Author Topic: Who makes an alloy standard style 1.60x18" rim to fit my CB400F front ?  (Read 1287 times)
Offline grcamna2
I've been looking for an alloy front rim for the 75' CB400F 1.60x18" that has the same style(non-shouldered)and spoke pattern as my oem steel chrome rim.
I will consider a 1.85x18" alloy for the front after having exhausted myself looking for a 1.60
« Last Edit: January 11, 2017, 02:05:21 pm by grcamna2 »
Offline innovativems
    • Innovative MotoSports
Bucannon's and I believe mikesxs do
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Offline 540nova
Sun, Excel, and DID, available at Buchanan's, among other places.
Offline grcamna2
Re: Who makes an alloy standard style 1.60x18" rim to fit my CB400F front ?
« Reply #3 on: January 11, 2017, 03:31:30 pm »
I want one for less than $100 if possible.My main concern is the spoke pattern match the angle of the hub size on the 75' CB400F.
Offline sxs
« Reply #4 on: January 11, 2017, 03:37:50 pm »
X2
Offline grcamna2
« Reply #5 on: January 11, 2017, 05:30:19 pm »
X2
Do you mean Yamaha ?  please clarify
like a mikesXS front rim for a disc brake XS650? was curious if that would have the same size hub as the CB400F w/ similar spoke angles? only those are 19" and I want an 18" front rim..
« Last Edit: January 17, 2017, 09:25:21 am by grcamna2 »
Offline grcamna2
« Reply #6 on: January 17, 2017, 09:20:35 am »
bump
Mikesxs is the cheapest
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Offline Bodi
« Reply #8 on: January 17, 2017, 10:04:02 am »
I think pretty much any 18x36 rim made for a disc brake front hub will work fine. The angle change would be very slight between the hub flange diameters commonly used. You should only have problems trying to use a drum brake drilled rim on a disk hub (or the reverse).
I would tend to go a size wider though - finding tires (decent tires at least) that are sized for a 1.6" rim is not so easy.
« Reply #9 on: January 17, 2017, 10:41:40 am »
I got cb400F rims from yamiya.
If you love it, set it free, if it stays it's probably one of my 750's.
Offline grcamna2
« Reply #10 on: January 17, 2017, 11:52:45 am »
Don,
Were you able to find an alloy 18" for the front of your CB400F ?
Offline grcamna2
« Reply #11 on: January 27, 2017, 12:21:10 pm »
Don,
bump.
 Did you find an aluminum 1.60x18" rim from yamiya ?
