Author Topic: '72 CB750K1/2 First time project  (Read 5963 times)
Offline MadDogCanada
« on: January 23, 2017, 07:01:58 PM »
I picked up a bike and frame, no history on it, missing lots of part non runner.  This is the test bike to learn how everything work, Make it into Frankenbike since there's so much missing. doing it on the cheap to get it back together and running down to work and back, 25km
Here's some pics of what I'm dealing with.
My first question is, the broken bottom case bolt hole, is it fixable? will it piss out oil or cause serious problems down the road other than look ugly!?
I already got a line on a top case without broken fins.
So the biggest question is.. where do I begin? what to check first to see if it's worth salvaging the engine or loooking for a replacement power plant..
Thanks,
M
cb750 K2:Fraken bike project
CB750C 1980. resto project
Offline timbo750
Re: '72 CB750K1/2 First time project
« Reply #1 on: January 23, 2017, 09:27:21 PM »
I can't actually tell which bolt it is thats broken but generally it can welded up and then use a file to reshape.
Does the engine turn over? If its not siezed then its a good start.  How far you pull apart one of these depends on 3 things, how much patience you have, how much mechanical skill you have or are capable of learning and what is the end result you are looking for. There is also money but generally if have a desire for it you will find a way to fund it.
« Reply #2 on: January 23, 2017, 10:04:15 PM »
hey timbo,
Its the bottom right front bolt hole on the crank case.
I've got the time and the desire, and a lil bit of mechanical skill...I've managed to keep three bikes on the road for years. Time to test the skills and learn a bit more....  I am economical and practical, so I wont replace things just so that they are new. but change things that need to be done.
PLus it's expensive as hell getting parts in Canada, between the exchange rate, shipping costs and border taxes...
I'm thinking of starting with the top end checking gaps and rockers and cleaning up the gas tank since it's caked in bondo.
« Reply #3 on: January 24, 2017, 06:42:15 PM »
here's a better picture. I'm a bit annoyed I didn't notice this before buying it.
Anyone got an opinion if this will be a major issue or how it's fixable thx.
Plan on bench testing the bike this weekend.
will check top end gaps,rough balance the carbs and chuck some oilfuel in it and see where it leaks... from everywhere most likely.
Feel free to post any comments or tips.
Offline timbo750
« Reply #4 on: January 24, 2017, 08:14:38 PM »
That is critical, it is actually one of the main bolts that keeps the crank torqued up and place. I would not suggest running the engine with that in that state. It can fixed but most likely not with out pulling the engine apart. It also looks like there is crack travelling upwards as well. Does the engine turn over by hand?
« Reply #5 on: January 24, 2017, 08:44:10 PM »
Yah can't believe I didn't see it. Or that the guy didn't at least warn me... I'm thinking jb weld. And Helicoil may do the trick.  Don't know if I want to pull everything apart for something that can be fixed.... but it'd be a learning experience.
How would you fix it?
Offline timbo750
« Reply #6 on: January 25, 2017, 03:17:38 PM »
That bolt is about 6 inches long so the thread should be fine. I have used JB weld on a few things but have also found a better option for this sort of thing. Get some 'Sun Fix' its 2 part and stiff to start with and guaranteed to dry rock hard, just make sure the case is spotless and free from any oil or grease residue, it is also better on a rough surface.
« Reply #7 on: January 26, 2017, 05:55:33 PM »
Step  2!
took engine out and put on a table with support brackets! i only took out two long engine bolts. isn't there three?  and I don't trust the two that were in there.
anyone know the sizes, lengths and proper placement of the long engine mount bolts.?
Here's a pic of my work bench.
So i'm checking the top end, gaps then starting to look at the carbs.
just want to hear it cranck over and see what I'm dealing with and see if I need a full rebuild or just a different engine!
Any advice or tips on things I should check before cranking it over? ALL tips Welcome!
Offline BPellerine
« Reply #8 on: January 27, 2017, 01:17:46 PM »
cant see if you have an oil tank hooked up,but if you are going to turn it over with the starter,it might be a good idea to hook it up and run some oil through it,you will be able to see if oil is reaching the top end,also I think you would only have to remove the lower case half to get that welded it looks like,lots of good welders in alberta I would think.bill
1978 CB 750K ard and webers
another anfob
« Reply #9 on: January 27, 2017, 01:51:49 PM »
Just so you know,
Three long bolts hold the engine in plus a few shorter ones
Of the long ones two have a bolt head and are I think 10 mm.
