Author Topic: Another No spark/low voltage?  (Read 1150 times)
Offline MotoBro
« on: December 07, 2016, 04:14:03 PM »
1974 CB550
-Top end rebuilt
- Coils tested and are within tolerances
- Spark plug boots are crap (reading almost 8 ohms, supposed to be 5 )
-By passed Kill switch wire ( Black and white into black)
-By passed Clutch switch ( Green and red into green)
- New and clean points properly gapped
- Using a Battery Jumper pack with the alligator clips (reading about 13volts
- Black and white Wire going to the coils is reading 11.6 volts (Is something draining it?)
- Headlamp is unplugged
- Starter motor is dead (apparently- Crossed the starter solonoid, got a big fat spark and got nothing)
-Get nothing if I press the starter switch (although the neutral does dim and the voltage at the coil junction goes to 10)
- When I kick it goes up to 11.7 volts and back down Oil pressure light comes on
-Bike is in Neutral
So thats the starting point basically.  Looked at most of the other threads on this before posting and am using this diagram for wiring.
http://oldmanhonda.com/MC/WiringDiagrams/CB550.jpg
*additional note, The Horn I believe is shorted out at the actual horn (wires are fine)
I have new boots coming but I think its more important as to why I'm only getting 11.6 volts at the black and white junction into the coils. I dont have the headlight on so I have no idea what could be possibly draining the system
« Last Edit: December 07, 2016, 04:49:29 PM by MotoBro »
Offline Deltarider
  • I'm back
Re: Another No spark/low voltage?
« Reply #1 on: December 10, 2016, 06:13:40 AM »
Are you talking Ω or KΩ?  8KΩ is perfect. 5KΩ is fine too. If you read 8Ω, it would mean it's a resistorless plugcap. They exist, but I doubt you have them on your bike.
I don't know much about jumper packs but you could use a known good battery. My neighbour has a jumper pack that's a piece of junk and he'd better have saved the money for a battery.
Not necessarily. With the ignition on, current goes through a coil (at least one) to ground which is like a lamp burning and for a 12V battery system to sink to 11,6 Volts is not abnormal. There is still plenty of juice for the ignition to ignite. You haven't informed us if your plugs spark or not.
Again, I dunno what your jumper pack is capable of, but I'd use a known good battery.
Again that's not abnormal. At least one coil is consuming power (and so drains) and voltage will sink somewhat. If you switch the ignition off you can easily check for drainage by using an ammeter. Disconnect either the + or the minus cable from the battery, connect the ammeter in between and see if there's any reading. Do not use starter unless you wanna see the testwires melt!
If bike has stood for a long time like in hibernation, I recommend switching the ignition key a dozen of times and the kill switch idem dito, just to clean the contacts inside somewhat. I do that every spring before I connect the battery.
« Last Edit: December 10, 2016, 07:08:29 AM by Deltarider »
CB500K2-ED Excel black
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #2 on: December 10, 2016, 07:24:51 AM »
+1 what delta said about the battery.
Offline Bodi
« Reply #3 on: December 10, 2016, 07:54:45 AM »
First, those boost things are crap. They can recharge a (good but discharged) real battery enough to start a motor. There is NO WAY the 16450 lithium cells will provide starting current - that is just impossible, max for high current cells (expensive and not the type in those crap boost packs) is around 20 amps.
So the starter motor not turning means SFA until you get an actual battery.
The solenoid might be stuck, it happens. The Honda ones are rebuildable exept the coil assembly is sealed but that is rarely the problem.
The voltage drop would be a problem but did you measure drop or voltage at the coil only? Is the battery voltage dropping or is it a loss in the harness? 11.5V is plenty for good spark regardless.
You should have 5k or 10k plug caps. Sounds mental but the resistance makes the sparks better. Zero Ohm caps are ok with resistor plugs.
All the weird symptoms could just be a weak power source. The starter button is connecting to something which might be the solenoid. Do you have a starter safety unit or a diode to isolate the neytral light from the clutch switch? The ssu can cause oddball problems while the diode is pretty stupid and either works or not - the neutral light comes on with the clutch switch ot it won't chooch in neutral.
Jumper to a car. There are BS scare stories that this is dangerous but all untrue. Just (IMPORTANT!!!) have "-" black negative jumper cable to frame and "+" positive red jumper to the red battery wire. Reverse that and expensive trouble.
