and hurt the opposite cam tower too. Check the cam tower threads in the head to see if any are pulled.
Re: Bummer
« Reply #10 on: December 09, 2016, 10:28:19 PM »
They have often run like that..( not saying you should keep running it) mine was outer end , and worse than that. I was surprised that not much ended up in filter, as 1/8 or more wore of the journal, plus a few cam lobes.
 We usually get a few members a year this happens to.
 Now why would you say the valves could be bent ?
 And why do you think it should affect the other side ?
« Last Edit: December 09, 2016, 10:34:25 PM by 754 »
Offline stikman
  • Bit of an
Re: Bummer
« Reply #11 on: December 09, 2016, 11:33:28 PM »
The motor I just rebuilt came to me looking like that on the outer end as well.  Cam bearings and a few lobes and rockers were wiped.  Clogged oil jet under that cam tower.  Mine was also seized from sitting with water in a cylinder and required more work.  You can find complete cam/towers/rockers/shafts sets on ebay for fairly cheap.  If your oil jets are clogged, you may just get away with swapping a set like that in and running it.  I'd change the oil at least once after the first brief ride or two around town.
1977 CB750A "High Horse": 836cc, mild porting, custom cam, K5 roundtops, v-stacks...
1973 CB750K D5 plunger frame chopper currently building..
Offline josherr
Re: Bummer
« Reply #12 on: December 10, 2016, 05:06:15 AM »
Thanks stikman I got this engine for 100 of Craigslist for my 750 build
PO said the cam chain might be broken but ended up being the camshaft ... no worries I'm planning on buying a ape racing kit with all that good stuff (camshaft, pistons , valves etc etc )
I have a spare 72 750 engine and plan on using the cam towers from that
Anyone advise against using the cam towers from 72 to a 75 ? Any big difference ?
Hopefully I remember to take lots of pictures to hopefully start a project thread
Re: Bummer
« Reply #13 on: December 10, 2016, 09:24:09 AM »
  Wont be a problem using the 72 stuff.
Re: Bummer
« Reply #14 on: December 10, 2016, 09:30:03 AM »
Yep. Everything should swap in.
Offline Desert-SOHC
  • It's old
Re: Bummer
« Reply #15 on: December 10, 2016, 04:53:00 PM »
Mine seized and broke on the highway at 75 mph or so, sounded like a REALLY fast BRAP/BRAP 20 or so times with a louder PING!!  Then it ran like crap and would only do 45 mph in 3rd...tops.  I rode it at least 30 miles that way, completely wasted the engine and trans.
11 Ranger S/C 2wd
Re: Bummer
« Reply #16 on: December 10, 2016, 04:59:33 PM »
 When mine got a lot worse, I arrived at my buddies 4 hrs from home .. was hoping he would come out a hear it. I turned it off , he came out and said, That bike aint going anywhere !  So we cut the frame and fixed it.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: Bummer
« Reply #17 on: December 10, 2016, 06:06:54 PM »
You mean after half the cam stops turning and half the valves stop closing and all the pistons are still moving? Sounds like the perfect recipe for bent valves to me...
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Re: Bummer
« Reply #18 on: December 10, 2016, 06:16:38 PM »
I didnt realize till now, that the cam had broke, thought i was looking at bad scoring..  ...Need new glasses....
 I retract that..it should run comment..
Re: Bummer
« Reply #19 on: December 10, 2016, 07:11:49 PM »
LOL, I had not realized it was broken at first either, until markreimer pointed it out and I had to go back and look again myself!  ;)  8)
TAMTF...
Wilbur
Projects:
Re: Bummer
« Reply #20 on: December 10, 2016, 07:39:28 PM »
They get way smaller than that if its the outboard one..without breaking..less force on them.
 If the closest one plugged, as it did.. Wonder how the other side looked ?
Offline markreimer
Re: Bummer
« Reply #21 on: December 10, 2016, 08:28:07 PM »
Haha! And here I was really questioning if I understood how this engine worked when you guys said it would still run.
Re: Bummer
« Reply #22 on: December 10, 2016, 08:49:55 PM »
Well guys have ridden them home like that..  If the valves didnt cock up...  Pull 2 @plugs  370 cc... The end of cam grinding against the other gets messy.
Re: Bummer
« Reply #23 on: December 11, 2016, 01:47:54 AM »
I saw the crack and was thinking they were smoking something funny.
