Author Topic: K3 Project has now started.  (Read 40732 times)
Re: K3 Project has now started.
« Reply #200 on: September 12, 2017, 04:23:15 PM »
Hey Steve....Bud is going through a rough time. Look here...
http://forums.sohc4.net/index.php/topic,168084.0.html
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #201 on: September 12, 2017, 09:08:07 PM »
Got it,thank you for the information. I'll need to think of something to contribute.
Getting ready to assemble cases. Letting the paint cure up some. Set up the fastener map, crude but serves the purpose. I'll be checking O rings and dowels next.
I used to live in Key Largo in the late 90's. We were always worried about the big one, which they just got, while there we rode out a few Category 1 and 2 storms. We did ok but I always thought it could get very bad if luck ran out. The folks down there have a tough road ahead, just like Budman.
All the best, and Aloha
Steve
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #202 on: September 13, 2017, 09:46:09 PM »
What's everyone using for wheel weights?
I'm not to crazy about flat stick on ones, they don't seem to secure. I guess I'll get some old lead ones?
Also, the 4 into 2 exhaust is up for grabs, not sure what shipping would've from here. It's in pretty good shape.
1973 CB 750 K3
Offline budman
  • 1914X
    • LeCompte Electric Bass
Bud
1973 CB750K3 Chopper (in pieces)
« Reply #205 on: September 14, 2017, 07:08:04 PM »
Budman
I was worried about you, aren't you near Houston? I hope all is well with you and yours.
I'm now going to lay things out and get ready to assemble the cases, with Hondaman's book at my side.
Steve
Bump me with any questions! ;)
I'm just getting back into the garage, back's doing pretty well. Do you want the parts back unpainted, so you can match them to yours?
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #206 on: September 14, 2017, 09:27:14 PM »
Mark
Yes, unpainted, thank you
Steve
1973 CB 750 K3
« Reply #207 on: September 15, 2017, 07:51:48 PM »
Okie-doke!
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #208 on: September 15, 2017, 10:26:07 PM »
My gasket set did not include the o ring for the oil passage, argggh. I ordered some from Grainger. Waiting.........
1973 CB 750 K3
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #209 on: September 17, 2017, 06:47:53 PM »
Aloha all
Bonehead question, I failed to take note when I disassembled the oil tank lines.
When assembling the lines to the tank, there is a rubber washer and an aluminum washer.
Am I correct in assuming the rubber goes against the tank flange and the aluminum is on the oil line side?
Thank you
Steve
1973 CB 750 K3
« Reply #210 on: September 18, 2017, 06:44:37 AM »
Aloha all
Hey Steve....I just installed new lines on my K4 last month, I dont recall a rubber washer?
Have you looked at the fiche?
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #211 on: September 18, 2017, 09:04:13 AM »
Good question. I've been looking at the parts pictures on line and the printed one I have. They seem to omit any mention of the tank end of the hoses. Yamiya sells a "set" that includes the aluminum and rubber washers. I purchased it. I just sent them an inquiry about it, we'll see what they say, they've been good about things like that.
I've been spending time putting together "sub assemblies" so that when the time comes there will be smooth sailing getting the bike together. Amazing what you find, there is always something that needs to be worked on or purchased.
I just learned that Hagon shocks no longer has their US office in California. Everything is out of the U.K. Now.
1973 CB 750 K3
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #212 on: September 19, 2017, 08:22:34 AM »
Oil Tank oil lines
Yamiya confirms that their oil line kit assembles rubber washer goes against the tank and the aluminum washer is against the oil line. I'm going to search through my parts to see if I took a rubber washer out, I don't recall.
1973 CB 750 K3
« Reply #213 on: September 19, 2017, 06:13:16 PM »
Got the cylinders back today, inscribed the cylinder number on each piston so they don't get mixed up. I hand-finished the pistons, will get it boxed up tomorrow for the return trip. The head is still in the shop: he broke his .260" valve guide rod in his valve machine last week and the new one isn't here yet. :(
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #214 on: September 19, 2017, 10:03:36 PM »
Great news!
I'm waiting for o rings to assemble the case.
Thank you
1973 CB 750 K3
« Reply #215 on: September 20, 2017, 03:55:43 PM »
I sure don't recall any O-rings in the oil lines at the tank(?). There is a soft aluminum washer there. I'd suggest leaving the nut loose on the line at the bottom of the tank, so you can more easily align it when the hoses are in place with the engine.
