Author Topic: Hagons  (Read 2229 times)
Offline 550Resto
Hagons
« on: February 07, 2017, 09:30:31 AM »
Looking at ordering some hagon for me 78 550. Anyone have experience with Heather USA? They don't have an option to pay through the site. They want me to send my info through email which I am hesitant to do. Doesn't seem like much in the way for protecting data.
Re: Hagons
« Reply #1 on: February 07, 2017, 09:47:19 AM »
https://www.davequinnmotorcycles.com/
Awesome to work with.  They answer phone calls and emails.
Offline Kevin D
  • SE Michigan
Re: Hagons
« Reply #2 on: February 07, 2017, 09:56:06 AM »
Dave Quinn +1
Prompt and helpful
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline grcamna2
Re: Hagons
« Reply #3 on: February 07, 2017, 10:09:58 AM »
Yes,Dave does pick up his phone and say "hello" and then helps you  ;) A rare thing in these electronic times..
Offline jamesw
Re: Hagons
« Reply #4 on: February 07, 2017, 10:47:19 AM »
You should consider Ikon shocks from NobleHops, who is the US distributor and a member here.
Great to deal with.
I bought 2 sets of custom shocks.
We get a discount too.
http://forums.sohc4.net/index.php/topic,163109.0.html
72K-F 750 Cafe
75K 750 Cafe
75F 750 Restoration
Offline Mooshie
Re: Hagons
« Reply #5 on: February 07, 2017, 05:46:17 PM »
Dave Quinn +1
Prompt and helpful
+2 Dave Quinn.  Love my Hagons on my 550
1976 CB550F
Standard disclaimer: Remember I am just a girl--so be nice fellows!
Re: Hagons
« Reply #6 on: February 08, 2017, 04:03:27 PM »
I have Hagons on my 550.  I had IKONS on my 750 -- better in my opinion but slightly more expensive.
Re: Hagons
« Reply #7 on: February 08, 2017, 04:49:49 PM »
+1, Ikons on my 750 are superb.  Hagons on my kz650 are quite excellent, but not as good as the Ikons...perfectly natural considering Hagons start around $200 and Ikons start about twice as much
Re: Hagons
« Reply #8 on: February 08, 2017, 05:53:34 PM »
Some times you get what you pay for.
Offline 550Resto
Re: Hagons
« Reply #9 on: February 16, 2017, 04:42:21 PM »
Looking at pulling the trigger on the 2810s that Dave offers. Any suggestions on length? They offer a 12.2 and 13 inches. Stock length is 12.6 I know you want to stay as close to stock as possible.
Offline jjminch
Re: Hagons
« Reply #10 on: February 16, 2017, 07:51:40 PM »
Can the Hagons be ordered 1" longer than stock?  I'd like to have ample clearance for a brat seat if I go that route?
Any of the track day guys chime in on Ideal shock length for a stock SOHC 750?
Offline 550Resto
Re: Hagons
« Reply #11 on: February 19, 2017, 12:39:20 PM »
Anyone have adevice? Will 12.2 be better than 13 inches or vice versa?
Offline jjminch
Re: Hagons
« Reply #12 on: February 19, 2017, 12:48:18 PM »
Not knowing 750s well I would go with a 13". Most other bikes I've always gone longer in rear for improved handling.
Offline 550Resto
Re: Hagons
« Reply #13 on: February 19, 2017, 12:58:06 PM »
This would be for a 550
Re: Hagons
« Reply #14 on: February 19, 2017, 01:28:20 PM »
If I recall correctly when you call and work with Dave for the Halgons he interviews you to understand your bike's weight ( if modified heavily) the type of riding you do and loads you expect  and the mods you have made.  Knowing this he is able to send you a set that are setup with the proper spring rate and recommended preload settings for your riding. 99% of the time they are spot on.
Women weighing 100-120 pounds, or Men, will need a substantially lighter spring than a 200 pound male rider with 105 pound wife riding two-up most of the time.
Offline grcamna2
Re: Hagons
« Reply #15 on: February 19, 2017, 02:54:38 PM »
I think RAF122S is right about Dave Quinn and he will be able to help you with even this decision.  :)
Offline 550Resto
Re: Hagons
« Reply #16 on: February 19, 2017, 03:14:58 PM »
Dave reccomended the 2810 10 way adjustables. He stated that they come in 12.2 or 13 inch lengths but couldn't give me advice on which length to go with because he has not ridden a 550 with that setup. Hence my question on which length to go with.
Offline MikeSimon
  • MotoManiac
  • Motorcycle Addict
Re: Hagons
« Reply #17 on: February 19, 2017, 03:37:45 PM »
Think about it: If you put Öhlins adjustables on the rear of your CB750, the shocks may be worth more than the whole bike...That's what I would go for....
1973 CB350F -sold
1974 CB350F -218 orig miles, sold
1976 CB750K - in restoration
Other Hondas:
3 x CBX
CB1100R
GB500
Plus Kawasakis, BMws & Ducatis
Re: Hagons
« Reply #18 on: February 20, 2017, 02:00:33 AM »
I would be afraid to park it out in public lest some bike thief spot it and the Ohlins and decide it is the bike to take in a large part from the Ohlins alone.  That is a good chunk of change on bike.  Definitely need to keep records and insurance aware of mods and value of the bike so the policy coverage is adequate for your needs.
David
Re: Hagons
« Reply #19 on: February 20, 2017, 06:13:26 AM »
Is measurement for shock in center height for preload setting.  How much range of movement is available in upwards or downwards direction? Is that adjustment result in equal movement in either up or down adjustment in the ride height when loaded with identical weight or is it the spring is loaded more or less to put it into a higher state of compression to start when loaded?
Offline grcamna2
Re: Hagons
« Reply #20 on: February 20, 2017, 07:07:24 AM »
+1
Re: Hagons
« Reply #21 on: February 20, 2017, 04:18:15 PM »
The 550s have a nice turn in and steering is an entirely different animal than how a 750 steers.  I do not think it will make it dangerous by altering the geometry greatly with an inch higher rear suspension.  It will make it easier to turn in and increase the rate you can easily turn the bike. It will make it crisper and will take a very small amount of time to adjust your lean and pressure required to make it turn.  Guys racing the 550 will do this.  The extra inch does not provide a massive change to the rake and trail by raising it another inch.
David
Offline turkey4me
  • The closer you are the less you can see!
Re: Hagons
« Reply #22 on: March 04, 2017, 04:40:50 PM »
Not a 550 but I just put  14" Hagons on my 750F.  Went for the first ride and  handling was great.  +1 for David Quinn
Offline Dunk
Re: Hagons
« Reply #23 on: March 04, 2017, 06:21:56 PM »
I almost got Hagons but went with Ikon for my restoration as they look closer to factory shocks. I'm thrilled with the performance. Can't comment on Hagon as I've never run them, but on a budget I'd give them a try.
