Author Topic: K3 Project has now started.  (Read 40747 times)
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: K3 Project has now started.
« Reply #50 on: June 28, 2017, 10:00:36 PM »
Test
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #51 on: June 28, 2017, 10:05:57 PM »
Some of my attempts to post have not worked for some reason.
Today's progress:
Wheel bearings taken apart, fought me all the way. Nuts were difficult.
Forks apart. Only 3 ounces of very dirty oil, yikes.
Steering head apart, condition ok, I'll still be putting in tapered rollers.
Engine taped up for some cleaning.
Discovered why it seemed to be sluggish, in addition to the carbs needing work. The gearing is 18/45.
1973 CB 750 K3
Offline budman
  • 1914X
    • LeCompte Electric Bass
« Reply #52 on: June 29, 2017, 06:34:43 AM »
18/45? Probably do 150, but take you a while to get there.
Bud
1973 CB750K3 Chopper (in pieces)
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #53 on: June 29, 2017, 09:19:17 AM »
Yes, the gearing also puts the engine at a disadvantage around town. I will go back with 17/48 and 102 links of 530.
1973 CB 750 K3
Offline budman
  • 1914X
« Reply #54 on: June 29, 2017, 01:27:07 PM »
I'm pretty sure the stock setup was 18/48 with a 100 link 530 chain.  Are you sure you want 102 links with a 17T front sprocket?
Bud
« Reply #55 on: June 29, 2017, 03:32:53 PM »
17/48 was stock for early models, 18/48 after K2?...not sure about that.  17/48 works great and is what I choose to put on all my 750's.  I rarely ride on the freeway.  Doubt there is much reason to ride on the freeway where you live.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #56 on: June 29, 2017, 04:39:51 PM »
Yes we have no bananas, I mean Interstates. Most speed limits are 45, a tiny bit of 55, lots of sub 45. We've had a MiniCooper since 2012 it now has 40,000 mikes. The cars computer says average speed, all miles, is 25. I need around town gearing.
As for 102 links, if there is room in the adjustment, it would put the rear wheel a little farther back. Bad idea?
Maybe it won't work and I should stick to 100 links.
Thank you for the sage questions, well done.
Steve
1973 CB 750 K3
« Reply #57 on: June 29, 2017, 05:10:02 PM »
Bike will turn a little quicker with the back wheel all the way forward,  ala 100 link.  Plus get more chain life before you run out of adjustment.
« Reply #58 on: June 29, 2017, 05:57:57 PM »
Is the Road to Hana as fabulous as they say? I've been to Hawaii but only Oahu.
Offline budman
  • 1914X
« Reply #59 on: June 29, 2017, 08:03:54 PM »
Yes, but it's a slow drive (ride).
Bud
« Reply #60 on: June 29, 2017, 10:21:52 PM »
Really slow, but that's kind of the point.  Take your time, stop by a turn off and hike, etc.  Make a day of it.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #61 on: June 29, 2017, 10:29:10 PM »
I just tried to post and it dumped it again, I think it's the photos, I think I'll only do a few at a time.
The road to Hana is a real treat. Very slow, lots of blind corners and one lane sections. Many unscheduled closures due to rock falls when its wet, which is a lot of the time. I retired from H DOT, I managed the State Highway road maintenance on Maui, Lanai and Molokai. The road to Hana ate up more budget per mile than any other.
Worth the trip.
My wheel bearing retainers all gave me fits. I will be getting new ones.
Tried out my ultrasonic cleaner and simple green. Wow, great results, I will post a few photos.
On the main stand, right side, under the bolt, there is a washer with a extra hole, does anyone know what it's for ? Pictures coming, one per post.
Thanks for comments.
Steve
1973 CB 750 K3
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #62 on: June 29, 2017, 10:30:28 PM »
Main stand mystery washer
1973 CB 750 K3
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #63 on: June 29, 2017, 10:31:30 PM »
Ultrasonic stuff
1973 CB 750 K3
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #64 on: June 29, 2017, 10:32:26 PM »
More
1973 CB 750 K3
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #65 on: June 29, 2017, 10:34:57 PM »
Brake panel before
1973 CB 750 K3
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #66 on: June 29, 2017, 10:36:17 PM »
After Simple Green and vibes
1973 CB 750 K3
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #67 on: June 29, 2017, 10:38:25 PM »
Could the mystery washer be where the battery vent needs to be?
1973 CB 750 K3
« Reply #68 on: June 29, 2017, 10:42:56 PM »
Worth the trip.
Steve
Steve,
Where on the island are you located?  I've been vacationing there since I was a young kid (my father was an airline pilot), and we had friends who lived in Paia, Pukalani, Makawao and Kula.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #69 on: June 29, 2017, 10:57:14 PM »
We are in Kihei in an area called Keonekai Heights. About .5 miles from the water and well out of the tsunami flood zone :-)
Great weather here in Kihei.
1973 CB 750 K3
Offline my name is nobody
  • I like Pontiacs and Hondas
« Reply #70 on: June 30, 2017, 03:55:21 AM »
That is correct sir. Maybe a label on the frame somewhere (right rear?) showing correct routing of the tube
Offline Sigop
« Reply #71 on: June 30, 2017, 04:38:59 AM »
Could be for routing a tube, but I seem to remember a Hondaman post a couple weeks ago that the early K3's had a solenoid with the four posts all coming out the top, and some bracket, or something, that was for mounting a switch? down near the kickstand. My memory is lame but I know it was Hondaman.
FWIW.
CB750 K3  Original Owner and Operator
« Reply #72 on: June 30, 2017, 07:12:44 AM »
Nice.  We used to have a condo on the north side of the island in Honokawai.  Maui is one of my favorite places in the world.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #73 on: July 02, 2017, 12:20:51 PM »
Does anyone have a good photo of what the inner rear fender tabs look like when they are not bent? I think I know but a photo would be great.
Thank you
Steve
1973 CB 750 K3
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #74 on: July 03, 2017, 09:43:07 PM »
I'm getting some cleaning done as I prepare to take the top end apart. Happily, steering stem races, swing arm bushings and steering head races came out with little effort. Lucky.
I am using the ultrasonic cleaner for anything that will fit in it. It seems to loosen paint fairly well, not sore if it's the Simple Green, the vibrations or both.
I think I need fork tubes. One has some pretty bad grooves and of course the rust up around the headlight ears.
More to come.
1973 CB 750 K3
