Author Topic: JMR billet engine build  (Read 23303 times)
Re: JMR billet engine build
« Reply #125 on: July 31, 2017, 09:13:17 PM »
 My drag car has a racepack data recorder on a 567" big block and at lower rpm's reversion will suck air back into the header between pulses and make spikes on the data recorder. crazy.
« Reply #126 on: August 01, 2017, 05:50:49 AM »
Flow does go in both directions. ;D I am porting a CBX head which has....possibly....the worst ports I have seen. The most lateral ports on 1 & 6 can't be seen from the intake side which made me think they probably push more air through the port than pull it. ::) ;D
Offline Syscrush
  • Sold. :(
« Reply #127 on: August 29, 2017, 03:54:02 PM »
It really is interesting the design compromises made on that bike! And it's interesting that they did so much wrong but still managed to come up with the first 100hp production bike. Was it the first widely-available 4-valve head?
How badly is the flow mismatched between the different cylinders? I'd be really curious about how it looks with the carbs and airbox on, as I think the intake trumpets in the airbox are shorter on the outboard cyls to compensate for the longer runner length.
