Author Topic: 1974 Rickman-Honda 750 CR replica/tribute  (Read 31528 times)
Offline kosmjon
  • Software is my job; building bikes is my passion.
Re: 1974 Rickman-Honda 750 CR replica/tribute
« Reply #50 on: January 11, 2017, 08:52:16 AM »
The .120 DOM for the swingarm will be plenty strong without added bracing, unless, you are going nuts on the HP. 0.120 walled tubing is about 2x thicker than stock and the modern steels are far stronger than 40 year old stuff.
For the frame, definitely stick with 0.065 DOM tubing. DOM is substantially stronger than regular ERW steel, and approaches non-normalized chromoly for strength. Its not quite there but closer to CrMo than it is to ERW. Its a solid choice for strength and ease of welding.
Not sure what diameter your swingarm tubing is, but on a Seeley swinger for instance, the tubing is pretty thin wall (like an 0.085-ish), but is like 1-3/8" or so, making it light and strong. The 0.120 is probably overkill, but you likely won't notice a real weight penalty, only a bit more stiffness, which isn't a bad thing.
I really appreciate these recommendations guys!  I was mainly guessing on wall-thickness and erring on the overkill side.
« Reply #51 on: January 11, 2017, 10:16:34 AM »
 I would not use that fixture for a swingarm, looks flimsy, lke stuff can move and pull.
Do you have a buddy with, or access to a milling machine ?
Offline kosmjon
« Reply #52 on: January 11, 2017, 10:50:46 AM »
I might.  Assuming yes, and we could machine up some kind of fixture -- what should it look like ?
Offline kosmjon
« Reply #53 on: January 11, 2017, 10:54:42 AM »
Getting ready to pull trigger on tires. Someone mentioned the 4.10 Dunlops would be a tight fit in front and they are a bit wide for a WM2 rim.  One source I have says the front was a 3.50x18.  Can anyone confirm if the front was 3.50 or 4.10 ?
« Reply #54 on: January 11, 2017, 02:13:56 PM »
I like to see something more positive to locate the parts and prevent movement.
Fist off determine if you wil, use the fixture again for another arm or different arm, then you want length/width adjustability.
 The pivot tube, i would probably use blocks that are bored to fit the pivot bolt, then fit to a keyway or pinned in place with dowels., try to prevent movement while welding.
 The way it is in the pics, it looks like the pivot tube can get pulled over while tacking.
 I am not a welder, but i would tack everything first, then wel part of the tube to pivot,then jump to the other side..alternate back and forth.
If you have the elements of the fixture high enough like 1.5 inches of the plate, or cutouts in the plate...you can probably weld 3/4 of the weld before, turning the part over to finish
« Last Edit: January 11, 2017, 02:19:27 PM by 754 »
« Reply #55 on: January 11, 2017, 02:34:47 PM »
I did say stitch weld.. I am aware of the gas issues.
 If the fixture element are say 3 inches above plate, you can get pretty far around, but sometimes cutouts will help.
In the pic he shows, I am thinking they tacked heavily..everywhere, then removed arm to finish weld (probably. Kept a tube and bolts between axle plates). This then is followed, by checking and probably a straightening operation......its probably most time effective if only doing one or two pieces.
Offline Steve_K
« Reply #56 on: January 12, 2017, 09:33:22 AM »
I am not a welder, but I have made fixtures that needed welding to complete.  That said, the shop I was working at had several welders,  but only one who knew how to weld with minimal distortion.  That man made my job much easier to get the fixture so it was straight.   A good welder is a good thing.
Steve
Steve_K
« Reply #57 on: January 12, 2017, 10:53:40 AM »
I hung around a few expert welders heavy on the tig, that passed on a lot of tips..
 I always try to suck up some knowledge so to speak..
 Some pretty cool stuff people are building out there...
« Last Edit: January 12, 2017, 07:15:52 PM by 754 »
Offline kosmjon
« Reply #58 on: January 12, 2017, 01:10:58 PM »
I appreciate all the great tips guys.  I surely would've missed the vent holes.  I have seen them my stock frames and swingarms over the years and never really thought about what they were for.
Tips on securing the parts during the entire welding process make a lot of sense as well.
I have only 4 years of on-and-off welding experience using my Eastwood Mig 175.  I feel I've gotten better over time, but this will be a real test.  I would love to use this project as a reason to add a Tig welder, but I've not sure my budget will allow it plus I'd be starting over my welding learning curve all over again.  I will take my time and I think all will turn out OK.
Offline kosmjon
« Reply #59 on: January 12, 2017, 01:12:15 PM »
My copy of the Rickman assembly manual has arrived. As I suspected it has lots of great exploded parts diagrams and parts lists which will help a lot.
Offline slikwilli420
  • Master of Disaster
« Reply #60 on: January 12, 2017, 03:53:39 PM »
That may be the best road map for this project you can get. Which one do you have? Honda or Kaw? Which forks are shown on the cover and on the front end section?
Offline kosmjon
« Reply #61 on: January 12, 2017, 03:54:49 PM »
It is the Honda one and it also looks like it covers triumph is well
« Reply #63 on: January 12, 2017, 05:39:58 PM »
Love that Rickman bodywork.
« Reply #64 on: January 12, 2017, 07:21:14 PM »
Looks like its got the 1 5/8 fork on it, as did the OP,s bike...... Hard to find
« Reply #65 on: January 12, 2017, 08:01:58 PM »
Yeah I noticed that to frank. Remember there were 4 versions of front ends. The 38mm and 1-5/8 forks with single and dual disc. Either dual disc front seems far rarer. Wonder the cost difference?
