Author Topic: Removing Spot welds from a Gas Tank  (Read 1735 times)
Offline gwallis
  • 1976 Honda CB550F 1973 Honda CB750
« on: February 06, 2017, 01:51:02 pm »
I have a 1977 CB400F Super Sport gas tank that I want to remove the hinged mechanism for the gas cap lid.  There are two areas that I want removed... the hinged area as wells the metal locking piece.  These areas are fixed to the tank using spot welds.  Four altogether.
What is the best way to remove the spot welds without damaging the metal directly underneath?
Offline calj737
  • I refuse...
Re: Removing Spot welds from a Gas Tank
« Reply #2 on: February 06, 2017, 01:57:51 pm »
He does not want to go thru..that leaves grinding..
Offline gwallis
« Reply #3 on: February 06, 2017, 02:04:42 pm »
A small amount of grinding and then body filler is expected.  Just do not want to drill into the tank itself.
Offline calj737
  • I refuse...
« Reply #4 on: February 06, 2017, 02:05:47 pm »
They do not if you use them as directed.
Offline 540nova
« Reply #5 on: February 06, 2017, 02:46:21 pm »
Eastwood sells those, as well.
Offline innovativems
    • Innovative MotoSports
« Reply #6 on: February 06, 2017, 03:46:22 pm »
Spot weld removers are amazing. Just take your time
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
« Reply #7 on: February 06, 2017, 05:56:22 pm »
Once they are off, then what is the plan ?
Offline Rocky2010
  • Live in Strayla
« Reply #8 on: February 06, 2017, 06:08:40 pm »
Just grind the plate down till you get to the tank material, the plate should just fall off or just with a light tap with a hammer and it shouldn't damage the tank material.
2010 Harley Fatboy Lo
1972 Honda CB750/4 Under Restoration
1971 Honda CB500/4 Original Condition
1972 Honda CB350/4 Original Condition
1972 Honda XL250 Motorsport Under Restoration
1967 Honda C90 Original Condition
1968 Honda S90
1962 Triumph Speed Twin
1952 Triumph Speed Twin
1970 Bultaco Sherpa T
1971 Bultaco Alpina
1958 Moto Guzzi Zigolo
1970 Moto Guzzi Ambassador Original Cond
1973 Yamaha RD250
1948 Velocette x 2
1942 WLA Harley Davidson
2006 Kawasaki ZX12R (Sold)
1980 Corvette
Offline gwallis
« Reply #9 on: February 06, 2017, 08:01:10 pm »
'The Plan' is to eliminate the lid that covers the interior gas cap.... paint and then add a chrome gas cap to complete the look.
The scalloped area that currently surrounds the gas cap will give it a different look... different but pleasing.
If you have ever seen and touched the cover it is very flimsy and cheap.... and it protrudes above the tank... not flush like the CB550 super sport.
