Author Topic: Fuel line routing  (Read 1239 times)
Offline rokhedjo
Fuel line routing
« on: February 22, 2017, 04:08:02 PM »
Does anyone have a good pic of factory fuel line routing for 73 through 74 is r/h petcock ? Cant find any where 😐
1976 CB750k , 1974 CB750k, 1972 CB750K 1986 V65 Magna , 2006 Kawasaki KLR650, 2018 Yamaha Vmax1700
Offline evinrude7
  • not a kung-fu
  • something to hüsker
Re: Fuel line routing
« Reply #1 on: February 22, 2017, 06:55:18 PM »
what he said ^^^^^.  mine seems contrived.
cb750 k6 - ugly
Offline Sigop
« Reply #2 on: February 22, 2017, 07:13:13 PM »
Mine is a 73 750. Inside upper hole in carb rack takes the hose to carbs 1 and 2. Lower run hose plugs into back pipe of petcock and low under rack and into junction of 3 and 4. The 2 lines are not connected to each other but go directly to the 1/2 junction or the 3/4 junction. Will try a few pics but happy to talk through it. I'm taking tank off this weekend and can follow up with better pics then if still need it. I have learned that length of lines is critical and I searched an old post here that had a graphic and the cut length for each hose.
CB750 K3  Original Owner and Operator
Offline Sigop
« Reply #3 on: February 22, 2017, 07:17:13 PM »
« Reply #4 on: February 23, 2017, 05:07:20 AM »
Across insulators, through the hole, the fuel line should never go up the hill, horizontal at worst.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #5 on: February 23, 2017, 08:18:49 AM »
Good point, being gravity fed.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline emlupi
« Reply #6 on: February 25, 2017, 04:05:15 AM »
Do these photos reflect the correct fuel line routing? Does anyone have a definitive answer on this? I would like to know as well.
Offline my name is nobody
  • I like Pontiacs and Hondas
Offline emlupi
« Reply #8 on: February 25, 2017, 10:32:23 AM »
Thanks Nobody, the photos agree with what Sigop posted above. I will be refurbishing fuel tank and fuel lines here, shortly. This post will help with that task immensely.
Offline Sigop
« Reply #9 on: February 25, 2017, 03:21:50 PM »
Yes emlupi. That old post was THE solution after I had pulled mine apart. Cut length is perfect also. Also remove petcock bowl so you can get to the petcock nipples. Heat gun, a little wd40, and needle nose pliers . .
Offline emlupi
« Reply #10 on: February 25, 2017, 03:43:32 PM »
Thanks, excellent tip.