Offline Scott
  • 72 CB750
« Reply #66 on: January 13, 2017, 10:35:13 AM »
Hello
When it comes time to buy body work, I have used airtech and was very happy with them.  The guy is very easy to talk to and really wants to help.  He goes through it carefully with you on the phone and then gave me little discounts from their listed price.  I think he even sold me the pingle fuel taps for half price. I think I saved about $200
He also put me in contact with the screen manufacturer and organised it to come in the one delivery from air tech
I haven't fitted the body work yet but it all looks good.
Scott
Offline kosmjon
« Reply #67 on: January 13, 2017, 10:42:07 AM »
Hello, When it comes time to buy body work, I have used airtech and was very happy with them.  The guy is very easy to talk to and really wants to help.  He goes through it carefully with you on the phone and then gave me little discounts from their listed price.  I think he even sold me the pingle fuel taps for half price. I think I saved about $200
He also put me in contact with the screen manufacturer and organised it to come in the one delivery from air tech I haven't fitted the body work yet but it all looks good.
Scott
  Wow, thanks this is great news. I was hoping that since the total was gonna be ~$1500 they'd work with you a bit.  About how much was shipping (for my budget planning purposes.) You have a thread going on this build, I presume?  I will seek it out.  Buying of all this will have to wait until I sell another bike.  Actually, this one to be specific.  After I give the wife her cut to help pay for my shop, I should have enough to pull the trigger on these parts.
« Last Edit: January 13, 2017, 10:45:21 AM by kosmjon »
« Reply #68 on: January 13, 2017, 11:32:52 AM »
Airtech makes some nice stuff. I bought the full fairing, seat and inner fender for mine. I think I might cut down the full fairing to be more of a half fairing style, but that is yet to be determined. I personally like the steel tank with cover model of tank, which is what I have.
Offline kosmjon
« Reply #69 on: January 13, 2017, 12:16:57 PM »
I didn't know they offered a inner metal tank with cover option. That does sound like a safer way to go for the street.
Do you happen to have a  link?
And also I thinking ahead to ordering some aluminum plate.  Can you tell me the width of the following parts (if you have them):
Rear brake bracket: looks to be 5/16 or 3/8
Front brake bracket (welded? bolted? to front fork)
Speedo / tach bracket: looks to be 1/4 or so
Taillight / License plate bracket: looks to be 3/16 or so.
Thank you!
« Reply #70 on: January 13, 2017, 12:30:47 PM »
The front brake bracket is cast into the fork, they are very scarce. Betor made them for Rickman .
 I lusted after that fork since 72 , i finally started to build a sort of replica, using 41 mm leg assemblies.
 That would be ok if you build trees to suit..but, I got lucky and found Rickman trees, and fit the 41 mm to it but had to use shims . Rickman is 1 5/8 which is about 13 thou bigger than the 41 mm
Here is a pic, but I am keeping it for now..
« Last Edit: January 13, 2017, 12:32:45 PM by 754 »
« Reply #71 on: January 13, 2017, 12:39:20 PM »
The only 1 5/8 source that comes to mind is HD wide glide. Not the best performance.
The other alternative, maybe a bit easier to find is the 38 mm Rickman fork.
 Meanwhile if you can find any AP calipers grab them , you need at least a pair. Early PM look close if you luck into some used ones.
« Reply #72 on: January 13, 2017, 01:27:25 PM »
Do you happen to have a  link?  Classic motorcycle fiberglass in Australia is the only one I have found that makes covers, but they do have them in both long and short versions. The steel tank beneath is crude at best and the one I have is from the original kit. I have seen people who have done one-offs of them, but they were aluminum. Here is the original long steel version: http://s986.photobucket.com/user/seamussam/media/DSCF3983-1.jpg.html
Rear brake bracket: looks to be 5/16 or 3/8 - its either 1/4 or 3/8. The one I did for another guy doing a Rickman was 1/4, seen here: http://s225.photobucket.com/user/chuck_lambert78/media/Rickman-CR-underslung-bracket-C.jpg.html
Some that I have seen are a doubled up version like this: http://s5.photobucket.com/user/sickbouy/media/005_zpsed97b146.jpg.html
Mine on my kit is this style without the holes: http://lookoom.fr/HR2/wp-content/uploads/2015/06/Honda_CR1060_Rickman-05.jpg
Speedo / tach bracket: looks to be 1/4 or so - no clue
Taillight / License plate bracket: looks to be 3/16 or so. - no clue
Thank you!
I would also be happy to help make the parts for you as well, just let me know.
« Reply #73 on: January 13, 2017, 02:04:51 PM »
 What I found handy for aluminum fab was two get 6 in flat bar rather than plate,
if you can buy small quantity, always pieces on the net.
 2 feet each of 1/4 in. 3/8 in, and maybe 5/16   will get you thru most project stuff.. not sure about rear brake bracket, fitting on 6in.
 If you are adapting stuff like brake calipers on the front, you will need thicker but milling is also usually involved.
6061-T6 is what you want. You can cut most stuff out on a small bandsaw if 6 inches wide, but plate will get hung up, then you need a skilsaw.
Offline Scott
  • 72 CB750
« Reply #74 on: January 13, 2017, 11:51:51 PM »
Scott
Shipping I'm not too sure as it was about 6 months ago and  I had one box sent straight to Australia and I had the other box sent to LA to come over with a couple of bikes in a shipping container.  I would be about 99.9 percent sure the dude who answers the phone at Air tech (Walter maybe) would be more than happy to have a chat and help you with your budget figures. I really think he is a very good bloke.
I got both the full fairing and the short fairing to give me options of having it look how it should look with the full fairing and then maybe using the half fairing with some handle bar risers and new bars for a touring Rickman that won't hurt my back.
I don't have a thread on my Rickman build but I do know that it is about the slowest build in history.