I just sent the cylinders, will PM with details.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #216 on: September 20, 2017, 04:06:59 PM »
Mark
Thank you. I think I will leave out the rubber. I remember now that there were none upon disassembly.
Good news on cylinders.
I checked my rocker shafts, they have about 0.0004" wear, out of round. The oil holes line up well with the 5mm bolts installed. Should I seek new ones? If I did find new ones I might leave out the 5 mm bolts.
Steve
1973 CB 750 K3
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #217 on: September 20, 2017, 04:09:56 PM »
Mark
Will I be using my old valve springs?
Steve
1973 CB 750 K3
« Reply #218 on: September 20, 2017, 08:36:54 PM »
Mark
Steve
I'd just flip the rocker shafts over, if worn a little on their bottom sides. That much wear isn't very significant, so long as the oil grooves show in the rocker's oiling holes.
I'm planning on re-using the springs, at this point. Very little wear or collapse in any of them. If you'd like extra performance from them, I could have them sand- or bead-blasted for you? This extends their life somewhat, mostly. It doesn't alter how they work.
In fact, this might be a good time for an old 'theory moment: in one of my favorite history books, "Ford: the first 100 years", there was a pointer to a story I researched and found to be very cool, regarding valve springs. In the beginning of the internal combustion engine, the #1 problem was the life of valve springs: they were measured in less than 100 hour increments. Henry Ford decided he wanted to solve this industry-wide problem and put one of his oldest and practiced machinists on it, all day every day, testing different springs and revising them. Then, one summer, a particular spring ran longer by 10-fold than any other spring, and Henry, who checked this project every 2 weeks himself, had the machinist trace the spring's history to find out what was so different about it. The machinist had kept complete records, and discovered that when it went to testing, it was a little rusty from sitting and waiting its turn, so he sandblasted it clean first. Within 3 weeks after that, they developed the technology now known as 'impact destressing', or today, "bead blasting", as it relieves all the surface stress lines in steels and other materials. All such springs are heated, wound, ends machined flat, and bead-blasted with tiny steel beads to make them last thousands and thousand of hours....because someone took a minute to 'fix up' something that wasn't quite right...
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #219 on: September 20, 2017, 09:48:39 PM »
See? That's why we do these projects, not because they are vanity projects or nostalgic macho excursions or ways to spend too much money on an old motorcycle, but because it's so educational!!
Actually, even though I spent many hours and miles on my K0 back in the day, I've learned more than I ever thought I would on this project. I'm used to pretty complicated stuff (nuclear submarine propulsion is an example), I'm impressed with how elegantly simple and robust the details are of the 750. It's a joy to work on. I'll be happy to get it on the road and be able to ride it and pick up my wood work again but I'm having a lot of fun with it all apart in the work shop. I'm fortunate to have a large garage to do the job in.
If I do another one I think I would look for a 400F
O rings came in but not the ones I need right now. I got the o rings for the engine side of the oil lines, if anyone needs a pair I have 50. Minimum order from Grainger. There aren't any good sources of o rings here on Maui. Still waiting for the oil gallery o rings, I'll have 50 of those too.
Steve
1973 CB 750 K3
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #220 on: September 20, 2017, 09:49:58 PM »
Oh, and I think we can leave the springs alone, I'm not racing or anything.
1973 CB 750 K3
Offline my name is nobody
  • I like Pontiacs and Hondas
« Reply #221 on: September 21, 2017, 07:14:05 PM »
The smaller of the 2 o rings that come with new oil filters also fit the bottom end of the oil hoses@ the engine IIRC.
They will also fit  (3 required) the collars where the oil pump mounts. There are aluminum washers for the top
threaded connectors of the hoses @ tank connections (at least 1) that I remember. You may want to check inside the threaded couplers to see if the old ones stayed with the hoses.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #222 on: September 21, 2017, 07:33:10 PM »
 Thank you, they are new hoses.
This is a great forum
Steve
1973 CB 750 K3
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #223 on: September 21, 2017, 09:47:01 PM »
Ok, my o rings got here, the ones for the dowel between the engine cases. Time to get busy. I have 49 extras if anyone needs one.
Also, Hagon shocks arrived, no idea how they got here so quickly from the U.K. Sure will be nice to try them out, still lots to do.
1973 CB 750 K3
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #224 on: September 21, 2017, 09:53:06 PM »
Body and cover are stainless, good for Maui environment, less rust to worry about.
1973 CB 750 K3
