Author Topic: 750 chopper electrical  (Read 1139 times)
Offline WhiteRust
« on: February 21, 2017, 07:44:37 PM »
Chopper gurus, I'm looking to increase the draw on my choppers electrical system. Added an extra headlight and the overcharging problem still remains. Any input is appreciated.
Online calj737
  • I refuse...
Re: 750 chopper electrical
« Reply #1 on: February 22, 2017, 10:17:03 AM »
Your system is "over charging"? If so, the Regulator sided the charging system needs to be troubleshot. Adding components to increase draw is not the answer. It's akin to raising the floor level when your basement floods. Fix the drainage inbound  ;)
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #2 on: February 22, 2017, 11:10:15 AM »
+1
Over charging is typically either the regulator or rectifier (diodes). If you don't correct it you can ruin the battery.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #3 on: February 22, 2017, 11:19:39 AM »
And if it's a lithium-based battery, it can runaway charge and explode.
