Author Topic: Carb boots, air box side  (Read 938 times)
Offline txterror
« on: February 05, 2017, 10:40:39 am »
Does anyone have any tips on how to get the boots to carb 2 and 3 all the way on. I remember a while back someone mentioning using a tire tube inflated in the air filter box but I don't have one on hand. Just wanted to see if there were any other techniques. Thanks for yalls time
1975 cb400f
Online Don R
Re: Carb boots, air box side
« Reply #1 on: February 05, 2017, 12:17:48 pm »
It might want to be rotated, they have a top and bottom. If they're hard it's really a pain.
Offline Scott S
« Reply #2 on: February 05, 2017, 12:25:15 pm »
 Yes, see that nipple at ~11 o'clock in your pic? That lines up with a dot on the air box. New rubbers help. Leave the bolts on the air box off or VERY loose (the ones that attach to the frame). Attach center two and snug up clamps. Then push air box forward and snug up outer two. It helps to have a second set of hands.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline jonda500
« Reply #3 on: February 05, 2017, 04:57:18 pm »
slip a large screwdriver between the plastic and the rubber and apply pressure while you tighten the clamp
John
A starter clutch thread:
Offline txterror
« Reply #4 on: February 05, 2017, 07:16:39 pm »
Thanks guys, does anyone have the air box pattern (dots to line up) so I don't have to remove the air box again. Thanks again for yalls time and help.
1975 cb400f
Offline txterror
« Reply #5 on: February 06, 2017, 06:32:25 pm »
So carbs aren't leaking anymore! But now when choke is off it's reving very high, and idle strew is almost all the way out too. What would cause this? Bike has never done this.
1975 cb400f
« Reply #6 on: February 06, 2017, 06:51:53 pm »
This sounds a bit like one of the cables is possibly trapped (under the tank) or kinked? Or, maybe the slack is adjusted a tad too tight? It literally takes just 1/8 turn of the cable slack adjuster on the cable to make it hit 1500+ RPM.
Offline txterror
« Reply #7 on: February 06, 2017, 09:52:58 pm »
Thanks Hondaman, I'll take a look at the cables. Your referring to the throttle cables, correct?
1975 cb400f
