Author Topic: CB750 Automatic kickstart lock nut  (Read 2727 times)
Offline hondamad
« on: January 14, 2017, 12:56:33 AM »
Anyone with a picture or drawing for the lock nut on the kickstart lever?
Sent from my iPad using Tapatalk
Offline jonnycakes
Re: CB750 Automatic kickstart lock nut
« Reply #1 on: January 14, 2017, 04:11:43 PM »
Its a bolt with a spring loaded center.
'Matic-Fanatic
Offline hondamad
« Reply #2 on: January 16, 2017, 02:56:16 AM »
Thank you , regards
Offline kac3177
« Reply #3 on: January 16, 2017, 04:10:50 PM »
my first kick start was missing the bolt. I was able to use a replacement oil drain plug from the hardware store to serve same purpose. I carefully ground a nipple on the end to which is the part that "locks" it in. I can send you pictures I you want me to.
kac3177
Offline jonnycakes
« Last Edit: January 17, 2017, 05:39:11 PM by Jonnycakes »
'Matic-Fanatic
Offline hondamad
« Reply #5 on: January 20, 2017, 09:43:46 AM »
Would appreciate it , thanks
Offline kac3177
« Reply #6 on: January 23, 2017, 07:08:22 AM »
The one on the left is the homemade version versus the one on the right that is OEM. Carefully ground, chased the threads after. Works good however I had to add a 13mm wrench to the tool kit. It is a functional, affordable replacement.
kac3177
Offline hondamad
« Reply #7 on: January 24, 2017, 05:30:06 AM »
Works for me , thank you
