Author Topic: Rocker Questions  (Read 1868 times)
Offline bambuhiphop
Rocker Questions
« on: December 30, 2016, 02:48:49 pm »
Happy New Year All
Was hoping to get some advice on some rockers. Goal is to get a set hardwelded for the new engine. I have two sets. One set is off a 75' and the other a 78'. 75' set are all very clean. Very light oil film on them and no pits. The 78' set is solid but 1 has a small pit and the oil on them is a little thicker and slightly burned.
Also, I am see degree(?) numbers on each of them. Not really sure if that effects which I should use. Set 1 have 83,85, & 86 markers and set 2 has 76 & 77.
Which set should I send out?
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: Rocker Questions
« Reply #1 on: December 30, 2016, 03:41:47 pm »
Those are likely casting numbers.
Are you getting a hardweld cam to go with the rockers?
I'd Send the worn and pitted set for hardwelding.  Keep the nice ones for stock rebuilds.
« Reply #2 on: December 30, 2016, 08:03:04 pm »
+1
Offline bambuhiphop
« Reply #3 on: December 30, 2016, 08:21:14 pm »
I have a billet yoshi cambin there already.
  • Holy Cow! I'm a
« Reply #4 on: December 30, 2016, 10:11:43 pm »
Yoshi?! Sweet!   ;D 8)
Offline bambuhiphop
« Reply #5 on: December 30, 2016, 10:23:45 pm »
Indeed. Picked it up off a fellow member, Greggo, few years ago. And actually Bill/BentOn Racing orginally purchased it back in 1985 on clearance. I found that out because he posted photos in a thread from 2009 and I recognized the box. Here is that thread. His mention of it is post 32.
http://forums.sohc4.net/index.php/topic,55272.msg598834.html#msg598834
It is a Isle of Man TT B grind. Never been used. Here is a recent pic of it in my engine I am building.
http://forums.sohc4.net/index.php/topic,86158.msg1867400.html#msg1867400
  • Holy Cow! I'm a
« Reply #6 on: December 30, 2016, 10:33:30 pm »
That's one hot lookin 550!  How does the yoshi iom cam compare to the stock?
Offline bambuhiphop
« Reply #7 on: December 30, 2016, 11:07:24 pm »
This is the info I have scrapped together on the Yoshi specs...
Int opens 27°BTDC
Int closes 57°ABDC lift 9.00mm
Exh opens 56°BBDC
Exh closes 27°ATDC lift 8.55mm
This is what I have found on a stock cam...
1.36 exh.       lobe              1.38 in.
1.110           base circle       1.110
0.252              lift              0.272
intake duration 240 ex 245.Intake lift .300 ex .280
Offline calj737
  • I refuse...
« Reply #8 on: December 31, 2016, 04:17:28 am »
I would confirm with Mike Rieck that the Yoshi cam is compatible with hard weld rockers. It is possible that the original cam is  a native grind, and not resurfaced (I haven't read Bll's linked thread).
Offline bambuhiphop
« Reply #9 on: December 31, 2016, 10:15:26 am »
Huh, hadn't thought of that in the slightest. I will reach out to Mike.
Offline bambuhiphop
« Reply #10 on: December 31, 2016, 01:48:31 pm »
Cal... I was hitting up the Google cave to see if I can find any info on this but am not. Could you elaborate on a "native grind"? Thanks
Offline calj737
  • I refuse...
« Reply #11 on: December 31, 2016, 01:51:55 pm »
Meaning that it wasn't hard welded/resurfaced from a stock blank to create a more aggressive profile. That is what the aftermarket cams are. I just don't know if the original Yoshi cams were that also.  :-\
Offline bambuhiphop
« Reply #12 on: December 31, 2016, 02:14:53 pm »
Ok, so meaning it is a blank itself (native) or hardwelded from another blank (resurfaced). What's the concern if is not resurfaced with hard weld rockers?
  • Holy Cow! I'm a
« Reply #13 on: December 31, 2016, 02:53:12 pm »
Hardweld rockers will eat a stock/native cam alive.  The softer material loses the wear and tear game.
Offline bambuhiphop
« Reply #14 on: December 31, 2016, 03:06:43 pm »
Huh. Makes sense. Can/Rocker interactions are still newer concepts for me. So, what are the rocket options available with the assumption the cam is stock/native?
  • Holy Cow! I'm a
« Reply #15 on: December 31, 2016, 03:34:53 pm »
Stock/NOS afaik
Offline calj737
  • I refuse...
« Reply #16 on: December 31, 2016, 03:36:48 pm »
Yup. Stock. Would ping Bill Benton or Mike Rieck about the cam to determine hard weld or not. They'll know. They know everything
Offline bambuhiphop
« Reply #17 on: December 31, 2016, 03:50:56 pm »
Cool, thanks for the info guys! Already pinged Mike. He'll get back to me in a few days. Always does.
« Reply #18 on: January 01, 2017, 01:38:06 pm »
Hardweld will work with iron cams......I have never had a problem and Megacycle says there is no problem. Use a zinc additive (ZDDP is what I use).
Offline bambuhiphop
« Reply #19 on: January 01, 2017, 03:47:44 pm »
Thanks Mike
