Alright, I've spent the better part of a year building a 1978F into a 970cc monster, and now I need help with the carb jetting (or what I assume is carb jetting). I will list the parts I have in the motor for reference, but when I try and kick it on, I get a fire or two, at very most 4, and it's off again. A couple backfires out the carb as well. I'm running 42mm mikuni 2 into 4 with velocity stacks and open 4 into 4 pipes. Any help you guys can provide is much appreciated!Oh, I also tightened my spark plug gap.
Engine:
Mikuni 42mm 2 into 4 (velocity stacks)
kenny D grind cam
R.C engineering head (opened to 970)
weisco pistons
970 block from cyclex
4 into 4 open pipes
cyclex optical timing
lightened and balanced crank
heavy duty crank arms
heavy duty engine studs
cyclex racing transmission
racing clutch
cyclex exposed stator (kick only bike)
Motogadget M-unit power commander
All new chains, bearings and seals
Pics are a little outdated, I'm running a remote oil filter located behind the engine, as well as a much larger oil cooler than is what is in the photo. Gotta make sure it stays cool!
