Author Topic: CB836 - Oil line routing  (Read 2339 times)
Offline dakota
« on: January 25, 2017, 11:10:13 AM »
Hi all,
I am busy preparing a cb7550 f2 1978. I have installed a dp836 piston kit, webcam 41, ....
I have also installed a oil cooler.
I have put 4 litres oil in the tank, but when I rev up to 6000rpm, there's not much oil coming back into the tank.
Are the oil lines okay?
Regards,
gp
Offline slikwilli420
  • Master of Disaster
Re: CB836 - Oil line routing
« Reply #1 on: January 25, 2017, 11:13:48 AM »
Your pictures dont even show everything hooked up. The return line does not even have a fitting on it. Post an updated pick with all three lines installed.
Offline Lammers000
« Reply #2 on: January 25, 2017, 02:14:17 PM »
What sort of oil cooler are you running? I'm doing a similar build, and looking for a good cooling setup right now. Thanks.
Be an Engineer they said. It will be fun they said.
Offline Old Scrambler
« Reply #3 on: January 25, 2017, 03:19:31 PM »
Tank to oil-pump in sump........filter adapter return feeds to oil-cooler..........then cooler to oil-tank.  What is the line on the right side of the motor for?
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline Bodi
« Reply #4 on: February 05, 2017, 04:01:32 PM »
The pump feed should not go above the tank to avoid airlock. The pump is not so efficient at pumping air. You should have a free gravity feed to the pump.
Offline Haybus
« Reply #5 on: February 06, 2017, 12:58:11 PM »
Can't see the feed line, but it's probably just hidden in the 2nd picture. The plumbing looks the same as mine, except my cooler lines are above the cooler. I remember it taking awhile to fill the cooler and lines before seeing much flow back into the tank. Might be worth rigging up a pressure gage to make sure the pump is supplying decent pressure. Mine runs at a 70-80psi.
Alan
75 CB750
76 KZ900
Online MRieck
« Reply #6 on: February 06, 2017, 04:14:54 PM »
What size hose is that.....-8 , -10?
