Author Topic: K3 Project has now started.  (Read 34588 times)
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: K3 Project has now started.
« Reply #325 on: February 19, 2018, 06:09:25 PM »
This has nothing to do with my K3 but I had to post.
We had snow on Haleakala today, at 10,000 feet.
Also had a cool sunrise yesterday.
Sorry to be so off topic.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #326 on: January 04, 2020, 05:31:24 PM »
1973 CB750 K3
New wiring harness, Hondaman fuse block, fresh battery kept on a battery tender.
Finally getting to look at my electrical bug
When I turn on the ignition the dash lights are dim and it won't turn over.
I was able to jump start it and only saw 6 volts at the battery at high RPM, about 3000.
Won't idle at all, likely due to low voltage.
When shut down, the battery shows 12.4 volts connected or disconnected.
I checked the diodes in the modern regulator/rectifier, they check ok.
I checked the stator, it checks ok. No shorts to ground or each other.
I also noticed that with the ignition on and nothing else being done, the regulator rectifier sings just sitting there, it has a whine. That doesn't seem right.
Any ideas?
1973 CB 750 K3
