Author Topic: The little Ducati Featherweight  (Read 17231 times)
Offline jag767
Re: The little Ducati Featherweight
« Reply #50 on: January 09, 2017, 09:22:55 AM »
Here's  one i have of the piston, ill take more later.
Offline grcamna2
« Reply #51 on: January 09, 2017, 09:58:21 AM »
Nice piston design Jag  8)
Offline jag767
« Reply #52 on: January 09, 2017, 10:45:17 AM »
Lol that's original Borgo right there. Apparently they are bulletproof so i'm trying to leave it in there.
Offline grcamna2
« Reply #53 on: January 09, 2017, 02:23:13 PM »
What bore and stroke is it ?
Offline jag767
« Reply #54 on: January 09, 2017, 03:25:34 PM »
61x52
Offline jag767
« Reply #55 on: January 09, 2017, 06:12:18 PM »
Damn these motors are easy to work on. Compared to a Honda 4 of course. I ground down both halves of the bevel drive to fit with the milled barrel, and filed it square. What's the saying, close enough for jazz? It all went together nicely. One part down. I will pop the head back off tomorrow to find out if I can get it ported in a day, or if I'll just do it myself.
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #56 on: January 10, 2017, 09:52:07 AM »
  Sounding like this is gonna be quite a "Humdinger" of a ride, for sure.  ;D ;)
Member # 1969
Offline grcamna2
« Reply #57 on: January 10, 2017, 01:19:01 PM »
jag,
Does the bevel cam drive allow you to change the cam timing if wanted? or is it set-up w/ a key-way on the shaft ?
Offline jag767
« Reply #58 on: January 11, 2017, 12:54:21 AM »
jag,
Technically you can, but i've been told it's a horrible idea.
Offline jag767
« Reply #59 on: January 11, 2017, 06:28:01 PM »
Lots of boring things to report. Ordered new gaskets and orings from across the pond, and still waiting for parts from Australia. In the mean time, I had my machinist verify the cylinder was good to go, and there was no ridge from where the rings stopped travelling. The whole thing has a 1 thousandth v taper to it, but still all round, and will work just fine. Put it on and spun the motor around several times. I was happy to see the sleeve is clearing the con rod fine.
I spent some time on the bevel drive, trimmed 1.5mm out of each half shaft, and 1.5mm out of the housing. For those of you just checking out the build, this was to accomodate the 1.5mm removed from the base of the cylinder to bump up compression. At that point I removed the points side cover, verified the timing, and spun her over a bunch of times. Valves cleared just fine, as I was told they would. Now i'm down to boring stuff, removing 50 year old gaskets and the sort.  Once the new gaskets get here I will get them on asap. I know I've said it several times, but I love how simple this motor is to work on.
I will get a bunch of photos up soon, I know I've been lacking.
« Reply #60 on: January 12, 2017, 12:31:51 AM »
Its simple to pull the top end..
 Wait till you split the cases, or change a cam and have to shim bevel gears... Then you will miss the Honda 4..
 I split my Ducati case cases on my Mach 1 when I was 17 or so and got it back together..
 But i remember the special tools in the manual scared the crap out of me, and influenced my decision to sell.. That and the cracked head..
Offline jag767
« Reply #61 on: January 12, 2017, 03:38:37 AM »
Yeah the special tool part is a pain, and so are the shims, all different sizes, and on everything. But being able to get the top end apart and back together in 20 mins is awesome!
« Reply #62 on: January 12, 2017, 09:36:01 PM »
 Yup, cab off..pipe off, take out 4 bolts..lft of head then cylinder.. I liked that..no headgasket..
Offline jag767
« Reply #63 on: January 16, 2017, 12:06:16 AM »
Slight change of plans. With gaskets getting here Tuesday, ignition some time this week, and carb jets coming as well, rather than create more work, I'm going to start getting items checked off. This means for now the head will not be ported. It'll kind of wind up being a good thing, because now I will get to dyno it as a before and after. Stage 1 will be a mikuni 22mm carb, compression bumped up to 9.6 from 8.2, and free blowing exhaust. Stage 2 will be the ported head, and a 26 or 28mm carb.
For Stage 1, the Mikuni 22mm will start with a 100 main jet and 35 pilot. Best I can tell, that's about 1 jet size richer on the pilot, and 2 sizes larger for the main. I'll know quickly with the air fuel gauge how far off I am. My guess is with this setup, the motor will run quite well with nice lower end grunt, but the top end won't be impressive. Based on the riding I will be doing, sounds like a good place to start.
« Reply #64 on: January 16, 2017, 01:02:46 AM »
I hope you would hit any spots in the casting of the head that have debris or raised ridges Off and at least port match the intakes to the head and similar on exhaust side.  Really nothing like that little bit of work...
David
Offline jag767
« Reply #65 on: January 16, 2017, 05:09:08 AM »
The ports are actually very clean castings, as yes I'll open the lip to 23.5mm to match the carb, just not going past that.
Offline bill440cars
« Reply #66 on: January 16, 2017, 07:56:45 AM »
   I Know it has been said and I have even said it, But, This one Cool & Refreshing Build.  ;)
Member # 1969
Offline jag767
« Reply #67 on: February 11, 2017, 02:46:42 PM »
Ok big update, just no photos, I will work on that. 12v conversion is done, will button up the clutch tonight. The top end is all finished, shold run like a champ. All the parts are at the powdercoater, will have them back end of the week. Hoping to do final assembly next weekend, very very eager to ride.
Offline grcamna2
« Reply #68 on: February 11, 2017, 02:58:11 PM »
We may have an early Spring so it should be just in time.  :)
Offline jag767
« Reply #69 on: February 11, 2017, 03:19:24 PM »
Haha, I still have to repaint the gas tank, but that may wait!
Offline jag767
« Reply #70 on: February 12, 2017, 06:22:46 PM »
Motor is done, well other than the intake manifold
Offline CBGhia
« Reply #71 on: February 14, 2017, 01:09:11 PM »
That's purdy!
Offline bill440cars
« Reply #72 on: February 16, 2017, 03:11:08 PM »
That's purdy!
               I agree, That Is Purdy !!  ;)
Member # 1969
« Reply #73 on: February 16, 2017, 05:27:36 PM »
What can you say differently, it is pretty indeed...
Nice work Jag.
Offline jag767
« Reply #74 on: February 18, 2017, 07:07:49 AM »
Thanks guys, heres a bwtter shot. Still waiting on powdercoat..... never had to wait this long  :o
