Author Topic: 750 k1 seat  (Read 1002 times)
Offline dusterdude
750 k1 seat
« on: February 05, 2017, 02:25:19 pm »
I need a thinner seat than my stock seat.i need to drop about an inch to an inch and a half,minimum.ive seen cafe seats on ebay and other sites,i would like a seat i can mount in the stock location if possible.i dont care if it has a steel base or fiberglass or any other material.any ideas?thanks
Sent from my R1 HD using Tapatalk
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Re: 750 k1 seat
« Reply #1 on: February 05, 2017, 02:31:29 pm »
Why not cut down the foam on a stock seat? [find one with a bad cover]
Offline calj737
  • I refuse...
Re: 750 k1 seat
« Reply #2 on: February 05, 2017, 06:01:34 pm »
Mark - I know an upholstery shop down in PG that could probably do that job for you, recover it, and get you back on your way. He does really good work and is PG-priced too  :)
Stingray 452-3700
Online Don R
Re: 750 k1 seat
« Reply #3 on: February 05, 2017, 06:20:49 pm »
 I sliced the one on my Goldwing, I peeled back the cover and sliced the foam with a new fine hacksaw blade, An electric knife will work too. Then pulled the foam back down and took up as much of the vinyl as possible. In Japan this is very common, I think Yamiya even has the low seat foam as a seat option.
Offline dusterdude
Re: 750 k1 seat
« Reply #4 on: February 06, 2017, 04:07:06 pm »
Stev,that is a viable option
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline Duanob
  • Bold Timer
  • Gotcha!
Re: 750 k1 seat
« Reply #5 on: February 07, 2017, 12:58:55 pm »
Or replace the oem foam with better newer type foams. 2" of high density and a 1" memory foam topper, his butt with thank him later.  ;D
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline dusterdude
Re: 750 k1 seat
« Reply #6 on: February 07, 2017, 04:53:57 pm »
I dont want to change my stock seat
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
