Author Topic: Cam tower studs  (Read 3238 times)
Re: Cam tower studs
« Reply #25 on: February 08, 2017, 12:49:08 pm »
Remember threaded rod is usually a poor class of fit, unless higher grade rod.
Offline markb
  • When I finish my current project I might be a
Re: Cam tower studs
« Reply #26 on: February 08, 2017, 01:20:00 pm »
Hi Mark,
Here's my take on it. Screws have been used on the the back holes because they are 'blind' ie they don't go all the way thru. The front holes are thru holes, because the casting is thinner at this point. By using studs on the front holes, each time the cam or cylinder head is removed, it saves having to go thru the process of re-sealing these. If a bolt is used at the front you have to be careful the clean the hole out, get new sealant into the hole etc.
I like it. Sounds logical to me.  :)
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
