Hey guys,
Just wanted to run an option by you for my first build. I'm pretty far into it, subframe is cut up and I'm about to get a new rim/spokes for the rear wheel. I put a brand new wheel on the front (see picture, 17"), and I have a brand new 150/70-17 tire lined up for the back.
1) My question is, since I want a slightly more aggressive rake/stance towards the bike, do you think it would be beneficial to run an 18" back there, or would sticking with the 17" be conducive, and weld the subframe accordingly to obtain the correct rake (have Cognito led hoop with upsweep). I know it's a bit hard to picture without picture of the frame, I'll try and attach one as soon as I can.
2) Secondly, I made a mistake in ordering a 36 hole hub for the front, and then realizing the rear hub is 40 hole, the mix-match of spokes won't be an eyesore/noticeable will it?
Any/all opinions welcome,
Thanks guys!
