Author Topic: Making a Dymag Magnesium Wheel video  (Read 2313 times)
« on: February 09, 2017, 12:33:29 pm »
I will try to add link later
 Part of this video shows them casting a magnesium Dymag, same as one I have. Lot more work than casting aluminum.  Lot of waste material , probably to eliminate pits.
Lots of voodoo going on to clean the metal before pouring.
Search on Youtube  BBC Technical Studies Die and Investment Casting.
« Last Edit: February 09, 2017, 02:07:14 pm by 754 »
Offline slikwilli420
  • Master of Disaster
Re: Making a Dymag Magnesium Wheel video
« Reply #1 on: February 09, 2017, 01:05:46 pm »
I dig the Dymag 3 spoke wheels, truly some 80's superbike kit that makes any big 4 look even better. Between these and a repop set of Morris mags I don't know which I would choose, but either would be spectacular.
« Reply #2 on: February 09, 2017, 01:50:28 pm »
Frank, see the address bar at the top of the page that shows the link, put the cursor on it and click on it {left click}, it will turn blue, then right click on it and a window will open up, click "copy", in your thread just right click again {the window will open again} and "paste" and the link will now be in your reply, you have to learn this sooner or later... :P
« Reply #3 on: February 09, 2017, 02:09:02 pm »
No left click here.....I copy with a Bic, then transfer to my keyboard..... Works sometimes.
« Reply #4 on: February 09, 2017, 03:41:15 pm »
Don't you have a mouse...?
« Reply #5 on: February 09, 2017, 03:53:47 pm »
No mouse, no computer...
« Reply #6 on: February 09, 2017, 04:10:34 pm »
Phone..?  Plenty of guys post from phones here, should ask someone how they post links....
« Reply #7 on: February 09, 2017, 04:29:12 pm »
Not my phone..my Shoe Tablet.... Look up..waaaayyy up..i posted it ..
 Used the old scribble and hunt peck trick.......learned it from Maxwell Smart..
« Last Edit: February 09, 2017, 04:32:54 pm by 754 »
Offline Rocketman
« Reply #8 on: February 09, 2017, 04:38:44 pm »
Frank,
Way cool.  Thanks for posting.  If anyone needs old Dymags or Morris magnesium wheels refurbished I can recommend Frame Straight Systems.  http://www.framestraightsystem.com/  He did a set of Dymags for me last year.  Had to blast them, check for cracks, apply a chromate finish to prevent corrosion, and then paint them.  Not cheap, but magnesium wheels can corrode and crack.  More of a problem with older wheels like mine which were on a 1982 roadracer.
Martin
« Reply #9 on: February 09, 2017, 06:36:12 pm »
 Did you see how much they cut off the side.. I think to eliminate surface pits.
Not really waste if its at the foundry, all get remelted.
They have a lit of other videos , quite detailed explanations of how stuff is made.
« Reply #10 on: February 10, 2017, 05:11:53 am »
I saw that.....and the way he chucked the rim in that container! ;D ;D
« Last Edit: February 10, 2017, 05:16:46 am by MRieck »
« Reply #11 on: February 10, 2017, 09:55:24 am »
Does that video not answer a lit of questions about casting ? Even car wheels and other parts..
I was surprised at how much they have to fiddle with casting magnesium vs casting aluminum or cast iron.
 I was so surprised when I saw a wheel that I have, being made...
