Author Topic: 1978 CB550 Carb Diagram  (Read 14909 times)
Offline Jkstull
Re: 1978 CB550 Carb Diagram
« Reply #50 on: January 04, 2017, 05:16:00 PM »
But you mean these, right? They're for the idle mixture. I'd leave everything standard.
Yes, that is the needle I was talking about. Not the needle in the slide. Is there a certain depth that should be at?
Sent from my SM-G935V using Tapatalk
 If you have a '77, factory setting is 2 turns from lightly seated. The '78 used 1.5 turns. You have pods so be prepared to experiment.
 On the PD carbs those screws are on the engine side so they control fuel. The more you turn them out, the more fuel...Richer... You'll get.
Okay. This thread is starting to give me a real good understanding of my machine. Big thanks to everyone with the patience to stick around. Is all of this laid out in the links provided? I haven't had time to do much research on said links. Unfortunately work gets in the way of that.
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #51 on: January 04, 2017, 06:17:12 PM »
I think he meant some people would say yes to your original question, and others would say no. Meaning we don't really know. Lol.
Exactly. Kind of like arguing over what the best electronic ignition is. Everyone has their favorite-
Theoretically, the earlier year carbs would run better given their lack of EPA intervention on exhaust emissions. Also, the earlier year carbs can be tuned more easily, and across a wider range. So in effect, one should be able to extract more horsepower from the engine. But this is all subjective and I have no evidence from side-by-side Dynos runs for multiple year bikes in equal condition with stock systems.
And all of this is superseded by the fact that everyone knows Flake Sunrise Orange bikes are fastest. And Planet Blue Metallic the slowest-  ;D
You're trying to tell me those traffic cone lookin supersports are faster than me and my friend bloo?!?!
Its candy sapphire blue too.  Like a stripper  ;D
« Last Edit: January 04, 2017, 06:19:13 PM by BomberMann650 »
Offline Jkstull
« Reply #52 on: January 05, 2017, 06:45:28 AM »
Okay. I've been looking for a match on the screws for my choke linkage. I'm coming up short, and I've emailed harisuluv and haven't gotten anything back. The manuals show part numbers for the screws on a 1977 K4, but not a 78. Can anyone help me out? The 78 seems to be off the grid in many ways...
Offline Scott S
« Reply #53 on: January 05, 2017, 09:45:24 AM »
 What's the part # for the '77?
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Fezzler
« Reply #54 on: January 05, 2017, 05:55:07 PM »
True?  I'm about to buy a 1978 CB550 Four K4.  Are they different and unique and under documented?
1975 Honda CB550f in parts in progress
1978 Honda CB550 Four K4
1971 Honda CB500 Four K0
2008 105th Anniversary Edition HD Road King
(Sold) 1998 Honda Shadow ACE Deluxe VT750
1973 Schwinn Stingray (Blue Deluxe - RIP Jack and Rose)
Offline harisuluv
« Reply #55 on: January 05, 2017, 05:57:02 PM »
i have all the screws.  you need the 8 screws for the butterflies?
  • Holy Cow! I'm a
« Reply #56 on: January 05, 2017, 06:35:29 PM »
From what I've seen, the 78 k bikes underwent a few cosmetic changes.  Seat, sidecovers, and the tank looks like they put decals on a supersport F tank.  They kept the popular 4into4 pipes and pd carbs.
The model guide;
http://www.sohc4.net/cb550-model-guide/
Offline Jkstull
« Reply #57 on: January 05, 2017, 07:32:30 PM »
Yes I do! I messaged you earlier. I can't find them anywhere else.
Offline Deltarider
« Reply #58 on: January 06, 2017, 07:15:00 AM »
Were there certain years that outperformed the others because of these subtle changes?
As a matter of fact: yes. The CB550F and the CB550F1 performed best. Although the CB550F2 had the same 069A carbs, Honda must have changed something. The German press complained about less driveability in comparison with previous models and showed that also the older CB500K2 (G) that had been tested in 1976, perfomed better (see pic. below*). Must have something to do with the new regulations I guess. Remember that the CB550F2 was on the market in the same period as the CB550K3 with even leaner PD carbs, so probably the setting was somewhat adjusted. The only thing I've found is that some carb scheme's show an advised airscrew opening that went from 11/2 (CB550F and CB550F1) to 13/4 (CB550F2) but I don't know if that was the cause and if not there were other things.
* 'Beschleunigung' means acceleration and 'Höchstgeschwindigkeit' means topspeed. Source: Motorrad 18/1977.
« Last Edit: January 08, 2017, 09:48:34 AM by Deltarider »
CB500K2-ED Excel black
  • Holy Cow! I'm a
« Reply #59 on: January 06, 2017, 10:19:06 AM »
I was really impressed by those zero to 60 times, then i realized it was kilometer scale haha!
Offline Jkstull
« Reply #60 on: January 16, 2017, 07:07:55 AM »
Hey harisuluv, did you want to work something out for those screws?
