Author Topic: RIK brand ring sets? (And what size ball hone?)  (Read 1266 times)
Offline Scott S
« on: December 08, 2016, 05:16:55 PM »
 Any opinions on RIK brand ring sets?
http://4into1.com/rik-brand-piston-ring-set-standard-13011-374-000-honda-cb550-1974-1978/
 And what size ball hone are you using to just freshen up stock bores?
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Re: RIK brand ring sets? (And what size ball hone?)
« Reply #1 on: December 08, 2016, 06:51:05 PM »
RIK rings are good ones! I use them often.
The hone: you are better off with a (fresh, new) set of straight stone hones, which you can get at most auto parts stores. The ball hone will leave the distorted cylinders distorted, which is why the old rings leaked. On these Fours, the outer 2 cylinders always are overcooled, which makes them press in toward those 2 pistons: if you carefully measure the bores you will find the most wear on those 2 corners, in something resembling an egg-shape (blunt end toward the outer front corners). If you're lucky, it will only be a few ten-thousandths of an inch: if it is more than 0.0010" then your new rings will last maybe 8k miles before they lose the ability to seal, too. The best fix is to bore a step: this will restore round forever now, as the cylinders have now cured. Lacking that, the straight-stone hones will show you where the top ridge is, and you need to hone until that is gone. This will take between 3-15 minutes per bore, depending on how often you stop and clean the stones. Be sure to use some light oil while honing, too, which will ensure the stones don't chip.
Offline Scott S
« Reply #2 on: December 08, 2016, 06:55:48 PM »
 Excellent.... thanks!
 Mostly, I'm just trying to clean up and reseal a spare engine. Just get the crosshatch pattern back in and do the rings, lap the valves, valve stem seals, etc, when I replaced the gaskets and pucks, etc.
'71 CB500 K0
'81 Yamaha XS650
« Reply #3 on: December 08, 2016, 09:49:37 PM »
I used the RIK rings as well, and no issues.
My $20 Amazon 3stone hone was a 220 grit, and just took a short time in each bore.
