Author Topic: CB125S O-ring Between Cylinder and Head Question  (Read 841 times)
Offline natez
« on: December 25, 2016, 02:26:54 PM »
When I tore my cb125s down, I removed the head and noticed that the O-Ring that goes around the locating stud/Cylinder stud on the forward/right cylinder head stud was missing, this was the first time I have tore this engine down so whoever did before me obviously left it out. (engine ran fine, no leaking at all without it)
On my new chinese 200cc cylinder, I noticed that there was no space for the o-ring like there was on the old cylinder...
So do I need that O-ring? do I need to have my new cylinder machined a bit or should I just put it together as is? Oil flows up that stud into the head correct?
See attached picture.
thanks!
Offline eigenvector
Re: CB125S O-ring Between Cylinder and Head Question
« Reply #1 on: December 25, 2016, 02:45:17 PM »
Yeah it's there for oil flow into the head.
Does it need the o-ring?  Hard to say, depends on how good a seal there is between the oil passage and the valve.  If you have the ability to machine a place for it - do it.  It's there for a reason.  Without the o-ring you might get oil leakage back down the passage and less oil up into the head.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
