Author Topic: JMR billet engine build  (Read 23297 times)
Offline frodef2
« on: February 22, 2017, 12:40:39 PM »
So, back in 2014/15 i started to gather parts to build a high power cb750 engine.
In February of 2015 i had gathered all parts and started the assembly.
I had the case machined to accept the JMR billet block, and then powdercoated
I received the cases back from the powdercoater cleaned and nice. I re cleaned everything myself, as the coater told me he had to blast the cases for powder prep. I finished the assembly of the engine and even installed it in the frame.
The thing is, i had a bad feeling about the cleanliness of the powdercoater even after i had recleaned the cases. So i ordered a snake cam on ebay to inspect the oil gallerys.
First i inspected the main crank oil gallery, and i found sandblasting sand at the generator cover side of the oil gallery.
I am was so bummed out by my crappy inspection and assumption that the cases were clean. That i left the engine in its assembled but "graveled" state until now.
The pewee video in the hi-po forum made me want to get it right.
So here are the pictures from the dismantling
« Last Edit: February 22, 2017, 12:55:58 PM by FrodeF2 »
76' Supersport
Offline Darren Jakal
Re: JMR billet engine build
« Reply #1 on: February 22, 2017, 12:45:49 PM »
Let's see.
Offline frodef2
« Reply #2 on: February 22, 2017, 01:02:39 PM »
This is the state the bike has been in the last two years
76' Supersport
« Reply #3 on: February 22, 2017, 01:57:26 PM »
Better to find out now than LATER.
Offline JoeCooley
  • Long time lurker, but now I'm a
« Reply #4 on: February 22, 2017, 03:12:10 PM »
Those are nice blocks. What size pistons are you running? They look huge! 😲
Joe in San Diego - Quick Cyles
78 CB750K 836cc Highway Racer - http://forums.sohc4.net/index.php/topic,162264.0.html
Rickman CR750 Restoration (SOLD)
Offline camera7
« Reply #5 on: February 23, 2017, 05:15:23 AM »
Where's e would you find these new and improved cam tensioner?
Sent from my iPad using Tapatalk
Offline camera7
« Reply #6 on: February 23, 2017, 05:16:10 AM »
What is a JMR billet
Offline frodef2
« Reply #7 on: February 23, 2017, 05:47:20 AM »
It is a cb750 sohc engine with these cylinders:
http://forums.sohc4.net/index.php?topic=49438
76' Supersport
« Reply #8 on: February 23, 2017, 06:29:16 AM »
Following
Offline frodef2
« Reply #9 on: February 27, 2017, 11:53:38 AM »
Today i removed the rest of the parts from the bottom half pf the case, and cleaned the gallerys on the top half.
A decent ammount of sand was removed from the plug area of both the generator plug and the filter area plug.
Next out is the gearbox oil gallery, and the main oil gallery in the bottom case half.
76' Supersport
« Reply #10 on: February 27, 2017, 01:12:43 PM »
This has to be a pain in the butt, but much better than ruining this awesome big block by not clearing the sand.
Offline innovativems
    • Innovative MotoSports
« Reply #11 on: February 27, 2017, 01:20:03 PM »
Fast progress!
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
« Reply #12 on: February 27, 2017, 07:33:56 PM »
71.25mm
Offline frodef2
« Reply #13 on: March 01, 2017, 11:52:12 AM »
Just came back from the garage after cleaning and inspecting the bottom half.
Absolutely no "gravel" in sight.
I also managed to get the the bottom half of the engine together, up to the point where i noticed my torque wrenches where missing.
The bottom is only snugged together right now to get the sealant squeezed.
Frode j
76' Supersport
Offline frodef2
« Reply #14 on: March 02, 2017, 11:48:25 AM »
Back from the garage again. Torqued the main bearing nuts to 20 ft-lb in 3 steps. And the 6mm bolts to 10Nm in 3 steps.
I also fitted a 90degree bend to the oil pressure switch location. I will be using a pressure transducer to be able to see the actual oil pressure on my motogadget speedo.
The next step will be mounting the pistons and the cylinder.
I am not looking forward to getting the flimsy oil rings in without pinching one.
Frode j
76' Supersport
Offline frodef2
« Reply #15 on: March 05, 2017, 10:46:38 AM »
Started timing the camshaft. Got the exhaust opening to one degree of the camcard, but the closing is 7 degrees late. I remember getting updated cam specs by email the last time, but i am unable to locate them.
76' Supersport
« Reply #16 on: March 05, 2017, 10:55:16 AM »
 Been there myself I have a big bore stroker that needs to come back apart. . That bike is awesome, I can't wait to see it all together.
Offline frodef2
« Reply #17 on: March 06, 2017, 01:00:59 PM »
Finished with the cam adjustments. I must say, i am not sure why i need to measure both the opening and the closing of the valve on both intake and exhaust to verify the correct cam adjustment.
I mean, on a single cam engine. If you get one valve opening correct, wouldn't the rest be correct also? Anway, i followed the degreeing guide on the webcam website. And in the end my lobecenter measurement came in 0,5 degree over the cam card. Using the calculations on the webcam site.  Only took 3 hours. Not bad for an IT guy.
76' Supersport
Offline Davez134
« Reply #18 on: March 07, 2017, 07:45:35 AM »
Looking great! My understanding for degreeing both the intake and exhaust is not so much to verify the opening and closing on the card, but to get the lobe centerlines of both intake and exhaust as close as possible. On my webcam for example neither the opening/closing or centerline matched the card exactly, but I got the centerline on both intake and exhaust to 103.5 degrees. I hope that makes sense.
Offline frodef2
« Reply #19 on: March 07, 2017, 12:35:36 PM »
Engine in frame, and mock fitted the carbs.
76' Supersport
Offline somesuch
« Reply #20 on: March 07, 2017, 09:46:24 PM »
need more updates!!! :)
Offline frodef2
« Reply #21 on: March 11, 2017, 10:10:13 AM »
3 picture updates from today.
Made a fixture plate for the new regulator, dyna 2000 box and the motogadget m unit.
76' Supersport
« Reply #22 on: March 11, 2017, 10:32:40 AM »
Are those Mikuni RS34s or larger?
Offline frodef2
« Reply #23 on: March 11, 2017, 10:56:21 AM »
Yes, they are rs34's. Bought them together with the head and cylinders from mr. Rieck.
76' Supersport
Offline Old Scrambler
« Reply #24 on: March 11, 2017, 11:26:35 AM »
Its looking REAL good :) :) :) Nice motor work :) :)
Depending on your weight...........you may want to have stronger springs on the shocks ;)
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