The other is I think 12 mm, and has thread on both ends, its lwer rear mount, and holds the footpegs on. Very often one end is bent, mostly still useable, but do not try to pull bent end through the motor.
« Reply #10 on: January 28, 2017, 04:22:35 AM »
still hooking things up.  will get the oil tank on. and use the kick start to get some oil going through things.  need to do a compresion test and set the carbs up.
SO I'm missing tht 12mm bolt... any Idea how long those bolts are?
Where in Canada do you guys get your parts?  Gaskets, carb kits?  engine parts.
trying to find stuff local to canada and not pay US prices, transport and border taxes.
hope to have this putting by Sunday.
Any other tips before I crank it over? feel free to share.
thanks
« Reply #11 on: January 28, 2017, 06:39:06 PM »
so I've  gone through the valve clearances, most were pretty good, think I got them to spec. did cam chain tension. didn't notice any movement or change from before or after,  a tiny bit of play on rear of chain when at TDC, but tight to sprocket. the Manual wasn't much help.
So it's time to check out the electrical system. Never worked with points before so looking that up. pics and label of wires where they are on the bike. I'm thinking of minimizing the wire harness.  engine, headlight turnsignals and make it a kick start.
First things first, hook up wires to engine out of frame and see what happens.
Checking the points now, look decent enough. new battery but will get a smaller 8 cell Lith battery, or see if i can do it without a battery!? as my buddies trying to get me to do.\
let u know how it all goes.
« Reply #12 on: January 28, 2017, 08:14:20 PM »
It always needs a bit of juice to start.
Do you ever get to CowTown ? A buddy may have a 73 motor available later this year. He knows where a guy had 3 motors foe salem they were outside.. He did not check them over.. I am trying to get him to go check them out in the next few weeks.
 What you really need is cases, or lower end and at least a head.....correct ? If you cant find a complete motor..
« Reply #13 on: January 28, 2017, 08:21:35 PM »
That'd be pretty cool man keep me posted. It'll depend if this thing turns over or not. May need the whole thing.
What frame kits do you do?
Offline timbo750
« Reply #14 on: January 28, 2017, 08:43:49 PM »
Franks frame kit works well, I can vouch for itt, easy to use and no welding.
« Reply #15 on: January 28, 2017, 09:29:38 PM »
I will be back making frame kits soon.
It allows you to cut the two lower frame rails under the tank, then remove the section to access topend in the frame. Then it clamps rigidly back in place.. Without having to weld  sections into the frame to allow that. The brace section has a bolt in element, that ties that back together.
« Reply #16 on: January 29, 2017, 01:14:23 PM »
yah I'v seen those around. makes taking of valve cover a bit easier, is there a bolt on hoop for the seat frame with that?
« Reply #17 on: January 29, 2017, 01:32:21 PM »
No bolt on hoop..
« Reply #18 on: January 29, 2017, 01:42:28 PM »
This engine is fighting me every inch of the way. I went to torque on oil drain plug and found it striped oh and no washer. The PO has screwed everything up that I've looked at so far.
The  bolt looks decent so thinking it's the inside threads....Will try and get a bolt to test it out. but there goes my plans bench testing this engine.
But I have always wanted to learn to Tap out holes.. s i'm staying positive.
Offline BPellerine
« Reply #19 on: January 29, 2017, 02:05:49 PM »
sorry it is going badly!
another anfob
« Reply #20 on: March 29, 2017, 09:22:01 AM »
 Looks like there may be at least the parts you need ora motor available in Calgary for you , either a 73 or 72.. Pm me if you need more info.754
« Reply #21 on: August 13, 2017, 07:14:53 PM »
Thx man any info would be good. Stripping my bike down into bits to ship... Any tips on what to take or leave behind to save on cost...
Sent from my SM-A520W using Tapatalk
« Reply #22 on: August 13, 2017, 08:04:52 PM »
My welder (he's a good aircraft-certified welder guy) would fix that bolt tower up for me in an hour and charge me $40 in the end.
The fins would be a little more (probably $60-$80), but do-able: the hard part is in taking the time to file them down to look like the others. It takes about an evening for me to do 2 fins.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #23 on: August 14, 2017, 09:25:26 AM »
For a start on what parts are and what they look like you can go to the Yamiya web site
http://www.yamiya750.com/
They have the pictures and sell a lot of the parts you will need.
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #24 on: August 14, 2017, 05:56:34 PM »
I'm tearing the engine apart to salvage as much as I can. And ditch the case. Any parts you think are more important than others. I.e. Rare /hard to find/expensive... I got limited space to ship...
