Author Topic: Electrical how-to required!  (Read 1531 times)
Offline JBCB500
  • Really enjoying this!
« on: December 06, 2016, 06:38:06 PM »
I'm in need of even more help on my project 1973 cb500.  I've finished installing a new wiring harness, and I've put in a new battery with a good charge but I get no response from any lights, horn, etc.
I'm a complete electrics idiot and the manual doesn't cover diagnosis and repair of the main board. Does anyone have a how to for testing components, modernizing if possible, etc.  I am attaching pics of what I'm looking at now.  It's obviously very dirty and corroded in places, which can't be helping.  But I don't see anything that looks like a fuse to me, and I note a loose wire with boot - where should this go?
Any pics, videos, and write ups would be hugely appreciated!
Offline Scott S
Re: Electrical how-to required!
« Reply #1 on: December 06, 2016, 06:40:13 PM »
 First pic, top left....the white tube with red wires is the fuse holder.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #2 on: December 06, 2016, 06:48:57 PM »
Lucky you these are straight forward machines and that is not a "board" like some sort of computer part.
Some manuals have a full color coded wiring diagram, that is your friend.  Provided you can physically differentiate between red and green  ;D
If you have successfully matched all the right colors together, have scant other issues like corroded switches, buttons, broken ignition key or cracked/ruined clips - you should be able to have your electrics sorted in a relaxing evening at the shop.
As for modernizing your electrics, yes - that is one thing you can do to your bike simply, and affordably with a couple pieces from Oregon Motorcycle Parts.  I have complete confidence in my bikes charging system since upgrading to OMP parts, and they were direct oem fits.
Offline b52bombardier1
« Reply #3 on: December 06, 2016, 06:52:31 PM »
Print out the wiring diagram on tabloid 11 x 17 paper for easy readability.  Starting with reconnecting the battery through the ignition switch, reactivate individual circuits one by one following the wiring diagram color code.  Do things one at a time until you are satisfied with each items performance.
  You can't eat an elephant all at once but it can be done one bite at a time.
Rick
1971 School Bus Yellow Aermacchi H-D Sprint 350
1972 Candy Yellow CL100 K2
1972 Candy Jet Green Honda CB500
1973 Mighty Green ST90 K0
1974 Mars Orange CT90 K5
1975 Topaz Orange ST90 K2
1976 Shiny Orange CT90
2006 Honda Foreman 500 (restored)
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #4 on: December 07, 2016, 03:48:21 AM »
Here's a quick and dirty write up I did:
http://forums.sohc4.net/index.php/topic,137351.msg1549191.html#msg1549191
There are a couple more electrical related links in my signature below.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline strynboen
« Reply #5 on: December 07, 2016, 06:21:54 AM »
take all komponents off the plate..and klean and paint it nicely..then klean evry part..for korosion and rebuild it on the main board..kontaktors can be glass blast,,and sprayed vith kontakt cleaner....other need to be painted to look nice...often all stuff vorks fine after a klean up..and some vires have to pun new inn
i have thanged mine fuses(nev model) and the solonid start relæ..but mostly hold the rest parts stock
« Last Edit: December 07, 2016, 10:08:10 AM by strynboen »
i hate all this v-w.... vords
Offline bochnak
    • How-To Motorcycle Repair Blog
« Reply #6 on: December 07, 2016, 08:38:57 AM »
Kind of off topic, but you may want to replace the RR wires. I used the kit from oregon:
http://www.oregonmotorcycleparts.com/SOHCfours.html
It's the harness repair kit.
Offline pjlogue
« Reply #7 on: December 07, 2016, 01:26:55 PM »
The wires going into your fuse holder look frayed (I can't tell if it is the wire or a frayed sheath to the wire) and the holder looks like it is partially melted.  Use a voltmeter to check for continuity across the fuse and repair any frayed wires then clean all connections.
-P.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #8 on: December 09, 2016, 10:49:52 AM »
-P.
They look more than frayed, they look fried!
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline JBCB500
« Reply #9 on: December 12, 2016, 10:35:10 AM »
Yeah, some of those wires were pretty crappy!  I've cleaned it up now and cut out the old style tube fuse holder and soldered in a new blade fuse holder.  These things are 15 amp, right?
  • Holy Cow! I'm a
« Reply #10 on: December 12, 2016, 10:54:10 AM »
15A main 7a lights on 550's at least
Offline strynboen
« Reply #11 on: December 12, 2016, 11:51:03 AM »
use a 3 fues holder...so you have 2 spare fuses at hand.(.in the holder)..i have a 5 fuses holder in mine use 3 of them as aktive...
