Author Topic: Cb400f "goldie", Handbuilt show, Bikeexif, and dyno run.  (Read 79314 times)
Re: Cb400f Wiring and then first fire!
« Reply #500 on: June 27, 2017, 10:18:02 AM »
I think the last thing on earth I'd want under my ass is an Antigravity battery. I've seen many fires start because of those. Just a heads up.
I've run about eight of them with no problems.  Everyone ive heard of was caused by over charging it.  With the Rick's R/R I'm good there.
Most of those failures occurred because the bike had the stock regulator and rectifier and a short likely precipitated a runaway charge and explosion/fire.  You should be fine with a solid state R/R.  If you are that concerned about Antigravity as a brand, buy a Shorai.
Offline innovativems
    • Innovative MotoSports
« Reply #501 on: June 27, 2017, 10:34:56 AM »
I'm in the process of being a speed cell dealer so may swap it out down the road
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
« Reply #502 on: June 27, 2017, 10:56:32 AM »
Speed cell has really trick stuff. I spoke to them a year ago. They will essentially make a battery for your application -- and with a meter built in.  Mostly race-oriented applications, from what I understand.
« Reply #503 on: June 27, 2017, 10:56:28 PM »
Ya there stuff is top notch!
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
« Reply #504 on: June 27, 2017, 10:58:01 PM »
All components are mounted.  Glad I used to do car audio installs.  This wiring is tight on room but will look great once done.
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
« Reply #505 on: June 28, 2017, 07:08:31 AM »
I haven't seen that fuse block before.  Is it a conventional blade-style system or an electronic fuse system like the Motogadget?
« Reply #506 on: June 28, 2017, 07:47:10 AM »
It is made by Eastern Beaver and uses mini fuses.  I really like it.  Has two fused 12+, 6 switched, and 8 grounds.
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
« Reply #507 on: June 28, 2017, 08:04:08 AM »
Also got my plug lines installed.
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Offline parm94
« Reply #508 on: June 30, 2017, 12:53:39 AM »
Almost there... Can't wait to hear the growl of those pipes.
Offline calj737
  • I refuse...
« Reply #509 on: June 30, 2017, 01:00:26 AM »
Did you test fit your tank after locating the coils where you did? It seems to me that they will interfere with the tunnel badly.  :-\
« Reply #510 on: June 30, 2017, 06:36:57 AM »
Yes sir.  Fits like a glove.  Was a tight fit on height of the coils.  Reusing the original brackets put me right where I needed.
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
« Reply #511 on: July 02, 2017, 10:49:12 PM »
Finished ignition switch bracket and one for my gauge switch and headlight dimmer
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
« Reply #512 on: July 03, 2017, 09:16:51 AM »
What are the switch functions on the left?  Horn and hi-lo?
« Reply #513 on: July 03, 2017, 10:42:36 AM »
The left switch toggles between the functions on the tach/speedo and the the dial switch controls the output of the headlight
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
« Reply #514 on: July 03, 2017, 12:46:18 PM »
Holy crap. I thought you mis-spoke when you said headlight dimmer but apparently NOT. I don't think I've ever seen that before for a headlight.
« Reply #515 on: July 03, 2017, 12:54:15 PM »
Yeah it was really hard to find a led light that wasn't 5" deep with good output and a dimmer or high/low setting.  Clearwater has been making a few models for the adventure bikes and I'm very impressed so far. Gonna have to add a set to my ktm
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Offline palepainter
    • Mike Learn custom paint and airbrush.
« Reply #516 on: July 04, 2017, 06:37:22 AM »
This is looking so tight. It is one of those builds that has been educational and full of great ideas.
« Reply #517 on: July 19, 2017, 04:45:39 AM »
Finally wrapping up some customer bikes and got to the home stretch for wiring.  From the coil ground forward is done.  Also get setup with speedcell as a dealer and had to redo my electronics tray to account for the little bit of size difference. Also got my stator back from being rewound and rebuild my starter.
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
« Reply #518 on: July 19, 2017, 06:52:16 AM »
Is that one of the Speedcell units with a built in volt meter?
« Reply #519 on: July 19, 2017, 09:06:56 AM »
Unfortunately only the Baja battery had that. And it's quite q beast of a battery.
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Offline 540nova
« Reply #520 on: July 19, 2017, 09:12:12 AM »
A $20,000 CB400, I hope this is a labor of love.
Sent from my SM-G955U using Tapatalk
« Reply #521 on: July 19, 2017, 10:46:16 AM »
$20000!?  Oh man I hope not.  This has been a labor of love.  Just wait till I start my h2 build that is happening after this.  that one is going to make this one seem pretty boring I think.
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
« Reply #522 on: July 19, 2017, 11:14:41 AM »
Whatever the tally comes to, hide the receipts from the better half!
Offline 540nova
« Reply #523 on: July 19, 2017, 11:24:15 AM »
Whatever the cost, it's awesome. I know what I spent on my 450, so I can tell this build hasn't been cheap. Oh, well, it's only money. My employer gives me more every 2 weeks. .
« Reply #524 on: July 19, 2017, 11:28:07 AM »
I believe Speed Merchant and Suicide Machine still use those models on their flat track Hooligan race bikes.  I think that Jake Gagne uses the smaller Superbike model on his CBR1000RR in MotoAmerica racing.  Obviously, it helps when you are a sponsored rider and not just a customer.  I spoke to the guys at Speed Cell.  Super helpful -- they will build a battery to fit your parameters.  Not cheap, but killer stuff.
