Author Topic: clutch adjustment tool  (Read 1029 times)
Offline cb
« on: December 10, 2016, 04:03:34 PM »
Has anyone seen a tool that fits what looks like a very large screwdriver slot on the crankcase cover?  If so, do you know where I can get one?
Offline Steve_K
Re: clutch adjustment tool
« Reply #1 on: December 12, 2016, 06:04:57 AM »
Possible, Snap On or Mac tool truck would have or order.  I have seen those slots on British and Japanese bikes, so they are out there.
McCarr MacMasters(not sure of spelling) carry all sorts of interesting things.
Steve
PS don't know if you might make one with some flat steel that fits the slot
Steve_K
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
« Reply #2 on: December 12, 2016, 08:40:11 AM »
+1. Those slots are usually radiused, so worth getting it as close as possible to get a decent purchase on it. Depending on size, I've fabricated 'special tools' for this type of application with nothing more than a suitably sized coin and a pair of Mole grips  :)
Build threads:
1977 CB750 F2
1958 Norton Model 99
Offline Old Scrambler
« Reply #3 on: December 12, 2016, 09:41:12 AM »
The factories made that slot so everyone would always have a tool to fit.............coins or circular spark-gap tools should already be in your pocket ;)
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline cb
« Reply #4 on: December 13, 2016, 08:40:19 AM »
Thank you everyone for your replies.  Right now I am looking for a large diameter washer which is also the correct width.   I am thinking that the difficulty I am having in turning this is due to an underlying problem with the mechanism.  Now I have to figure out how to take it apart and clean it and lube it.
Offline martin99
  • UK Based, Non-
« Reply #5 on: December 13, 2016, 01:16:18 PM »
Just out of curiosity (and you never know, someone here might have come across this before) - what bike are you working on?
Build threads:
1977 CB750 F2
Offline Flyin900
« Reply #6 on: December 13, 2016, 01:22:51 PM »
Just buy a large flat bladed screwdriver and grind the end so that the blade becomes thicker as you grind it down further. I bought one from a local Harbour Freight type store up here and it fits perfectly into the slot and works well. You can grab the metal shaft with a pair of vice grips to get some extra torque on the turning action if necessary.
If the part is seized into the case from non removal for a long time, it will be more difficult to remove it initially. Be careful hitting it too hard as that material is aluminum and can fracture and break if you are too aggressive.
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Offline wowbagger
  • Not much of an
« Reply #7 on: December 15, 2016, 12:47:17 PM »
I just use a large washer. I don't remember the exact size offhand but the curve of the washer and it's thickness were just about perfect.
Offline cb
« Reply #8 on: December 15, 2016, 05:42:50 PM »
Good Question; thank you.  a 1971 CB500 K0
