Author Topic: New Video - (Not A) Botched Bore Job?  (Read 3040 times)
Offline bochnak
    • How-To Motorcycle Repair Blog
Re: New Video - (Not A) Botched Bore Job?
« Reply #25 on: February 20, 2017, 09:50:35 AM »
How do you even bore a taper? Most boring machines I have seen has a fixed single cutter that rotates and translates, providing a straight cut.
« Reply #26 on: February 20, 2017, 01:10:20 PM »
An automotive boring bar should stay straight.
 On a lathe you can bore a taper, a few ways.
But in fitting a piston, the boring is the first step, then you finish hone.. You can create a small taper when honing...either on purpose, or by accident if you are sloppy.
 Forged pistons are usually set up looser, they have different expansion rates.
The only reason to set up anything loose, it to be able to race without breakin...or maybe because you cant measure accurately.
