Author Topic: Reinstalling fork caps and keeping the skin on your hand.......  (Read 2758 times)
Offline misterskin
  • www.sohc4.net
    • My Pics
« on: December 09, 2006, 06:58:03 AM »
A tip to getting the fork caps back on while under presure (if you are adding the PVC spacer described a couple of threads down)......  Go buy a CHEAP rubber mallet.  Take the mallet head off and throw the handle away.  Take a razor/exacto blade and cut an outline of the "nut" on the fork cap into one end of the mallet head, basically making a big a$$ rubber socket.  You can use this to push & twist that cap back down and get the threads started easier, saving the palm of your hand!
I have done the spacer thing on dang near every bike I have had.  From one inch spacers in stock length forks, to making up the differences in 8/10 inch over forks on choppers.  Sometimes these can be a booger to get started and pressing on a big piece of rubber is much more comfortable, and easier than pressing on a socket/rachet combo and trying to turn it at the same time!
Offline jaknight
  • ....Round Town Ride......
Re: Reinstalling fork caps and keeping the skin on your hand.......
« Reply #1 on: December 09, 2006, 09:58:42 PM »
     Good idea........... will give it a try next time I pop those caps to change/add oil.
     Love that 750 avatar you've got 8) 8)
     ~ ~ ~ jaknight ~ ~ ~
"THE PEN IS MIGHTIER THAN THE SWORD........
..........EXCEPT IN A SWORD FIGHT"
"There is nothing new under the sun.........But there are many old things we do not know"
BIBLE ---> Basic Instructions Before Leaving Earth
Offline kghost
« Reply #2 on: December 09, 2006, 11:48:18 PM »
hmmmm......
I just use the wooden handle to press down on the cap while gripping the rubber head.
Then I spin the nut with the wrench from the tool kit......
Stranger in a strange land
Offline turboguzzi
« Reply #3 on: December 12, 2006, 03:34:27 PM »
Destroying  a hammer and on top of that having to cut it?
I just use a socket (size of the hex on the cap) + an extension as a handle. gives you a good sense of the direction you are screwing so it's harder to cross thread.
You can take out a lot of your guess work by unscrewing slowly the cap (without the spring) and making a small mark of the postion where the last thread ends. Both on cap and triple clamp. When you screw in the cap, start your twisting just  a couple milimeters before your mark so that the thread catches immediately after 1/4 of a turn.
Works every time
Offline skidpan
« Reply #4 on: December 12, 2006, 03:42:35 PM »
Thats a shockingly good idea, turboguzzi
Offline misterskin
  • www.sohc4.net
    • My Pics
« Reply #5 on: December 13, 2006, 12:20:22 AM »
I got the hammer from "The Dollar Tree", one of those everything is a buck stores...it was 100 pennies.  Not like I wasted a 20 dollar hammer.   ;)
Offline Rsnip988
« Reply #6 on: December 23, 2006, 11:53:45 AM »
Works every time
worked for me
R.K.S.
1976 CB750 K6 Full
1976 CB750 K6 Cafe'ish
Offline Mekagojira
« Reply #7 on: January 26, 2011, 02:44:19 AM »
Any other tips? I'm going to try the mallet thing tomorrow.  I am assuming  my springs are good since I can't get the caps in easily…?
Started my first fork oil change hours ago...
1975 CB750F
« Reply #8 on: January 26, 2011, 03:07:16 AM »
You do have the weight off the front end .? Make sure there is no weight on the front wheel and it is off the ground and i use a large good quality socket..
Offline Mekagojira
« Reply #9 on: January 26, 2011, 03:49:35 AM »
Thanks -
Yeah, bike on center stand, then I jacked it so the front wheel was an inch up…
These springs are like 4 inches out - it takes all I got to press them back in while holding the socket - I'm pressing so hard the wrench won't ratchet…  ???
1975 CB750F
Offline turboguzzi
« Reply #10 on: January 26, 2011, 06:34:21 AM »
dont use the ratchet, just a socket extension as a handle
and read my prior advice on starting the cap on the threads, it's all there .... ;)
Offline bjatwood
  • I'm not a Big Shot, I'm just a
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #11 on: August 17, 2011, 01:17:36 PM »
I just pushed down the nut with all I had and had the wife give it a couple spins with a open end wrench. No cussin and no fussin
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
Offline Spiider
  • '73 CB750k
« Reply #12 on: February 04, 2012, 04:46:49 PM »
I know this is late but a correct fitting socket and a speed handle work great too.
You can use both hands to press down with the speed handle and then turn it ccw to set up the threads a full turn then cw to start screwing it down.
It's never taken me much effort to get them to go back in properly first try.
Offline MoMo
  • Ride like you're invisible
    • my photobucket link
« Reply #13 on: February 04, 2012, 05:26:28 PM »
Another late reply, but every mechanic I worked with for the 14 or so years I wrenched used this- a sliding t-handle with a ratcheting adapter and the proper socket. The T gives you pressure on both sides and the ratcheting adapter lets you to get the feel of when the cap is properly threaded...Larry
Present: 1975 CB750, two 1974 CB750's, 1975 CB400 four,  1981 GL500I, 1974 CZ 250 Enduro, 1966 Suzuki S32 150cc , 1977 CB750K7, 1974 Honda XL125K0, 1983 Honda Sabre, , more to come.
Past: Honda XL125 I rode in enduros, Honda XL175, Yamaha DT1, MZ 250 ISDT, Harley Hummer, 1969 Honda CB350, 125 Sachs/DKW, 250 Ossa Pioneer, 1968 250 Montesa La Cross, Yamaha RD350, two Yamaha TX500, eight Honda CB450 dohc, 250 KTM, 1982 Yamaha 650 four(worst bike ever owned), seven Honda CB400f's, 1983 Honda VF750F Interceptor, 1981 CB650, 1973 CB350G, 1973 CB750, mint 1975 Honda CB550F, 1977 CB750K , GL500I Silverwing, 1973 Jawa 175 Trailmaster, SL350 K2, 1970 CB750K0, 1972 CB350 and  probably others long forgotten.
Offline ChuckG750f1
  • Not your average, everyday, run-of-the-mill
« Reply #14 on: April 19, 2012, 12:43:19 PM »
^nice!
Life is hard; it's harder if you're stupid.
- John Wayne
1976 CB750 f1
1995 HD Softail Custom
Motorcycle Project Banner Ad
Honda
