Author Topic: 1974 Rickman-Honda 750 CR replica/tribute  (Read 31065 times)
Offline kosmjon
  • Software is my job; building bikes is my passion.
Re: 1974 Rickman-Honda 750 CR replica/tribute
« Reply #75 on: January 30, 2017, 10:38:15 AM »
What I found handy for aluminum fab was two get 6 in flat bar rather than plate,
if you can buy small quantity, always pieces on the net.
 2 feet each of 1/4 in. 3/8 in, and maybe 5/16   will get you thru most project stuff.. not sure about rear brake bracket, fitting on 6in.
 If you are adapting stuff like brake calipers on the front, you will need thicker but milling is also usually involved.
6061-T6 is what you want. You can cut most stuff out on a small bandsaw if 6 inches wide, but plate will get hung up, then you need a skilsaw.
Good tips for sure - thanks.  Looks like closest Metal Supermarket near me is in Tampa (~4 hour drive).  I have a HF portable bandsaw that I built a stand for and it works pretty well but has a small throat area to fit pieces into.  I have a woodcutting Craftsman bandsaw that someday I want to build/find a speed reduction for.
Offline kosmjon
« Reply #76 on: January 30, 2017, 10:48:06 AM »
Shipping I'm not too sure as it was about 6 months ago and  I had one box sent straight to Australia and I had the other box sent to LA to come over with a couple of bikes in a shipping container.  I would be about 99.9 percent sure the dude who answers the phone at Air tech (Walter maybe) would be more than happy to have a chat and help you with your budget figures. I really think he is a very good bloke.
I got both the full fairing and the short fairing to give me options of having it look how it should look with the full fairing and then maybe using the half fairing with some handle bar risers and new bars for a touring Rickman that won't hurt my back.  I don't have a thread on my Rickman build but I do know that it is about the slowest build in history.
Thanks for the additional info.  Sold another bike http://www.ebay.com/itm/292002689853 so I was able to call Airtech and talk to Walt and get my order going.  As you said Walt was a great guy to deal with and treated me right on the pricing.  It will take 2-3 weeks to build the parts and then 4 days shipping from CA.  Very excited!  Walt also gave from the link for the windscreen which I purchased separately.  My spokes and Borrani rims should arrive this Wednesday from Buchanans.  Job and life has been getting in the way of making actual progress other than buying parts.  Hopefully that will change soon.
« Last Edit: January 30, 2017, 10:53:06 AM by kosmjon »
Offline slikwilli420
  • Master of Disaster
« Reply #77 on: January 30, 2017, 11:37:43 AM »
Glad to see you are still chipping away at some big pieces of this build. What are you doing about forks/brakes?
Offline kosmjon
« Reply #78 on: January 30, 2017, 01:13:57 PM »
Yes indeed! Big and expensive!  I see a Lockheed caliper (from a Triumph) on ebay right now that might work on the front. Otherwise I'll buy a pair of AP Racing Lockheed-style calipers and a master cylinder for the rear from http://www.clubmanracing.com/discsystems.php  In the interest of time/money I may try and modify the stock Honda 35mm forks to work by welding on a front caliper mount and replacing the bottom studs with bolts.  Of course I know this is less than ideal and am open to suggestions.
« Last Edit: January 30, 2017, 01:23:48 PM by kosmjon »
« Reply #79 on: January 30, 2017, 02:43:34 PM »
Stock triumph units are steel and very heavy so I would steer clear. The aftermarket AP units are what you need.
Welding forks has been done by others with varying degrees of success. Considering its a brake related component I wouldn't trust it. You can try a fork like the GL1000 which is closer to rickman size and is much easier to adapt a caliper to. See my AHRMA racer thread to see the finished product.
« Reply #80 on: January 30, 2017, 04:36:53 PM »
Metal Supermarket will probably ship for reasonable cost.
 Yeah the Triumph caliper would be real heavy, even an AP is not super light and its aluminum. They have the look, they are the right stuff.
« Reply #81 on: January 31, 2017, 10:23:31 AM »
Going to need these. Only one in the auction but you need to start somewhere and this is a good price.
http://www.ebay.com/itm/132075013638?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Too bad this guy wont ship to the US because here is the setup right here:
http://www.ebay.co.uk/itm/Lockheed-Front-Adj-Master-Cylinder-and-2-x-CP2696-2-pot-Calipers-New-/272526325121?clk_rvr_id=1161439472384&rmvSB=true#shpCntId
« Last Edit: January 31, 2017, 10:29:31 AM by slikwilli420 »
« Reply #82 on: January 31, 2017, 11:21:45 AM »
That first one, must have the brakeline go into centre of caliper ? Must be a tapped hole in the shadow.?
« Reply #83 on: January 31, 2017, 11:35:36 AM »
What do you mean Frank? Like where the line goes in? The bleeder should be in the other side, but I suppose you could run the feed line and bleeder in either hole.
« Reply #84 on: January 31, 2017, 11:56:44 AM »
Not seeing the inlet, maybe looking at wrong side,  most have the inlet coming in same way as the bleeder.
Goid selker btw , bought from him before..he gets very cool stuff..
« Reply #85 on: January 31, 2017, 12:18:36 PM »
In the picture in the listing, the inlet is where the bleeder is at. The bleeder actually goes in the hole on the back half of the caliper but the threads are the same so you could use either hole as feed or bleeder.
