Author Topic: Big Ouch!  (Read 4490 times)
Offline kmb69
Big Ouch!
« on: January 26, 2017, 09:08:23 PM »
How not to remove a stuck CB1100F cylinder!  :(  :'(
Offline scunny
  • don't call me expert
Re: Big Ouch!
« Reply #1 on: January 27, 2017, 12:39:09 AM »
WD40 then the buff, good to go. WTF happened there ?
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Re: Big Ouch!
« Reply #2 on: January 27, 2017, 03:15:11 AM »
I see two 550 twins there, what seems to be the problem.... :P
Offline MoMo
  • Ride like you're invisible
Re: Big Ouch!
« Reply #3 on: January 27, 2017, 05:00:55 AM »
never been a situation JBweld can't cure.    What happened?
Re: Big Ouch!
« Reply #4 on: January 27, 2017, 05:42:05 AM »
Suppose to inject the nitrous in the cylinders, not the crankcase!
Re: Big Ouch!
« Reply #5 on: January 27, 2017, 05:52:20 AM »
 Cal or Frank can weld it good as new !!
Re: Big Ouch!
« Reply #6 on: January 27, 2017, 05:53:01 AM »
Wow....
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=f8fvcctstj8lreh84sop4d4vj1&/topic,60973.0.html
Re: Big Ouch!
« Reply #7 on: January 27, 2017, 07:53:28 AM »
did your toolmachine take damage...this is not a vay to use  it..heat and hard hammering.. vill loose the rust not a torque pull..---
i hate all this v-w.... vords
Re: Big Ouch!
« Reply #8 on: January 27, 2017, 09:44:25 AM »
You need to find a new machinist Leroy  ;)
Offline kmb69
Re: Big Ouch!
« Reply #9 on: January 27, 2017, 09:52:56 AM »
Well......First time in my life I have ever seen such a thing!  :o
A design flaw by Honda in my humble opinion. The 4 studs between 1-2 and 3-4 have openings in the head that allow water/debris to collect at the cylinder level with no way to drain or flush. After 34 years, the cylinder can become bonded, like ONE, to those 4 studs. This particular one sat in Aero Kroil for over 3 months. It would not budge. I was able to remove all the other studs - no problem. I tapped 1/2-20 threads in all the surrounding cylinder holes. Then put set screws in the case threads. Started cranking down on the 1/2-20's till it let go and boy did it! Hard to imagine just how much pressure was applied but it was obviously a lot.  ;)
Machine tool all OK. I was using a tooling plate made for SOHC cases to hold it. Rather expensive workbench but solid. But the machine tool is the answer for the next one that's stuck. Need to saw those 4 studs off close to the head and machine them out completely. Fixing to break tear disassemble another one today and see what we get. The center 2 studs between 2 and 3 had no support under them and I am somewhat concerned that the cases on this one could have been cracked/damaged in the process.
You should see the contraption the guys down in NZ use for this problem. However, I seriously doubt it would have worked on this one.  ???
« Last Edit: January 27, 2017, 09:57:13 AM by kmb69 »
Offline kmb69
Re: Big Ouch!
« Reply #10 on: January 27, 2017, 11:04:23 AM »
Great advice! Thanks, Spanky  ;)
Re: Big Ouch!
« Reply #11 on: January 27, 2017, 11:14:03 AM »
  Same problem a lot of guys run into on the Suzuki GT750 Water Buff trying to pull the cylinders with corrosion on the studs etc., though I have not seen one break but there is a plate that can be made to force them off. Pretty fragile around the cam chain tunnel apparently, sorry that it happened to you. Hopefully a replacement won't be too difficult.
Re: Big Ouch!
« Reply #12 on: January 27, 2017, 12:06:24 PM »
Water buffalo, yep same problem..
Massive rust on them two studs on the leftt..
Offline Desert-SOHC
  • It's old
Re: Big Ouch!
« Reply #13 on: January 27, 2017, 01:14:28 PM »
that sucks
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
Re: Big Ouch!
« Reply #14 on: January 27, 2017, 02:42:37 PM »
Well, heat the cylinders until they drop the liners and then put it in the scrap aluminum recycling pile along with that bottom case set...
Scrappers should give you about $0.50 for it
Offline eigenvector
Re: Big Ouch!
« Reply #15 on: January 27, 2017, 04:46:54 PM »
Man that would really ruin my day.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
Offline kmb69
Re: Big Ouch!
« Reply #16 on: January 27, 2017, 05:02:15 PM »
Yep, the liners are salvageable. Cases may be OK too - fingers crossed. The cleaned up top case fits nicely on it's mate. All but the 2 center studs, that flap in the breeze, were solidly supported over the mains. Gotta do a dye penetrant on the top to make sure no cracks.
Gonna send a couple sets off to Nils to get vapor blasted and then do the DPI. A bit worried the vapor blasting might hide any cracks due to the microscopic peening. What ya'll think?  ???
It did, but nobody got hurt so we live to fight another one.  ;)
Offline kmb69
Re: Big Ouch!
« Reply #17 on: January 27, 2017, 05:05:21 PM »
Any body got a good CB1000C or CB1100F cylinder for sale?
Offline Bill/BentON Racing
    • BentON Racing
Re: Big Ouch!
« Reply #18 on: January 28, 2017, 10:10:00 AM »
LMAO,  good one Jerry, seems I'm not z only one capable of breaking things! Lol, Damn Keith, you just had to outdo me...haha, think you mighta come close! At least mine was IC !!!!! Wow ;D, Bill
BentON Racing Website
BentON Racing Facebook
Re: Big Ouch!
« Reply #19 on: January 28, 2017, 11:08:42 AM »
Anyone try using parrafin wax to see if the hot wax would get enough penetration to do its job?  Would be difficult to immerse it in a pot of hot wax, not mention take a heck of a lot of wax...  But a bake in the oven and melting the wax from the heat and feeding/ applying as much as it would take might allow you to have it suck more wax inside. Heat it up apply, bake some more, apply, repeat.....
Offline Flyin900
Re: Big Ouch!
« Reply #20 on: January 28, 2017, 07:22:06 PM »
I will check if I still have a CB1000C set of barrels still in the garage attic? They would need to be bored at a minimum or the cylinders replaced as the motor had 75K kilometers or 50K miles and the cylinders will be worn with that mileage.
I wouldn't want much for the barrels although am in Canada and shipping will be expensive.
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Offline kmb69
Re: Big Ouch!
« Reply #21 on: January 29, 2017, 12:44:01 PM »
Sounds good. Already planning to replace the sleeves. Pretty sure the 1000's and 1100's started with the same cylinder casting. Need to make sure they are the ones without air passages between 1-2 and 3-4.
Offline Flyin900
Re: Big Ouch!
« Reply #23 on: January 29, 2017, 04:38:11 PM »
Just sent you a PM and will look tomorrow and send you some pictures of them for reference. I know they do have the same openings between cylinders that catch the dirt and grit on the case studs that you encountered. I didn't have a huge issue in removing them though from what I recall I was able to split at the upper case and pry up and remove.
Offline kmb69
Re: Big Ouch!
« Reply #24 on: January 29, 2017, 07:16:35 PM »
Replied to your PM. Yep, they are not always a bugger, but they can be if they experienced the right (wrong) conditions in life.
