Author Topic: 627B Carburetors - Pesky Rubber Tubes Between The Carbs???  (Read 1137 times)
Offline b52bombardier1
« on: January 02, 2017, 12:16:12 PM »
Hello,
   I have read the Carb FAQ.  I have visited CB750carbs.com.  I have looked on You Tube.  What do those black rubber tubes between carb 1 & 2 and carb 3 & 4 do?  I'm guessing they are some kind of equalization or vent and I seem to remember reading that around here somewhere.  These rubber pieces have no part number listed on the fiche at CMSNL.
But here's the biggest question.  How are the rubber pieces replaced?  It would seem that the best way is to loosen carbs 1 and 4 to give a little slack to install the new rubber.  But is that the best course of action?
  How do you do this??
Many thanks,
Rick
« Last Edit: January 02, 2017, 12:33:06 PM by b52bombardier1 »
1971 School Bus Yellow Aermacchi H-D Sprint 350
1972 Candy Yellow CL100 K2
1972 Candy Jet Green Honda CB500
1973 Mighty Green ST90 K0
1974 Mars Orange CT90 K5
1975 Topaz Orange ST90 K2
1976 Shiny Orange CT90
2006 Honda Foreman 500 (restored)
Offline bomorr
    • sohc/4
Re: 627B Carburetors - Pesky Rubber Tubes Between The Carbs???
« Reply #1 on: January 02, 2017, 12:32:48 PM »
Hello,
But here's the biggest question.  How are the rubber pieces replaced?  It would seem that the best way is to loosen carbs 1 and 4 to give a little slack to install the new rubber.  But is that the b est course of action.
Many thanks,
Rick
You will need to disassemble the carbs from the mounting plate to replace the tubes. They are vents to equalize the carbs. There are a few good videos on YouTube on carb rebuilds: here is a pretty good one
« Reply #2 on: January 02, 2017, 12:51:52 PM »
I will watch that video and try to learn.  I only searched for CB500 and 550 carb videos, not anything for a 750.  I should'a broadened my search.
  Many thanks,
Rick
« Reply #3 on: January 02, 2017, 06:12:02 PM »
Wow . . . the Hackaweek Guy guy is really a joy to watch.  I have learned so much these last few hours.
Thank you very much!!
Rick
Offline bomorr
    • sohc/4
« Reply #4 on: January 02, 2017, 06:17:06 PM »
Yea he floats around this forum every once in a while and he did a great job documenting his builds, I believe that he took some time off to pursue other things after that bike build. I also learned a ton watching his videos.
Sent from my SM-G925V using Tapatalk
