Author Topic: Hondamatic top end upgrade choices  (Read 3362 times)
Offline Kongamatic
« on: January 31, 2017, 09:53:39 PM »
Hi there,
I've read the topics on hondamatic performance upgrades and besides the round top carb upgrade I've also decided to upgrade my 1976 hondamatic with stock parts from a none hondamatic motor (pistons,head and cam). On a budget so I figure since I have access to 2 good top ends I could increase my compression and power with one of these 2 top ends. What I have access to is a 1974 K model top end or a 1978 F top end...by top end I mean everything above the block. Now I have access to both but I have to chose one has the owner of these top ends is trading me 1 of them for some stock parts...my question is which one should I chose? I've read that the F has different  oiling than the K but I read both that it can or can't be used on a K block so I'm confused.
I apologize if this has been covered in the past but after reading some posts I still need some guidance
Thank you in advance
Dom
Stock 1978 cb750A
Konged 1976 cb750A
Stock 1978 standard gl1000
Dressed 1980 GL1100
Project 1965 CA95 Honda benley
2003 shadow a.c.e deluxe
Re: Hondamatic top end upgrade choices
« Reply #1 on: February 01, 2017, 09:19:46 AM »
The easiest way to properly use the late model F top end is the entire thing, cylinders, pistons, head and cam then you're OK. The downside to the F2/F3 head is the valve guides which wear quickly so that's something to watch for before installing.
OR - I'd keep the 392 head you have and use a late model cam. If your pistons are low compression ?? swap them out while you're at it. Maybe 77/78 K or 75/76 F. Also a cam from one of these engines would be an upgrade from the 74 K cam.
« Last Edit: February 01, 2017, 09:22:05 AM by Jerry Rxman Griffin aka MuthaF'er »
Offline Kongamatic
« Reply #2 on: February 01, 2017, 09:25:39 AM »
Thank you, I was planning on using the entire set up of either one so seems like the F would be a better choice cam wise and yes I have low compression pistons now.
My only concern with the F was different oiling distribution I've read about...but if your positive by using the cylinders and head from the F will work I'll use that one.
Thanks again
Dom
« Last Edit: February 01, 2017, 09:45:13 AM by Kongamatic »
Stock 1978 cb750A
Konged 1976 cb750A
Dressed 1980 GL1100
« Reply #3 on: February 01, 2017, 10:17:59 AM »
The oiling distribution is the same. It's the return that differs. The F2/F3 head has only half the returns the other 750's have but the matching parts top end will work on the other 750 engines.
Don't forget the matching F2/F3 pistons too.  ;)
Offline Kongamatic
« Reply #4 on: February 01, 2017, 10:31:43 AM »
Awesome and thank you!
Yes I'll be using the pistons and rods from that same motor.
I'll be using round top...any guess on a ball park jetting I can start with?
Stock 1978 cb750A
Konged 1976 cb750A
Dressed 1980 GL1100
« Reply #5 on: February 01, 2017, 12:33:48 PM »
The rods are all the same so you don't really need to swap those. The F2/F3 however uses better rod bolts but going down that road with the F2/F3 rods will possibly require new bearings. 10 X ~ $13.00 for crank and 8 X ~ $12 for rods. You could always swap the assembled F2/F3 crank with rods. That would probably eliminate new rod bearings. You'd need to compare engine/crank codes for crank bearing sizes for starters. If they are the same according to the charts use what's in the build engine but Plastigauge them for clearances. Sooooo, my take, use the original crank and rods and not really have to go through all this. Perhaps just use new wrist pins with the different pistons if it looks like there may be a problem.
Not sure what the F2/F3 is jetted at but I'd do that for starters. Keep in mind the final jetting will depend on exhaust, carbs and air cleaner.
Offline stikman
  • Bit of an
« Reply #6 on: February 01, 2017, 08:49:44 PM »
For simplicity I'd go with the full K top end.  If I remember correctly, the intake boots for the roundtops won't work with the F head, different spacing.  I would prefer to run that F cam with the rest of the K top end.  But really, swapping in the whole K top end is going to up your compression from stock A pistons, and the K cam and roundtops are a real upgrade from the A as well.  I'd pass on the F head for the reason Jerry mentioned, they wear out the valve guides.
1977 CB750A "High Horse": 836cc, mild porting, custom cam, K5 roundtops, v-stacks...
1973 CB750K D5 plunger frame chopper currently building..
Offline Kongamatic
« Reply #7 on: February 01, 2017, 08:55:23 PM »
Thanks guys I truly appreciate all the info!!
Stock 1978 cb750A
Konged 1976 cb750A
Dressed 1980 GL1100
Offline stikman
  • Bit of an
« Reply #8 on: February 01, 2017, 09:09:04 PM »
Not a problem.  Let us know how it goes.
Offline Kongamatic
« Reply #9 on: February 01, 2017, 09:35:34 PM »
Will do!! This is where I'm at right now,waiting on dohc swing arm and shorty shocks then I'm I will start to Kong the frame....the front end is a yamaha xt250 with 21" drum gives me about 3" over...might rake it all depends on how it sits after the rear suspension mods and rear tire/rim choice which might be a solid rear rim
« Last Edit: February 01, 2017, 09:37:26 PM by Kongamatic »
Stock 1978 cb750A
Konged 1976 cb750A
Dressed 1980 GL1100
Offline Desert-SOHC
  • It's old
« Reply #10 on: February 01, 2017, 09:50:45 PM »
What happened to your stock front wheel?
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
Offline Kongamatic
« Reply #11 on: February 01, 2017, 09:53:07 PM »
Nothing,looking to build something different.
Stock 1978 cb750A
Konged 1976 cb750A
Dressed 1980 GL1100
Offline kac3177
« Reply #12 on: February 03, 2017, 05:15:31 PM »
I'd spend the money on an 836 upgrade. I build on a budget too however if you are going to do it, do it once... New pistons, rings and a fresh bore. The bigger cam and carbs will make a noticeable top end improvement, it did on my stock bore 76'
kac3177
Offline Desert-SOHC
  • It's old
« Reply #13 on: February 05, 2017, 03:22:33 PM »
No, I'm interested in a 750A front wheel.  Did it have the stock one on it when you got it?
11 Ranger S/C 2wd
Offline Kongamatic
« Reply #14 on: February 10, 2017, 09:37:40 AM »
Yes it was stock but unfortunately I just traded it for 77 K pistons and cam plus a few other odds and ends I needed.
This is where I'm at now....gonna start the Kong tomorrow.
Stock 1978 cb750A
Konged 1976 cb750A
Dressed 1980 GL1100
Offline BPellerine
« Reply #15 on: February 11, 2017, 06:02:52 PM »
you will not have much brake on that bike,small drum.bill
1978 CB 750K ard and webers
another anfob
Offline Kongamatic
« Reply #16 on: April 02, 2017, 11:59:07 AM »
Sorry I haven't been online lately but been busy getting my bike ready for a builders show I was invited too
Here she is....
Stock 1978 cb750A
Konged 1976 cb750A
Dressed 1980 GL1100
