Author Topic: 76 CB 550 directionals  (Read 1464 times)
Offline Maltieri12
« on: January 19, 2017, 02:45:39 PM »
I'm new to the forum! I'm working on a 76 cb550 for my first ever cafe racer conversion.  I bought after market directionals that are 2 wire and I hook them up the same way the oem 2 wire directionals were, but the new ones don't flash. When I activate the signal, they light up but then just stay on and don't flash. They're attached the same way as the oem ones. Any suggestions?
Thanks.
Online BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: 76 CB 550 directionals
« Reply #1 on: January 19, 2017, 03:43:23 PM »
Welcome to the forum.
Double check the wiring diagram.  The proper colored wire with the wrong ground connection will cause that issue, as well the improper color wire with the right ground.  (Happened to me)
You may also have to swap the winker relay to suit the wattage of the new lamps.
Offline Deltarider
« Reply #2 on: January 19, 2017, 11:44:53 PM »
Originally your model had duplo (dual filament) bulbs in front to function both as indicators as well as running lights that were useless btw. I don't know about US bulbs, but here a suitable bulb would be the 21/5 Watts duplolamp that we use as tail/brakelight. So if you're gonna use them as indicators only (wise!) you'll need a simple (single filament) 21 Watts or 18 Watts bulb. Anyway, make sure those running light wires (orange/white (left) and lightblue/white (right)) do not make contact with the bulbs + pole. You haven't picked LED indicators, have you? Check your wiring scheme. Is yours a CB550K or CB550F?
« Last Edit: January 20, 2017, 12:14:07 AM by Deltarider »
CB500K2-ED Excel black
Offline Maltieri12
« Reply #3 on: January 20, 2017, 06:24:39 AM »
Thanks for the response.  The bike is 76 CB550F.  They are not LED, they are incandescent,I believe 12v and 10w.  I wired the rears just the same as the stock lights. (1 power, 1 ground).  I've read some different info talking about relays?  Really new to all this and figuring it out as I go! Thanks for the insight.
Offline Deltarider
« Reply #4 on: January 20, 2017, 06:47:28 AM »
Ten Watts will not be enough. You need 18-23 Watts each to make the winker relay work.
Offline Maltieri12
« Reply #5 on: January 20, 2017, 12:12:43 PM »
Thanks everyone for the help. An EL-12 2 prong electronic relay solved the problem!
« Reply #6 on: January 20, 2017, 01:02:18 PM »
Flashers, but no running lights....right?
Where's Duanob!?!?! ;D  :-X
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #7 on: January 20, 2017, 01:19:19 PM »
Hey I'm here. Maltier12 hit me up via PM. I have what you need.
Honda front winkers use a three wire system. You need a special harness with directional diodes to make aftermarket two wire flashers work. I put Triumph Bonnie flashers on my bike because I liked the way they look and had to make something up to make them work properly. I have a few extras I made up.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
« Reply #8 on: January 20, 2017, 01:28:42 PM »
Yes.  These are good  8)
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #9 on: January 20, 2017, 01:50:42 PM »
Thanks for the kudos Rob!  :D
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
  • Holy Cow! I'm a
« Reply #10 on: January 20, 2017, 06:04:42 PM »
Whats this about diodes?  K or F model harness?
Online Don R
« Reply #11 on: January 20, 2017, 08:03:24 PM »
 I think he got it working.
  • Holy Cow! I'm a
« Reply #12 on: January 21, 2017, 09:37:39 AM »
Haha yup