Offline MikeSimon
  • MotoManiac
  • Motorcycle Addict
« Reply #86 on: January 31, 2017, 02:00:16 PM »
This is probably not relevant and has already been dismissed in theory by the experts, but there are a huge variety of classic Honda forks available in different sizes for little money, which all have standard dual calipers and nice rotors: 35mm, 37mm, 39mm and 41mm.
1973 CB350F -sold
1974 CB350F -218 orig miles, sold
1976 CB750K - in restoration
Other Hondas:
3 x CBX
CB1100R
GB500
Plus Kawasakis, BMws & Ducatis
« Reply #87 on: January 31, 2017, 03:41:36 PM »
The forks aren't as big a deal but a proper rickman should have AP calipers.
Offline MikeSimon
  • MotoManiac
  • Motorcycle Addict
« Reply #88 on: February 03, 2017, 11:50:09 AM »
Here are a few more Rickman pictures. The Honda CR appeared for sale first at VMD in 2006 and last in 2014, so I thought. Closer look, however, shows the bike seen in 2013 was different and the 2006 and 2014 were different bikes also.
« Last Edit: February 03, 2017, 11:52:57 AM by MikeSimon »
1973 CB350F -sold
Other Hondas:
3 x CBX
CB1100R
GB500
« Reply #89 on: February 03, 2017, 10:31:50 PM »
Okay, not a CB750 or a Honda, but a regularly tracked Rickman Kawasaki owned by Yoshi of The Garage Company.
« Reply #90 on: February 03, 2017, 10:34:58 PM »
Ooooihhhb 41 mm fatfork and Morris wheels.. Nice.
Got a side view ?
« Reply #91 on: February 03, 2017, 10:48:07 PM »
Got a side view ?
I took the photo above at Yoshi's Corsa Moto Classico
The one below I found on the Interwebz
Here are more details:
1975 Rickman framed, 74 Kawasaki Z1 900 engine race/street monster.
74 Kawasaki Z1 900 engined race/street monster. APE big bored to 1065cc, factory close ratio transmission, racing alternator, total loss ignition with dyna coils. Keihin CR 39mm smoothbore carbs. Rickman racing forks and triple clamps, works performance shocks. Lockheed racing master brake cylinders to brembos, 4pot front, 2 pot rear. Cal-fab swingarm, aluminum gas tank, Earles oil cooler, lots of custom billet aluminum bits like rearsets, mounts, etc.
http://www.garagecompany.com/4racer.html
Offline MikeSimon
  • MotoManiac
  • Motorcycle Addict
« Reply #92 on: February 04, 2017, 06:57:21 AM »
The Rickman Kawa in my post is a nice large sideview
1973 CB350F -sold
Other Hondas:
3 x CBX
CB1100R
GB500
Offline Zunspec
« Reply #93 on: February 23, 2017, 01:47:50 AM »
Hi kosmjon,
This just popped up on UK Ebay:
http://www.ebay.co.uk/itm/genuine-rickman-honda-cr750-/381976532467?&_trksid=p2056016.l4276
Posted for your inspiration, but if you want to buy it and keep it in my garage until you can collect I'm happy to oblige  ;D
Good luck with your build.
Cheers  Geoff
« Reply #94 on: February 23, 2017, 02:00:52 PM »
You could use it as a reference tool!
Offline Hondadave01
« Reply #95 on: February 23, 2017, 04:51:49 PM »
Can anyone help me, I have a 1963,64,or 65 Honda ca150 benly touring that I would like to rebuild, can anyone tell me where I can download a repair manual?
Thanks you
Offline Scott S
« Reply #96 on: February 23, 2017, 05:32:24 PM »
Thanks you
 Hey Dave. You might have better luck starting your own topic. Try the "Other Bikes" section here. This thread is about the Rickman's and your post might get lost in the shuffle.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline kosmjon
« Reply #97 on: March 07, 2017, 08:34:41 AM »
Hi kosmjon, This just popped up on UK Ebay:
Good luck with your build. Cheers  Geoff
Ha, that would be nice, eh?  Looks like no takers on that one.
BTW, thanks for all the recent pics and links.  I've been a bit side-tracked with honey-do tasks and other stuff.  I have sold 4 bikes since 1 Jan and have raised a good bit of capital for buying the remaining parts needed for this Rickman-Honda replica.
To assure you there is life in this project, look what arrived today by FedEx from Airtech Streamlining in CA:
Parts look amazing and Airtech did a wonderful job.  I had already received the windscreen from Gustafsson Plastics (who knew they were just an hour away in St. Augustine.)
Probably won't get a lot done until April at rate things are going, but I it is nice to have all the fiberglass on site now.
« Last Edit: March 07, 2017, 11:15:05 AM by kosmjon »
« Reply #98 on: March 07, 2017, 09:00:24 AM »
Nice glass pieces.  I assume you will line the gas tank with an epoxy (like Caswell) to resist against the effects of ethanol-based fuels.
Offline Zunspec
« Reply #99 on: March 07, 2017, 10:40:51 AM »
The quality of the body work looks A1, great when your project receives significant parts and you can begin to see what it might look like.
Cheers  Geoff
